Old 01-20-2013, 07:57 PM   #73216
JagLite
JagLite's Avatar
Oddometer: 617
Cool2
Originally Posted by trailrider383 View Post
The $498 includes a new spring. If you get the shaft assembly only from Racetech it's $399.99 minus %15 = $339.99
http://www.racetech.com/page/title/S...t%20Assemblies
http://www.advrider.com/forums/showp...76&postcount=1
Yes, and if you noticed in my post, the Cogent shock shaft assembly without spring is only $295.
Still a better deal than $339.99.
I do not know what the differences are between the Raceteck and the Cogent assemblies are.
Since Cogent is an authorized Racetech shop, they would be able to explain the differences.
One big advantage is that Rick at Cogent rides a DR650 so he knows the bike well.
Either way you can't go wrong, they will both make a huge improvement over stock.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 01-20-2013, 08:36 PM   #73217
neo1piv014
ADV in training
Oddometer: 610
Originally Posted by motolab View Post
Yes.It's good that some force is required to get the spacer all the way against the clip. This will help prevent the needle from spinning during operation, which otherwise causes needle wear (see the needle on the left here: www.moto-lab.com/gallery/view?itemid=306).Leave it out.Indeed.
Remind me though, how many miles are there on the carb, and have you already inspected the slide guide, emulsion tube, slide and float needle for wear/damage?
Regards,
Derek
As of today, there's 12,445 miles on the bike, and I'm assuming that the factory carb is the one on there. The PO had stated that he put a DJ kit on the bike, but the needle definitely wasn't a DJ needle. The plug for the mixture screw had been removed, and the airbox had been opened up, however, so something had been done to it. I didn't notice anything that immediately stuck out as being worn out compared to the pictures on the BST Bible thread, but I've also not seen any brand new ones in person either.
Assuming I get the spacer forced up to where the the clip is, I would raise the clip position to lean things out a bit, correct?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-20-2013, 08:40 PM   #73218
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,135
Since Cogent is an authorized Racetech shop, they would be able to explain the differences...
I just measured the Race Tech shock shaft assembly and it is larger in diameter than the stock shaft. I was told that before buying, but didn't know until I measured it myself. So, it's a larger, stronger shaft with more bearing surface. I don't know what other difference(s) there might be.
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is online now   Reply With Quote
Old 01-20-2013, 08:49 PM   #73219
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,496
Originally Posted by Thumper Dan View Post
Actually, I've got the exact same one and find it great. I saw it on special for $99 a few months back but nonetheless is still worth the $150. I can actually move the bike around whilst its jacked up, up have never had an issue of it toppling off. Great for turning the bike around!
Have fun.
Originally Posted by Tyrepower View Post
That looks shit hot exile730, now all you need is a Safari tank, some Wolfman racks, Wolfman Saddle bags and you will be ready for the Canning Stock Route in July....
Cheers Richo.
Swan View.
Thumper Dan and Richo ... waste of band width to quote back all the photos from the original post. We've all seen them ... no need to RE-POST them.
Might I suggest you go back and EDIT them out of your posts?
Bad internet manners. Leave the pics OFF on replies ... especially when they are 4- X Large ones.
Cheers!
Old 01-20-2013, 08:54 PM   #73220
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,615
Originally Posted by canoli View Post
What are you using to flush/bleed the system and how long did it take? Local dealer wants $99 p/hr for service and I'm not about to get ripped off so I was going to try and do this myself.
Thanks,
Canoli
Like Jaglite just said... it's too easy for that if you know to just not let air get into the system.
The only tools I used were the vice grips to loosen the bleeder screw, and some old piece of clear tubing/hose I found to guide the dripping fluid down into a oil catch pan (and to keep the fluid off of the rotors).
The rear - bleeds itself. Unbolt the rear brake reservoir to have easy access, loosen the bleed screw until it's dripping out, and just keep adding fresh fluid in the resevior to make sure it doesn't get low enough to suck air in. Toward the end tighten up the bleed screw/bolt/nipple, then top off the fluid and replace the reservoir.
The front - it wouldn't all just gravity-drip out, so I would pump the brake lever with my left hand while loosening and tightening the nipple/bleeder with the right hand to push old fluid out (the brake lever pushed the fluid out, close the bleeder, pump the lever, loosen the bleeder, hold lever down, tighten the bleeder, repeat a bunch of times).
Really only took the minutes that Jaglite says it does.
I used blue loctite on the two front top reservoir screws as an anti-seize since I have had those screws seize on another bike of mine (and since I couldn't find my real anti-seize), and ... ooh yeah ... most imperative - blue loctite on the 10mm bolt that holds the rear reservoir on since it was way loose! It would have fallen out soon.
It takes probably 15 minutes, total, from gathering the tools to finishing it up. Pay me ... $50 and I'll do it for ya
That's damned near a 49.5% discount!
for more of an idea of all my special bleeder tools, here is a shot of the rear while it was gravity-bleeding itself:
Here the vice grips that I used on the bleeder are gently holding the tubing down to keep the tubing's end from falling out of the catch-basin. I didn't want brake fluid on my walk way.
