Old 01-25-2013, 01:34 PM   #73321
procycle
procycle's Avatar
Oddometer: 1,614
Originally Posted by Foot dragger View Post
I bet it is,I was wondering how long a DR650 runs with 20 more HP then stock? Has anybody ran one very long?
Getting close to 2-1/2 years now. No problems whatsoever. The thing is, 98% of the time you aren't using any of the additional 20 HP. It sure is handy when I want to pass a truck uphill.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 01-25-2013, 02:37 PM   #73322
opium89
opium89's Avatar
Oddometer: 1,134
Success!
Parts finally arrived so....Pine-Sol dip, new main jet, new pilot jet, and new KTM needle and the hesitation off idle is now completely gone. Only issue I am having now is some pretty obnoxious decel popping at > 1/4 throttle. What I mean by that is the decel pop is minimal to nada if I don't get on the throttle much. It's only on decel when really opening it up that the popping starts to get bad.
In an effort to remedy, I tried adjusting the fuel screw, seem to improve a bit the wider it's open, but still present no matter what. However, it does go away if I throw the choke wide open...
I set the KTM needle on slot 3, right in the middle, as this puts the spacer at the exact same location as the stock needle. I gotta say, these needles look nearly identical to me. Is anyone with me in suggesting that I try raising the needle up a slot and see what happens?
Almost there.....
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Old 01-25-2013, 02:49 PM   #73323
shaddix
Oddometer: 648
Originally Posted by JagLite View Post
Yeouch!
I would buy a used harness (eBay, etc?) and change it yourself.
No need to get new keys that I can think of since the ignition wires plug into the harness.
Even if the wires connected to the ignition burned you should have enough to splice in new.
I know very little about wiring but replacing the complete harness with a new (used) harness is easy if you just do as suggested to unclip and reclip one at a time.
I am never happy with any work a shop does so I end up doing my own work though.
Just my 2c
I am gonna try it myself. I was trying to sell it and I was hoping the dealer could get it fixed quickly but 1300 is just too much.
shaddix is offline   Reply With Quote
Old 01-25-2013, 03:09 PM   #73324
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,343
Buy a kit, I'll help with the install, then ride it like normal so I can have a baseline for when I do the DR in my garage.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." -
Abraham Lincoln
Bigger Al is offline   Reply With Quote
Old 01-25-2013, 03:30 PM   #73325
crazy88
Oddometer: 8
Puke IMS Gas Cap Vent Tube
Ok, I get that this is apparently really necessary. I'm a complete noob, but I managed to successfully change my stock tank to an IMS, or so I thought... Seems to be fine except that when I put on the long vent tube on the gas cap, the engine doesn't stay idling for more than a few seconds. I take it off, make sure the other end of things is covered up, and my bike runs fine. So what's going on here? Should I purchase a shorter vented tube, or did I route some things up incorrectly?
crazy88 is offline   Reply With Quote
Old 01-25-2013, 03:44 PM   #73326
Thumper Dan
Oddometer: 226
Tm40
I bought my TM40 about 10,000km ago and everything seems fine with it. But wondering Is there any preventative maintenance for the TM40's - apart from changing fuel filters etc??
I've never actually pulled one apart and don't really want to unless its necessary. I know I wouldn't have to with 10km on it but what about 20k 30k, etc
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
Thumper Dan is offline   Reply With Quote
Old 01-25-2013, 03:57 PM   #73327
silverwolf
silverwolf's Avatar
Oddometer: 267
Sounds like you either didn't reconnect the vacuum hose on the petcock. There should be two hoses on it. or your vent hose is clogged. try blowing some compressed air through the vent hose.
silverwolf is offline   Reply With Quote
Old 01-25-2013, 04:13 PM   #73328
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,845
Or when you want to tow a truck uphill...
NordieBoy is offline   Reply With Quote
Old 01-25-2013, 04:15 PM   #73329
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 1,772
re: Everglades
Ever have to run from an alligator??
re: 780/790
Jeff's been running his hard for ages (like he just said) and it's fine. Adding 20 hp to an almost-40-hp motor isn't that big of a deal. I ran my WRX at 400 hp (224 stock) for four years and it was still running strong when I demodded it to get rid of the payment (since I ride 99% of the time).
re: Fork Solution Kit
I FINALLY rode my DR today after last weekend's Fork Solution Kit installation... .47kg springs and Gold Valves. WOW, nice improvement!! All I could do was ride asphalt and an unusually smooth stretch of "what used to be a gravel road." But the few bumps I did hit were much better controlled than before. Hey, to whomever it was that bought my Intiminators -- get the stiffer springs! I think they'll work better with something better than the stock sponges.
Rob
'96 Suzuki DR650
'10 Kawasaki KLX351S #320
'01 Yamaha FZ1
The Lane Sharing Works Blog
Rob.G is offline   Reply With Quote
Old 01-25-2013, 04:16 PM   #73330
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,845
It will pop on decel.
The BST carb has no coasting enrichener.
Tune for performance.
Old 01-25-2013, 04:23 PM   #73331
GSF1200S
Oddometer: 382
Originally Posted by CreativeEdge View Post
Picked up this bike about 2 years ago and absolutely love it. I'm a photographer and use it to
go into the Everglades here in Florida. I have the Pelican case on the back for my camera equipment and it has
worked out great.
I took out the snorkel, did the needle shim and the mixture screw...could not believe how much better it ran after these
simple mods.
Here's a pic from one of my rides into the Everglades
Here's a couple of the pics I got of the Endangered Florida Panther during my Everglades ride..
This is exactly what my DR was purchased for, though as it turns out I love offroading just as much as photography. Very nice pictures..
GSF1200S is offline   Reply With Quote
Old 01-25-2013, 05:15 PM   #73332
opium89
opium89's Avatar
Oddometer: 1,134
My other one doesn't pop much at all. You don't think tweaking that needle a bit might help? I find it curious that it all but goes away when the choke is opened up.
Old 01-25-2013, 05:26 PM   #73333
C/W
Oddometer: 47
That's because the choke is an enrichment circuit.
C/W is offline   Reply With Quote
Old 01-25-2013, 07:08 PM   #73334
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,503
Almost there.....
Two Things:
Raise idle
Go back to stock muffler
Old 01-25-2013, 07:28 PM   #73335
1989THEARK
1989THEARK's Avatar
Oddometer: 22
Thumbs down
Bram bram bram bram braaaaaam... Braaaam... Braaa(BOOM)
Evil 3rd gear strikes again
Originally Posted by Adv Grifter View Post
The DR650 motor is pretty under stressed, no? ... my guess is the bottom end can handle it OK. The Oil cooler being a big plus for handling the extra heat from 20 more HP.
My concern would be the trans ... and 3rd gear specifically.
Probably be fine if not abused.
Too few examples out there to get much feed back.
1989THEARK is offline   Reply With Quote
Times are GMT -7.   It's 05:18 AM.
