Old 01-28-2013, 04:59 PM   #73231
Feelers
Oddometer: 189
Originally Posted by TRAVELGUY View Post
As always, thank you Eric. Your post and input is always appreciated!!!
TravelGuy
In attempting to raise the bar, I just want to point out that his name is Derek... not Eric...
Feelers is offline   Reply With Quote
Old 01-28-2013, 05:08 PM   #73232
GSF1200S
Oddometer: 976
GSF1200S is offline   Reply With Quote
Old 01-28-2013, 05:46 PM   #73233
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
Best material to use on the skid plate to quite the vibration it makes and noise it focuses up into the bike???
Thinking the stick on sound deadeners panels where it does not touch the frame. Or a spray on line-x on the bottom underneath surface too??? how about that spray on under car body sound deadener??? the black stick stuff?
thanks, bill
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 01-28-2013, 05:51 PM   #73234
rpet
Awesometown
rpet's Avatar
Oddometer: 820
thanks, bill
This is going on the inside of my plate later this spring. Cheap DIY experiment... we will see how it works.
http://www.amazon.com/dp/B002MB6RIY/..._M3T1_ST1_dp_1
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 01-28-2013, 06:11 PM   #73235
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 854
Nsu
Today I wrapped up my series of upgrades and maintenance on the DR by locktite-ing new allen head screws in place of the originals on the NSU switch and did it without removing the clutch basket which wasn't all that bad, a little fiddley but fairly quick to do. Nothing new to add to this repair and of course the the screws were not even tight.
I feel like I dodged the bullet on this one and got by on dumb luck. I've owned this 07 for 2 years now and it has a total of 5,000 miles, much more and the screws would have fallen out. Shear laziness on my part for not doing it right away when I bought the bike. The reason for this post now is to encourage anyone like me who has put it off to do it sooner than later. It's an easy fix for something that can spell big trouble if you let it go.
Carl Childers is online now   Reply With Quote
Old 01-28-2013, 06:14 PM   #73236
GSF1200S
Oddometer: 976
Mine were so tight I had to use an impact drive to get them loose
The primary nut, however, was way loose and would have come off in time. Its amazing how much these guys vary unit to unit..
08 6700 miles when I did it
Old 01-28-2013, 06:15 PM   #73237
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 412
Mine has the spray-on liner, probably about 5 or 6 coats. It helps, but not as much as you would think. The skid plate is still too reflective for sound waves. It's not vibration noises, it's all the noises the engine normally makes that are being reflected up at you instead of towards the ground. At first I was trying to find things to quiet it down, finally decided it isn't a big deal and I just ignore it now. I would like to find a really porous foam (think stripper pad on a floor buffer) to put in there and will try it if I find one. I just don't want anything that will hold water, it still needs to drain well.
Tim
3DChief is offline   Reply With Quote
Old 01-28-2013, 06:54 PM   #73238
gofast1320
gofast1320's Avatar
Oddometer: 734
surging
I noticed what felt like surging at 55-60mph the other day. The bike is new to me but is a 2006 with less than 4500 miles on it. I've put about 200 miles on it while just running around locally over 3 days getting used to it.
If I drill out the eco/epa whatever block on that carb screw is there a set amount I need to back it out. Or do I screw it in and then put it back and add 1/4 or 1/2 turn to it? Thanks
gofast1320 is offline   Reply With Quote
Old 01-28-2013, 07:07 PM   #73239
Feelers
Oddometer: 189
thanks, bill
Mass loaded vinyl with one side with adhesive is your best bet.
Old 01-28-2013, 07:16 PM   #73240
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
This might work.
I used it to isolate my Pelican box from the rack I mounted it on.
Old 01-28-2013, 07:18 PM   #73241
cemory
cemory's Avatar
Oddometer: 55
I used dynamat that I bought at the local Best Buy store. They use it in cars to deaden sound from door and back dash speakers, etc. Here is just one link with some info on it. Best part is that you can trim to fit with scissors and then peel the paper off the self stick backing. I tried some spray on liner but I could never get it to stay on the aluminum skid plate. http://www.summitracing.com/parts/dyc-10415/overview/
Chris in Topeka
cemory is offline   Reply With Quote
Old 01-28-2013, 07:22 PM   #73242
motolab
motolab's Avatar
Oddometer: 2,775
That is pretty entertaining...
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-28-2013, 07:26 PM   #73243
motolab
motolab's Avatar
Oddometer: 2,775
What is the throttle position when the problem occurs?
Was the bike ever stored for any length of time?
The fuel screw should be used to adjust the idle mixture. It is not applicable to other openings.
Regards,
Derek
Old 01-28-2013, 07:49 PM   #73244
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
More details would help. Could be several things. Start with simple and cheap things:
1. Run some Sea Foam in your gas for a tank or two. (still surging?)
2. Drain tank, flush, remove petcock and clean fuel inlet filter.
3. Is the air box stock or modified? Is left side cover on bike?
The screw you're referring to is the fuel/air adjustment. Affects idle to one eighth throttle. Use a sheet rock screw to remove tin cover. It's UNDER Carb bowl, hard to see or reach. Rotate carb to gain access. Take sheet rock screw and poke into tin seal ... pull it out. Now you can remove the stock screw and add an extended fuel/air screw. Much easier to adjust with the extended screw.
Old 01-28-2013, 08:06 PM   #73245
GSF1200S
Oddometer: 976
Tim
I used a floor mat made out of closed cell foam sold at Lowes for workshops. While I was working on the bike a lady friend of mine cut out places for the frame rails to go. This mat is about 3/4 of an inch thick, and it sounds exactly the same as before I put the skidplate on.
I do have a question ive been meaning to ask here though- since the mat sits up against the engine, should I worry about it overheating some particular bearing surface somewhere near the bottom of the engine? I know DRs run cool, and I havent worried about it so far since its been cold enough due to winter, but what about summer? Im thinking I might drop the skidplate and remove the stuff and try some spray on stuff, but it sure is nice not hearing any new noises with the skidplate on..
Times are GMT -7.   It's 11:12 AM.
