01-19-2013, 08:31 PM
#73186 |
Awesometown
Oddometer: 320
2.75 Sun
'76 Xl250 '04 XR250R '09 DR650 '10 TR450 |
01-20-2013, 01:28 AM
#73187 |
exile730
Oddometer: 59
workshop stands
I have only recently purchased my bike so I was wondering what maintenance stand would suit me best for general tinkering.
I picked this up from Supercheap for $149 and I think it works well ![]() ![]() ![]() ![]() It made the chain adjustment and lube really straightforward. It was easy to spin the bike and move it around as needed. I also took off my frame guards and cleaned up under there. It was filthy as and well worth the effort. I had also taken off and cleaned up my bash plate when I did the oil change - again well worth it. I have put a zip tie on my side stand switch and that saves some hassle - the side stand pivot has been cleaned and lubed, too. I worked out what chain and sprockets the PO had installed. It turned out to be a 525 with 14F and 41R. I am thinking of going for a 42R and a 15F and 16F to cover the options. What do you think? Anyone else got a different fave workshop stand?
It's always good to be out .... Western Australia |
01-20-2013, 02:27 AM
#73188 | |
Oddometer: 214
Have fun.
Currently riding DR650 (2011) Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
Thumper Dan screwed with this post 01-20-2013 at 10:21 PM |
01-20-2013, 03:08 AM
#73189 | |
Oddometer: 40
Cheers Richo. Swan View.
It's all good fun until someone gets hurt......... then it's hilarious!!! |
01-20-2013, 03:36 AM
#73190 |
Oddometer: 3,502
Rally Grips
'08 DR650 |
01-20-2013, 06:42 AM
#73191 | |
Life behind "Bars"
Oddometer: 6,246
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
01-20-2013, 08:56 AM
#73192 |
Asperger
Oddometer: 2,047
I have been told the Race Tech unit has a larger diameter shaft than stock and therefore more bearing surface area. Other than that, I'm not sure how the Cogent differs from Race Tech.
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
01-20-2013, 09:25 AM
#73193 | |
867-5309
Oddometer: 2,528
http://www.racetech.com/page/title/S...t%20Assemblies http://www.advrider.com/forums/showp...76&postcount=1
DO WHAT YOU LIKE - LIKE WHAT YOU DO Explain to me again why enjoying life when I retire is more important than enjoying life now? |
01-20-2013, 09:35 AM
#73194 | |
recycle crime scene tape
Oddometer: 399
~DR 650~ Upgrades: 1. dented tank |
01-20-2013, 11:02 AM
#73195 |
Oddometer: 74
Sweet looking ride and I love the low front fender. Wait a minute, an English wheel in the background..........Did someone say talent?
01-20-2013, 11:26 AM
#73196 |
Oddometer: 2,483
With about 7500 miles on the beast today I changed out the rear and front brake fluid.
Here is about the first inch-worth's of fluid coming out of the front... ![]() Hope I put newer fluid in it in time to prevent the front from seizing up too soon.
"After reading through this thread I've come to the conclusion that more people cruise the internet looking for reasons why X bike won't work in Y scenario rather than actually riding their motorcycles." -- RyanR |
01-20-2013, 11:29 AM
#73197 |
Oddometer: 399
I've taken flak for the fender & a lot of stuff I built for my DR, but I don't give a shit it's the way I like it
01-20-2013, 11:56 AM
#73198 |
Kool Aid poisoner
Oddometer: 4,823
Anyone know what the thread pitch is on the header bolts?
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
01-20-2013, 12:04 PM
#73199 |
Armature speller
Oddometer: 6,766
01-20-2013, 01:02 PM
#73200 |
Asperger
Oddometer: 2,047
Could be. I went slightly less than Race Tech recommends and the guy that set up my suspension mentioned the stiffness of the springs, but he followed up by saying that he thought I was right to put in significantly stiffer springs. He said many of the people who bring him suspension work refuse to believe they should be running spring rates as high as they should, so they change the compression/rebound and run springs too soft for the weight they are running (either their body weight or how the pack the bike), or their style of riding. So, bottom line is I figured the springs are pretty cheap and I might as well use Race Tech's recommendations as a starting point. I'm not sure it's right or will be over time, but with the small amount of riding I've been able to do since yesterday, the bike feels very well balanced over rougher terrain. It definitely feels like the front and rear are working together as opposed to feeling front and rear separately (I used to feel the front and then the rear when going over terrain; whereas, it now feels like one fluid movement). I think the rebound is much much better.
