01-18-2013, 06:54 PM
#73126 | |
Oddometer: 598
PC site
I am surprised that I can get the notice my order has shipped and then I remember what else I was going to order... the next time I placed an order. ![]() While you are upgrading, or for your site upgrade list, I can find different universal items that are listed under other bike listings but not on the DR650 list. The only one that comes to mind now is the ProGrip Rally Grips. I found them when I was ordering for my TW200. I have the Rally Grips on one bike and I want to get them for my other bikes. Next time I place an order......
Attitude ~ The difference between Ordeal and Adventure James |
01-18-2013, 06:57 PM
#73127 |
Oddometer: 2,556
There is an advantage to the balky navigation: I can still make my house payments.
01-18-2013, 07:06 PM
#73128 | |
Mostly Harmless
Oddometer: 1,707
I do wish they stocked more stuff for the KLX250S though. :) Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
01-18-2013, 07:57 PM
#73129 |
Oddometer: 2,556
There was a question about removing the idle fuel screw plug over on DRRIDERS.com. I posted a link to Jessepitt's photo essay on the procedure: http://www.advrider.com/forums/showp...5&postcount=71
I got this response, thanks Jesse. ![]() Jessepitt should do a manual for us rookies. These photos are fantastic!!!! This is the definitive answer to "THE CAP OVER THE STOCK NEEDLE ADJUSTMENT SCREW." Even I can do this now!!! If you don't understand this. You might seriously consider taking the bike to a shop or have someone show you.
2004 DR650: 46,358 miles of ![]() ER70S-2 screwed with this post 01-18-2013 at 09:51 PM |
01-18-2013, 08:05 PM
#73130 | |
Oddometer: 276
#73131 | |
Oddometer: 181
18inch long piece of black 3/4inch I.D. pipe threaded on both ends 4inch long piece of black 3/4inch I.D. pipe threaded on both ends 1 90 degree elbow A threaded brass cap 1 1/8inch flat to flat. Which looks like this: http://s3.pexsupply.com/images/produ.../c74-147-1.jpg |
01-18-2013, 08:20 PM
#73132 | |
All Hail Seitan!!!
Oddometer: 5,561
I was looking for specs on the stock DR camshaft versus some of the Web grinds and Google sent me to the Pro Cycle page. Got me the info I wanted, so thanks
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966 |
01-18-2013, 09:26 PM
#73133 | |
Oddometer: 1,607
Some day we'll have some separate pages for our favorite general items.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
01-18-2013, 09:37 PM
#73134 | |
Oddometer: 1,607
I'd love to be listing more stuff for the KLX. At this point we don't have anyone on staff that owns one. I've found it takes having one of the crew owning and riding a particular model to be able to jump in with both feet and work up a complete offering. Yeah, another thing on my 'some day we're going to do that' list.
01-18-2013, 09:49 PM
#73135 | |
Oddometer: 2,556
01-18-2013, 09:51 PM
#73136 | |
on the road o'dreams
Oddometer: 5,382
stabilize fork on bench or whatever (or have a helper hold it) insert correct hex/allen key into damper rod bolt at bottom of fork . Have someone hold Allen in place ... now Whack it with a hammer! (counter clock please!) Do NOT hit your helper with hammer! The sudden shock can usually break loose the Damper rod bolt from the damper rod ... without it being held from the inside. Worth a try. If not ... try the above tool. Also, an air wrench can also work on this same principle. I've done the lazy man's method three times on my DR with success. TIP: when you put it back together do not OVER tighten bolt into damper rod and don't use Loc-Tite. NOTE: This may not work for KYB forks built on Tuesday by that grouchy guy who over torques everything that passes by. My forks were built by a cute 17 year old girl on a Friday. Gentle hands! Adv Grifter screwed with this post 01-18-2013 at 10:15 PM |
01-18-2013, 10:23 PM
#73137 | |
Oddometer: 1,110
1) It is likely that the drill will pull itself into the fuel screw when it breaks through the far side of the plug. The result can be just a little nick, mostly ruining the head, or somewhere inbetween. The way to avoid this is to use a drill stop, which, when properly set, will prevent the drill from going any further when it breaks through. 2) I've seen quite a few cracked/broken fuel screw wells. These are the result of the plug cocking as it is being pulled out. The way to avoid this is to tap the hole (I use a M4X.7 tap, which takes a 3.3mm or #30 drill). Grind the point off of the tap (if it has one) for clearance with the head of the fuel screw. Tap only deep enough to get through the plug. Then use a metal tube with squared ends and an ID just larger than the OD of the plug in conjunction with a screw and a washer with the same or larger OD than the tube as a puller to extract the plug. This way it is guaranteed to come out squarely. 3) Shimming the needle clip richens the mixture by lowering the slide rather than by raising the needle (except when the slide is against either stop), as the shim increases the preload on the slide spring. Regards, Derek |
01-18-2013, 10:50 PM
#73138 |
Oddometer: 425
Got back from Death valley on my DR and loved my wolfman/ramount/teknic/kolpin gear...
if any of you fellow riders want anything let me know...ill hook you up!
Pm me with what you want, Hooking up the adv community since 2010 Adv discount on all brands www.motoclubhouse.com www.route66moto.com moto rental/sales and tours, location et vente moto, import-export |
01-18-2013, 11:00 PM
#73139 |
Dirty Old Hippie
Oddometer: 868
01-19-2013, 01:19 AM
#73140 | |
Armature speller
Oddometer: 6,769
No-one has them
