01-19-2013, 01:57 PM
#73171 | |
Armature speller
Oddometer: 6,777
01-19-2013, 02:12 PM
#73172 | ||
ride2discover
Oddometer: 3,180
I have something similar on both bike & never use anything else but foam grips.
http://www.amazon.com/BikeMaster-170...ords=foam+grip
DR-Z400E 00 - DR650SE 02. Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY". |
01-19-2013, 02:20 PM
#73173 | ||
Oddometer: 1,658
01-19-2013, 03:17 PM
#73174 |
"Moto therapist"
Oddometer: 373
I suspected as much. I'll just ride it this season and see how it does. Mine has been really trouble free and I can't complain about a little bit of smoke. I would love an excuse to do the high compression kit or the 725 kit though!
Tim |
01-19-2013, 03:18 PM
#73175 | |
Oddometer: 1,129
Remember that the needle is attached to the slide, so raising the slide for a given intersection of throttle position and rpm means raising the needle. If the slide were higher than is needed to simply match the butterfly opening, then the mixture would be richened from the needle being out of the emulsion tube further while the airflow was limited by the butterfly. Regards, Derek |
01-19-2013, 03:47 PM
#73176 | |
Oddometer: 1,129
The idle mixture screw is already adjustable. If you mean an extended one, I consider those the optional, depending on how much altitude variation the bike will see. What pilot and main jet sizes to use will have to be determined. Regards, Derek |
01-19-2013, 03:51 PM
#73177 | |
Oddometer: 1,129
Regards, Derek |
01-19-2013, 04:13 PM
#73178 |
Oddometer: 599
I had a Chevy S-10 pickup that started doing that at about 50000 miles. I sold it with 217000 miles on it and the engine still didn't use a qt between oil changes.
01-19-2013, 06:36 PM
#73179 |
Asperger
Oddometer: 2,052
Race Tech Emulators and Rear Shock Shaft Assy
FYI, suspension, gearing impressions.
Got my bike back this afternoon from a local suspension guru and nothing is spewing fork/shock oil! But, even better than that is the way the bike feels. It sure doesn't ride like a DR650 anymore, at least nothing like a stock one. I may have gone a bit too stiff with the springs (.70 front and 8.1 rear), I'm still figuring it out. It's a relatively stiff ride, but the fact that it doesn't bounce around on wash board is phenom. I need to find a place that's significantly more rutted or wash boarded out because most of the stuff around here has a nice layer of new gravel over a frozen layer of dirt, but the dirt roads nearest my house are completely different to ride with the new suspension. I just wanted to post this for those on the fence about upgrading the suspension. It probably doesn't matter what you do as an upgrade, it's probably all for the better, but if you go all out and get new springs and emulators and a rear shock with adjustability, I think you'll be surprised at how different your bike will feel and perform. BTW, I also changed the front and rear sprockets (one down in the front, one up in the back). I guess it's got to be about an 8 or 9% change and it has made a pretty good difference, and definitely not too low for around town, commuting and gravel roads. I lost a little top-end, but I didn't use it anyway (over 5k miles and it's never been on an interstate).
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
01-19-2013, 06:45 PM
#73180 |
Oddometer: 920
Good to hear, Ace. Suspension mods went right to the top of my list for any bike after doing them on the DR. Like a different bike and as you said - planted - feel.
Congrats.
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... |
01-19-2013, 06:50 PM
#73181 |
Asperger
Oddometer: 2,052
I wanted to have it a year before modifying (much) it so I didn't get caught up in buying stuff that I ended up not liking, and so far I'm really liking the new mods. I'm really surprised at how the new bars seemed to have eliminated the buzz too.
All that's left, in the short term are the new Barkbusters and bar ends. It almost rides like a dirt bike in the dirt now
01-19-2013, 06:51 PM
#73182 | |
Mostly Harmless
Oddometer: 1,713
Question -- you mentioned adjustable rebound. Is this on the rear shock? If so, how'd you get that with the Shock Solution kit? I'm starting to seriously consider that instead of the Cogent route because of cost difference... $289 vs $600. Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
01-19-2013, 06:54 PM
#73183 |
Asperger
Oddometer: 2,052
If you look at the item just above the shock solution kit you'll see the shock shaft assembly. It's basically the same thing as the Cogent. Although I'm not completely familiar with the Cogent, it was explained to me the Race Tech shock shaft assembly is better (I'm not saying it is, it was explained to me to be better).
01-19-2013, 06:56 PM
#73184 | |
Oddometer: 181
01-19-2013, 08:21 PM
#73185 | |
Oddometer: 604
Shocking1
It is a great budget rebuild improvement but is not in the same league. The Cogent rebuild kit is $295 if you can do it yourself (spring NOT included) and it gives you full adjustment. Or for $399 you can have them rebuild yours for you (again, spring is extra) Their optional Mil spec coating is not required and you don't get that with any other rebuild so don't add that $ to the Cogent cost. So, the bottom line is that if you want the best, you want full adjustment, comp & rebound, and if you need a different spring, the Cogent costs under $500 and they do the work, or you can spend $498 for the Shock Shaft assembly and you do the work. Kinda seems like an easy decision to me...
Attitude ~ The difference between Ordeal and Adventure James |
