Old 01-19-2013, 08:08 AM   #72991
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,277
Wow! Just the right colors. U should be selling that rope and idea on the KLR forum, you'll be able to retire in no time
Originally Posted by Mambo Dave View Post
Re: grips...
I may have to replace mine eventually when I change bars, but I'm certainly not going for foam grips (that nobody has) when this 'solution' has worked for me on two bikes and many miles so far:
Tightly wound in a spiral, these cushion and leave no noticeable pressure points that had my hands tingling after many miles with traditional grips.
And, they're wider than most grips - I don't even have big hands, but I find this far more comfortable.
Yeah, yeah, I wish I had some other color rope to change it... sorta... but it's what I had on hand from the limited choices Home Depot had that day. (Of course within days they had most colors available again.)
If even only as a stop-gap until you can find foam grips, I think if its comfort you're looking for, you might try this out.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-19-2013, 08:56 AM   #72992
acap650
acap650
acap650's Avatar
Oddometer: 681
Originally Posted by procycle View Post
There are 2 reasons why you don't see grips on the DR page. First, I like to keep the number of 'general' items that folks can usually get at any shop to a minimum - especially on the pages that are so filled out like the DR page. Second, for most folks replacing grips on the DR for the first time can become a nightmare of a job.
Some day we'll have some separate pages for our favorite general items.
After reading about the throttle grip being bonded to the tube it just made sense to order a new tube with the grips-my time is worth more than the few dollars a new tube costs, and the next grip change will be easy.
acap650 is offline   Reply With Quote
Old 01-19-2013, 08:57 AM   #72993
Kommando
Kommando's Avatar
Oddometer: 7,378
Originally Posted by DockingPilot View Post
Fellas,
Can the carb inlet tube on the stock BST be rotated ?
Yup. I padded the tube with a shop rag, then applied gently-increasing torque with a wrench until it moved.
Kommando is offline   Reply With Quote
Old 01-19-2013, 09:00 AM   #72994
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,615
Thanks fellas
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 01-19-2013, 09:13 AM   #72995
victor441
victor441's Avatar
Oddometer: 950
grips...
Gran Turismo grips are a good option, have been around at least 40 years...they are tapered and soft in the middle, very comfortable for long rides and not too slippery...vintage British bike parts suppliers often carry them
victor441 screwed with this post 01-19-2013 at 09:42 AM
victor441 is offline   Reply With Quote
Old 01-19-2013, 09:27 AM   #72996
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,557
Originally Posted by Porky View Post
GREAT IDEA
Have been thinking about thicker grips but want to retain my Cramp Buster. Your idea will enable me to keep my Buster.
Inerestingly enough, because I lay down a grip's-length of rope across the grip before wreapping it, with the right placing the throttle's "bulge" from that underlying end of rope it acts as sort of a cramp-buster. That, or for both hands at least an ergonomically better bulge up into the palm than a standard purely-round grip.
The neat thing, of course, is experimenting and catering the rope to your needs.
I don't ever want to go back to tiny Japanese grips again.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 01-19-2013, 09:35 AM   #72997
motolab
motolab's Avatar
Oddometer: 2,628
Originally Posted by jessepitt View Post
If you look at the write up you will see that I use a drill bit with an old, dull counter-sink collar on it for grip and drill it by hand. There is really no way to loose control and damage the screw.
Sounds time consuming, but safe.
I dont even drill all the way through the plug. The plug has a tiny hole already drilled in it which acts as a pilot for the drill bit but also allows a small fine thread screw to be turned a couple threads in if you leave a little bit of the cap when you drill.
Not drilling all the way through the plug precludes being able to tap the hole, which precludes being able to use a small puller, which opens up the possibility of cocking the plug on the way out, which opens up the possibility of cracking/breaking the fuel screw well.
Prehaps I should remove a small amount of the spring in order to counter the increased preload?
If you knew that there were benefits to be had from increasing the spring rate, then clipping the spring would be a viable option. If not, you could modify the spring seat on either end of the spring in order to reduce the preload back to normal. The bottom one would be easiest, but the top one could be modified to simultaneously allow the slide to open all the way (as it is, it tops out ~.060" or so short).
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-19-2013, 09:43 AM   #72998
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Regards,
Derek
Thanks for that. I will have a look at modifying the spring seat rather than the spring length. It make sense that clipping the spring would up the rate just like a fork spring. Will the increased spring tension caused by the needle shim cause a more sluggish throttle response?
jessepitt is offline   Reply With Quote
Old 01-19-2013, 09:47 AM   #72999
Kommando
Kommando's Avatar
Oddometer: 7,378
He can speak for himself.
