Old 01-16-2013, 11:16 AM   #73036
motolab
motolab's Avatar
Oddometer: 1,146
Originally Posted by procycle View Post
I'm pretty sure I said show us not tell us.
I'm not sure what you mean. Are you saying that someone owes you a CV carburetor tuning how-to video?
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-16-2013, 11:50 AM   #73037
LucasLeader
LucasLeader's Avatar
Oddometer: 277
Chain Guide
My chain guide disappeared this morning on the way to work. I haven't thrashed the DR off road for a while so I'm not sure what happened. Does anyone that has upgraded theirs have a stock piece in decent condition they would like to sell?
LucasLeader is offline   Reply With Quote
Old 01-16-2013, 12:28 PM   #73038
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 1,772
Intiminators
Shameless Plug: I just posted a set of Intiminators for sale in the Flea Market. Nothing wrong, just switching to Gold Valves as my riding skills have changed.
Rob
'96 Suzuki DR650
'10 Kawasaki KLX351S #320
'01 Yamaha FZ1
The Lane Sharing Works Blog
Rob.G is offline   Reply With Quote
Old 01-16-2013, 12:30 PM   #73039
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,128
so much humor in this thread today
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 01-16-2013, 01:51 PM   #73040
procycle
procycle's Avatar
Oddometer: 1,614
No, I was trying to (in a polite way) say "put up or shut up"
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 01-16-2013, 01:52 PM   #73041
motolab
motolab's Avatar
Oddometer: 1,146
I don't follow.
Regards,
Derek
Old 01-16-2013, 02:33 PM   #73042
TinkerinWstuff
Take it apart
Oddometer: 1,128
I don't follow.
Regards,
Derek
He's saying theory is all well and good but none of us are aware of anyone who's used the stock needle IN CV carb WITH modified airbox AND achieved optimum results.
let's see where it's been done successfully. Many of us here are well familiar with the practice of how to tune - especially procycle.
1999 Suzuki DR650
Old 01-16-2013, 03:14 PM   #73043
procycle
procycle's Avatar
Oddometer: 1,614
I don't follow.
You keep saying how much better the OEM needle will work with an open airbox than the DynoJet needle. But you have no hands on experience tuning a DR650 with an open airbox.
The problem with the OEM needle and open airbox is that the needle will have to be raised about 4-6mm to have any hope of running well enough to make the bike rideable in the mid-range. Raising the needle that much causes the beginning of the taper to rise out of the needle jet way too early causing a low end bog.
In the real world the only viable solution available is the DynoJet needle.
I'd like to see you show that there are other options and I've even offered to foot the bill to give you that chance.
I'd also like to stop hearing about how much better OEM needle is until there is some proof to back it up.
Old 01-16-2013, 03:20 PM   #73044
motolab
motolab's Avatar
Oddometer: 1,146
He can speak for himself.
If, however, you yourself are saying that none of you (who?) are aware of anyone who has used the stock needle with a modified airbox and achieved optimum results, I agree that with the USA needle, the possibility is slim (no need to shout BTW). If you are asserting that no one has used the non-USA stock needle with a modified airbox and achieved optimum results, then that's either because no one has tried, because whoever did try doesn't know how to tune, or because there is a better needle profile yet.
Sure, let's!
The point I have been trying to make is that, based on the chart I have posted several times now, the results when using the DJ needle can hardly be called optimal, and that experience with many different needle profiles (including many of my own) on many different motorcycles has shown me that a profile such as the DJ needle has is likely to produce a wonky CO trace such as the DJ needle does in fact in practice produce. The same experience has shown me that a shape more like the non-USA adjustable needle has will in fact flatten the CO trace vs. what a needle with a shape like the DJ produces. I suppose there is always the possibility of an anomaly, but I can't see how the non-USA adjustable needle would not be an improvement over the DJ.
I think that depends on the definition of the phrase "familiar with the practice of how to tune". I'm not saying that to be rude. It's just that there are different levels of experience and different levels of tuning (some of which are equipment-dependent). Unfortunately there's no way around that.
Regards,
Derek
Old 01-16-2013, 03:25 PM   #73045
barko1
barko1
barko1's Avatar
Oddometer: 2,513
Regards,
Derek
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi
barko1 is offline   Reply With Quote
Old 01-16-2013, 03:31 PM   #73046
TinkerinWstuff
Take it apart
Oddometer: 1,128
New topic anyone?
1999 Suzuki DR650
Old 01-16-2013, 03:41 PM   #73047
Carl Childers
Carl Childers's Avatar
Oddometer: 94
Header Grind
My GSXR can showed up today so I pulled the stock exhaust off to get ready for the install and one of the first things I did was dremel out some of the weld out of the header pipe. I've gone from a trapazoidal opening to a round hole now that looks pretty good in comparison. I want to get the optimal opening without taking too much out so I was wondering if anyone could post a nice close up picture of the right amount of metal removal on this pipe?
Carl Childers is offline   Reply With Quote
Old 01-16-2013, 03:45 PM   #73048
JTB488
Oddometer: 43
Mmmm, more power!!
JTB488 is offline   Reply With Quote
Old 01-16-2013, 03:51 PM   #73049
TinkerinWstuff
Take it apart
Oddometer: 1,128
here's mine
before - mine wasn't as ugly as some I've seen
1999 Suzuki DR650
Old 01-16-2013, 04:10 PM   #73050
cberard
godaddy
cberard's Avatar
Oddometer: 60
Head light off-on switch
I would like to put a on-off switch for the headlight. Would still like it to work on high beam for flashing.
I think the drawing says the white is for low beam...other two are yellow(high) and black/white I am thinking is the ground? I am thinking the switch on the white? But I am a electrical moron...
Chris
NorthernI daho
cberard is offline   Reply With Quote
Times are GMT -7.   It's 03:18 PM.
