Old 02-14-2013, 07:50 PM   #73771
doug s.
Oddometer: 1,348
Originally Posted by dljocky View Post
Good call Rusty! Took the kickstand off, closed it up, and it's perfect now. I also rode by the local Ducati shop, spoke to their welder guy, he said it's an easy fix, about an hour labor TIG weld, but he said I didn't need it. I also took the bike to the local Suzuki shop, they said cosmetic also....Any thoughts?
Originally Posted by badweatherbiker View Post
mine looks worse than that, no worries
ther's a dent in my swingarm, about in the middle of the swingarm, where your gouge is. the p.o. obviously dumped the bike and the end of the sidestand made the dent. purely cosmetic issue, imo...
doug s.
doug s. is offline   Reply With Quote
Old 02-14-2013, 08:06 PM   #73772
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,045
DR650 side (gen 1 Wolfman style) and top racks for the DR in vendors:
http://www.advrider.com/forums/showthread.php?t=863252
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 02-15-2013, 04:12 AM   #73773
VBdiver
disconcerted
VBdiver's Avatar
Oddometer: 50
crankshaft access to adjust valves
I finally got the access plug off the crankcase housing ... what a PITA .
Somebody prior to me must have used something smaller than a 10mm Allen & wrung it out real good. I tried heat ,tapping , driving in a 10mm Allen , no dice .
I got it out using a chisel working it around the circumference & it thankfully came loose.
I don't see in my manual the proper torque settings for tightening the cover . Can anyone lend a hand ?
VBdiver is offline   Reply With Quote
Old 02-15-2013, 04:49 AM   #73774
planemanx15
planemanx15's Avatar
Oddometer: 1,009
I had the same issue yesterday!! I used a dremel and an impact driver. That didn't work so I used the dremel to cut all the way to the edge and used a chisel and heat. Replaced it with the warp 9 plug Procycle offers. I tightened it to 20 ft/lbs, and I'm sure that's over kill.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 02-15-2013, 05:08 AM   #73775
AC909
Great Job!
AC909's Avatar
Oddometer: 1,208
I may be a bit late to the tank pannier/bag conversation but here is the only thing I have found to work with my setup that doesn't hit my knees at all or hit me when I am standing.
Giant Loop Buck n' Roll
A CT175 & XR250R Do A Few States of the TAT
http://advrider.com/forums/showthread.php?t=827855
A CT175 & DR350 Do a Few More States of the TAT
http://advrider.com/forums/showthread.php?t=1010764
AC909 is offline   Reply With Quote
Old 02-15-2013, 05:26 AM   #73776
canuckAME
canuckAME's Avatar
Oddometer: 724
You might want to smooth and blend out the gouge so it has a nice smooth radius to it. Any sharp edges could lead to a crack starting from a stressed area which I imagine this would be.A needle file set and sandpaper would work in the aluminium which is fairly soft.
canuckAME is offline   Reply With Quote
Old 02-15-2013, 06:13 AM   #73777
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 782
Originally Posted by thumpididump View Post
Adjusting the preload will not make the shock stiffer or softer, rather, preload is used to set the ride height (sag).
If you're under 160 lbs, then the stock shock is pretty good, but offers no rebound damping adjustment which makes it hard to fine tune to your liking, and to suit the terrain and type of riding.
If you're over 160, then a stiffer spring will certainly help and a valve kit if you want better. Having 3-way adjustment is ideal but you would need to add a rebound clicker for that.
Sent from my Rotary Dial Phone using TapaTalk.
The factory manual has three recommended settings for prelaod based on spring height and they are refereed to as soft, standard and stiff, so I raised the collars to get the soft setting from the standard position. The whole thing puzzles me, most people refer to the shock as mushy and undersprung yet I found it way to stiff and harsh. I bought the bike bone stock with 1,500 miles on it from a mild mannered gentlemen so I doubt if he had the shock reworked. I weigh 195 lbs. without riding gear so that doesn't fit the norm either. No complaints though for whatever reason that one adjustement and the addition of intimators to the fork changed the whole level of ride performance to the bike........go figure??
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 02-15-2013, 06:15 AM   #73778
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,377
Nice work on the side covers. Maybe you could give some tips on how you made them. There has been a bit of discussion in the last 2 days about the high price of replacements.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 02-15-2013, 06:25 AM   #73779
shu
Oddometer: 1,028
Common wisdom around here is to loosen it when it's warm (the night before if you're setting valves and want the motor cold.)
I just put some antiseize on it and tighten it 'softly but snugly' by hand- no need to use a torque wrench. I haven't had any trouble with mine for 50,000 miles this way.
...........shu
shu is offline   Reply With Quote
Old 02-15-2013, 07:47 AM   #73780
AC909
Great Job!
AC909's Avatar
Oddometer: 1,208
That would be a $16.00 Hefty trash can and many hours work on fitment, cut, and design
Old 02-15-2013, 09:42 AM   #73781
bluegroove
Motorcycle junkie
bluegroove's Avatar
Oddometer: 445
20 ft lbs! You're gonna need the chisel again next time
I'd guess 10 is plenty.
Former Mechanic in Honda and Kawasaki Dealer (eons ago). 38 yrs. of riding and racing dirt and street.
bluegroove is offline   Reply With Quote
Old 02-15-2013, 01:37 PM   #73782
mmod
Oddometer: 28
Does that giant loop buck n roll just strap around the tank or to something else?
Looks like the side compartments would be a great way to carry a few water bottles
mmod is offline   Reply With Quote
Old 02-15-2013, 02:58 PM   #73783
biker128pedal
Super Lurker
biker128pedal's Avatar
Oddometer: 3,123
I have been looking around at DR thumpers and was wonder how long the chains and sprockets last. I got 35k miles on the Vstrom but it is a twin. So for 80 to 90 percent road how much worse would it be? Also the Vstrom cush bumpers were in good shape. How do the DRs hold up? I found a little info searching but see what the latest opinions are.
650s rule.
Wee Strommin along.
biker128pedal screwed with this post 02-15-2013 at 03:22 PM
biker128pedal is offline   Reply With Quote
Old 02-15-2013, 03:00 PM   #73784
AC909
Great Job!
AC909's Avatar
Oddometer: 1,208
Yep straps around the tank. It is a nice capacity for sure.
Old 02-15-2013, 03:02 PM   #73785
Rusty Rocket
Life behind "Bars"
Oddometer: 9,377
Originally Posted by biker128pedal View Post
I have been looking around at DR thumpers and was wonder how long the chains and speaker last. I got 35k miles on the Vstrom but it is a twin. So for 80 to 90 percent road how much worse would it be? Also the Vstrom cush bumpers were in good shape. How do the DRs hold up? I found a little info searching but see what the latest opinions are.
650s rule.
Speakers? That's what happens when you let the computer think for you.
I don't really know how long the chain and sprockets last if you do mostly road work. I get 5-6000 miles with a lot of offroad. My hub cushions were probably the originals when I bought the bike. They needed replacing at 10,000 miles and 10 years old.
2009 DR650
Times are GMT -7.   It's 02:23 AM.
