Old 01-23-2013, 01:07 PM   #73111
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by TinkerinWstuff View Post
That is interesting, I haven't heard of pinging on a stock setup. Thought I read up on this one pretty thorough before going forward but didn't see any of those. Did you see that on ADV or somewhere else?
I added some octane boost to get through this tank and it helped. The only time I got pinging was when my oil temps exceeded 270 for a moment.
I did not see anywhere else that people had to adjust timing for the HC piston. So I'm tempted to leave that as a last resort.
How about just going with High Octane pump gas? Might be enough?
The high temps are probably due to tight tolerances of your new High comp piston breaking in? Maybe a bit more cylinder honing required? Dunno.
I've not heard of any pinging reported among our little seven bike DR650 cadre. (all stock motors) My own DR (stock) has consumed lots of really crap Baja fuel out of rusty 55 gal drums. A nasty slurry of gas, water, Diesel and rust. I always try to get them to decant it into clear jugs so I see what I'm getting. It ain't pretty ... but the mighty DR ran fine ... no pinging ... even in 100F heat of Southern Baja.
Old 01-23-2013, 01:16 PM   #73112
Adv Grifter
Oddometer: 6,128
Originally Posted by TIGERRIDER007 View Post
Just recently picked up a DR650, of course, and was wondering about a specific tire to see if it will fit on the front...
I'm not sure if a 3.00-21 would fit in a Bridgestone ED03..anyone know?
Yes ... it fits. I think the ED03 is the Bridgestone "Gritty" tire. A really good and tough tire. We used them on long Baja rides. Pretty good ON and OFF road ... but more Off road. Go easy on wet paved corners until you're sure how she sticks ... or doesn't .
Old 01-23-2013, 03:44 PM   #73113
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,558
Nothing earth shattering
but still posting for those with winter boredom.
7k on my 2012 now. This sample taken between 6 and 7k miles.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 01-23-2013, 03:59 PM   #73114
DockingPilot
Oddometer: 9,558
And for a comparo
From my 07' with close to the same mileage taken in 2011. This was actually 1 quart 10w40 and 1 quart 20w50 Amsoil. Hence the higher Viscos
Frank Reinbold
Old 01-23-2013, 04:43 PM   #73115
shaddix
Oddometer: 647
I am sitting at a stop light and smoke starts coming out from under the tank! I am just 5 miles from the house so I go when the light changes and it blows away. Then I stop at a few more lights and no smoke. I get it home and shut it off and I don't see where any oil is leaking or anything. But now it won't start. The starter turns it over but it will not run. I really have no idea what to do with it? Should I take the carb apart?
shaddix is offline   Reply With Quote
Old 01-23-2013, 04:57 PM   #73116
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Pull the seat and tank and check the wiring...
DR650 Wiki
NordieBoy is online now   Reply With Quote
Old 01-23-2013, 05:01 PM   #73117
Sierra Thumper
Oddometer: 641
Sounds electrical......better start looking for burnt wiring. And check for spark, that'll tell you right away if its fuel/carb or electrical related.
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 01-23-2013, 05:03 PM   #73118
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,166
Re: Tires... since this comes up from time to time anyway...
I like the look of the ED03. I'll have to consider that. I was going to do T63's for my next set of off-road tires. But the Kenda in back... I dunno. I run those on my KLX250S, and while they're great tires, I think they wear out waaaay too damn quick for the KLX... I bet they'd be even worse on the much heavier DR.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 01-23-2013, 05:08 PM   #73119
Sierra Thumper
Oddometer: 641
Rob
Thats what most of the reviewers on the link to the Kenda said, that they liked the traction, but it wore out too fast. Thats why I won't be running them. I don't mind paying a few dollars more for longer life.
Old 01-23-2013, 06:40 PM   #73120
planemanx15
planemanx15's Avatar
Oddometer: 1,007
I had the same issue with my LED aux lighting. The positive wire frayed on the frame and and started smoking. I ended up adding a fuse and replacing all the wires.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 01-23-2013, 07:33 PM   #73121
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 921
Do these last for a while? I'm looking hard at those Mezteler Unicross tires too...thanks!
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 01-23-2013, 07:39 PM   #73122
shaddix
Oddometer: 647
Wow yeah all the wires are burned up and frayed. I unplugged something now the headlight won't com on anymore. I will have to read up. Looks like this is gonna suck lol. I was about to sell it too
Ugh wiring harness 300 bucks really? I think I should take it to a dealer
shaddix screwed with this post 01-23-2013 at 07:48 PM
Old 01-23-2013, 07:48 PM   #73123
shu
Oddometer: 999
Smoke? Under the tank? I've smelled that before. In this case it was from an F650 Dakar. We put it out with our water bottles but not in time to save the bike.
somewhere in Uzbekistan
http://www.advrider.com/forums/showt...r+2010&page=15
Time to get some help from someone who knows wiring.
..............shu
shu is offline   Reply With Quote
Old 01-23-2013, 07:50 PM   #73124
shaddix
Oddometer: 647
..............shu
Yeah it looks something like that lol
Old 01-23-2013, 08:14 PM   #73125
ER70S-2
ER70S-2's Avatar
Oddometer: 6,296
Wow yeah all the wires are burned up and frayed. I unplugged something now the headlight won't come on anymore. I will have to read up. Looks like this is gonna suck lol. I was about to sell it too.
Have there been any wiring modifications to your bike? The dealer will be glad to see you.
..............shu
Holy sheeeeeeeeeeeeeeettttttttttttt!!!!! My heart would stop if I saw that mess anywhere near home. But somewhere in Uzbekistan!! Bimmers suck. Glad it wasn't on a DR, my nightmares would start tonight.
I am, however, on shedule to leave for Kalifornia on Friday.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