"After reading through this thread I've come to the conclusion that more people cruise the internet looking for reasons why X bike won't work in Y scenario rather than actually riding their motorcycles." -- RyanR
Mambo Dave screwed with this post 01-20-2013 at 09:02 PM
Mambo Dave is offline   Reply With Quote
Old 01-20-2013, 08:59 PM   #73221
Adv Grifter
Oddometer: 5,496
Originally Posted by Rob.G View Post
New question... how do you guys go about deburring these holes? I got 'em all drilled, but now they have sharp edges, which the instructions say are a no-no.
I have a Dremel... suppose I could use that.
Rob
I used a Rat tail file and emery cloth. It takes a while. Make sure you clean all metal debris out. Rinse out well.
Old 01-20-2013, 09:15 PM   #73222
motolab
motolab's Avatar
Oddometer: 1,146
I would definitely recommend verifying that the depth of the indentations concentric with the bore in the bottom corners adjacent to where the slide bottoms are still at least .010" deep. If they are not, the emulsion tube is at risk for wear, which will cause an excessively rich mixture at low to low mid rpm.
Has the slide lift hole area been increased by drilling? If so, slide guide, slide and emulsion tube wear will have accelerated as a result.
Measuring the the indentations concentric with the bore in the bottom corners adjacent to where the slide bottoms is key.
After having verified good slide guide and therefore emulsion tube condition, float needle condition, correct float height, and correct main jet size, yes.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-20-2013, 09:34 PM   #73223
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 2,570
I think one difference is the Racetech assembly has their Gold Valve.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 01-20-2013, 09:47 PM   #73224
canoli
human
canoli's Avatar
Oddometer: 1,157
Awesome! Thanks Dave and Jaglite. I'll take care of it this weekend.
Canoli
canoli is offline   Reply With Quote
Old 01-20-2013, 10:22 PM   #73225
Thumper Dan
Oddometer: 225
Cheers!
Well actually, I've seen it more times than not on this forum so didn't bother! Its not really bad Internet manners per se, just more an inconvenience. As such, I've edited.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
Thumper Dan is offline   Reply With Quote
Old 01-21-2013, 12:15 AM   #73226
Chill
Chill's Avatar
Oddometer: 81
Clarke Gas tank cap
Does anyone know if there is an issue with the Clarke gas tank caps? Mine's only 4 months old but is cracking across the top through the logo. I did a google search and there seems to be a few letting go but none in the same way mine is. I'm sure they're a good company and I could get a replacement if I hassled them but probably will have the same problem again in a few months time. I'd rather fix the problem once and for all. Are these caps a generic fit? Will any aftermarket MX type cap fit or are they brand specific?
Chill is offline   Reply With Quote
Old 01-21-2013, 05:58 AM   #73227
tbrduc
Oddometer: 1
Old DR?
Hello,
it seems that this thread is about 'newer' DR's.
Mine is a '92 and as you know, different in many ways.
I tried searching for older models but the search engine here wasn't helpful
Where can I find data here on the older models?
It's basically stock, except for a JE piston, tires and airbox-jet modes from Uncle Jesse.
thanks.
tbrduc is offline   Reply With Quote
Old 01-21-2013, 06:02 AM   #73228
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,046
Originally Posted by tbrduc View Post
Hello,
thanks.
http://www.advrider.com/forums/showthread.php?t=61568
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 01-21-2013, 06:19 AM   #73229
mrprez
KJ4WMZ
Oddometer: 1,263
Send a message via Skype™ to mrprez
Originally Posted by acesandeights View Post
Yes, it's stiff in fact, but doesn't feel like it's riding on the spring. That's how it felt in stock form like it was riding solely on the spring.
I rode again today and went over a little dirt jump the kids around the neighborhood use on their bicycles. I didn't jump it due to all the mud, just up and over a few times as if it were "whoops". My bike follows the terrain really well. Both tires stay planted to the ground. I know what you mean by the pogo because that's what my stock suspension felt like, but a really soft pogo stick. Now it's a stiffly, firmly planted, completely connected to the ground feeling. I'm still not sure whether it's a little too stiff, but I'm almost thinking riding for the last 18+ months with the stock suspension has made me forget what a good set up should feel like. Mine feels like the compression is stiff and the rebound just sticks the bike to the ground...no pogo. Hope that helps. BTW, when are the tires coming again!?
I just checked the sag, it is more than it should be so I'll add in some more preload and see what gives give. I'd like to get this to ride somewhat like my DRZ did.
Tires? Probably sooner than you'd think!!!
How's the coffee?
John
Sent via morse code
mrprez is offline   Reply With Quote
Old 01-21-2013, 07:57 AM   #73230
acesandeights
Asperger
Oddometer: 2,135
Originally Posted by mrprez View Post
How's the coffee?
John
Gone
Times are GMT -7.   It's 08:41 PM.