If, however, you yourself are saying that none of you (who?) are aware of anyone who has used the stock needle with a modified airbox and achieved optimum results, I agree that with the USA needle, the possibility is slim (no need to shout BTW). If you are asserting that no one has used the non-USA stock needle with a modified airbox and achieved optimum results, then that's either because no one has tried, because whoever did try doesn't know how to tune, or because there is a better needle profile yet.Sure, let's!
The point I have been trying to make is that, based on the chart I have posted several times now, the results when using the DJ needle can hardly be called optimal, and that experience with many different needle profiles (including many of my own) on many different motorcycles has shown me that a profile such as the DJ needle has is likely to produce a wonky CO trace such as the DJ needle does in fact in practice produce. The same experience has shown me that a shape more like the non-USA adjustable needle has will in fact flatten the CO trace vs. what a needle with a shape like the DJ produces. I suppose there is always the possibility of an anomaly, but I can't see how the non-USA adjustable needle would not be an improvement over the DJ.I think that depends on the definition of the phrase "familiar with the practice of how to tune". I'm not saying that to be rude. It's just that there are different levels of experience and different levels of tuning (some of which are equipment-dependent). Unfortunately there's no way around that.
Regards,
Derek
So...Are you saying to try a non-USA (adjustable) stock needle, an open airbox, an adjustable idle-mix screw, a 150 Mikuni main jet, and a x40F0x muff with a smoothed header, at sea-level? Should the pilot jet remain stock or go a size bigger?
I'm planning to buy a brand-new DR, maybe this year. I'm willing to experiment before cutting the airbox (permanent), drilling the slide (semi-permanent), or wearing any carb components to questionable condition.
Old 01-19-2013, 09:52 AM   #73000
sandwash
sandwash's Avatar
Oddometer: 1,358
Well that was easy:
http://www.ebay.com/itm/HANDLEBAR-GR...sories&vxp=mtr
97dr650
sandwash is offline   Reply With Quote
Old 01-19-2013, 10:01 AM   #73001
Kommando
Kommando's Avatar
Oddometer: 7,378
Originally Posted by sin3kal View Post
Not sure if this is the right place for this question but wasn't getting too much love on the DDR site since my bike is a pre 96. Anywho, I have a 93 dr650 that broke the knuckle that attaches to the kickstart shaft (yup it's one of those bikes). Not much in the way of kickstart levers for this bike specifically related to the dr650 that don't cost an arm, a leg, and a wallet. Was wondering if anyone knew if any of the kickstart levers from a dr250 or 200 have the same spline count and diameter on their mounting knuckles.
Can it be welded, machined smooth, and then heated to relieve molecular tension?
Old 01-19-2013, 10:05 AM   #73002
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,557
Originally Posted by sandwash View Post
Those are 'replica' grips. Does the original maker still make them?
their motorcycles
RyanR
Old 01-19-2013, 10:37 AM   #73003
Kommando
Kommando's Avatar
Oddometer: 7,378
Originally Posted by Tech23 View Post
Same here, if Suzuki were to make any changes I would rather see it receive better, fully adjustable suspension components.
Tech23
Wide-ratio 6spd and HD stator output would be cool. I don't think the current DR really needs much that the current aftermarket can't already deliver nicely. The DR-Z400 suspension could be grafted on easily and inexpensively, but could they retain the height-adjustment feature? A windscreen, luggage, 10WHP, comfy seat, knobs, skid, handguards, or huge plastic tank are also easy to add.
Let's hope that Suzuki keeps producing a good base to build from...inexpensively.
Old 01-19-2013, 10:47 AM   #73004
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by NordieBoy View Post
I want the ProGrip foam rally grips.
No-one has them
http://www.amazon.com/Pro-Grip-Foam-.../dp/B0036GNRIC
(just a USA google, havent actually bought them)
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 01-19-2013, 10:49 AM   #73005
procycle
procycle's Avatar
Oddometer: 2,315
The slide spring can be easily shortened without cutting.
Slip the spring on to a 5/16" shaft or dowel (a #3 Philips screwdriver works well). Compress the spring fully and 'unwind' it a few turns. Naturally you want to measure very accurately before and after. If you go too far you can carefully stretch it back and start over.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Times are GMT -7.   It's 11:44 AM.
