Old 09-23-2007, 02:32 PM   #7366
alprosound
HappyMan
alprosound's Avatar
Oddometer: 498
Main Jet Size
Originally Posted by CaptTurbo
Alpro, what size DJ main jet did you put in? Thanks.
It was 3:30 this morning and I've got to say my memory is a little hazy. I think it was a 155 per Jesse's recomendation but I'll need to go and check my kit to see for sure. I'll try to remember to post it for you later.
John
MN
06 Triumph Tiger
Suzuki DR650SE
Yamaha XT350
Suzuki DR 200
Yamaha TTR
Yamaha RT
Suzuki JR 80 and JR50
“Success is not final, failure is not fatal: it is the courage to continue that counts.” - Winston Churchill
http://ridedualsport.com
alprosound is offline   Reply With Quote
Old 09-23-2007, 02:44 PM   #7367
alprosound
HappyMan
alprosound's Avatar
Oddometer: 498
Cool2 Main Jet Size
Yes, I just confirmed that I went with the 155. It was simple to do and now that I've done it I'd like to play around some more when I get time. The bike runs great so I've no need to change it but I'd like to learn more through experimentation so when I can spare the time I'm going to try the 150 just to see what happens. Then I think my TTR is gonna get a re-jet too!
John
MN
06 Triumph Tiger
Suzuki DR650SE
Yamaha XT350
Suzuki DR 200
Yamaha TTR
Yamaha RT
Old 09-23-2007, 03:27 PM   #7368
rokhopr
2014 Beta 200
rokhopr's Avatar
Oddometer: 63
That needle jet clogs after you've cleaned the carb up, then use SeaFoam in the gas to keep it cleaned out. No amount of carb mods will help if the jets are dirty.
Originally Posted by DRDude
My DR is idling very rough.
It has about 2000 miles on it and is an '06. I have not done any engine mods to it, but have changed the front sprocket, springs and tank. I broke my hand riding so the bike sat for about 2 months. I was given advice on TT to take off the carb and clean it. Any one have any other ideas? Should I do the Jesse Dynajet mod or replace any screws since I have to take the carb off? any advice is appreciated. I'm a little pissed that it needs cleaning so soon.
Thank You
rokhopr is offline   Reply With Quote
Old 09-23-2007, 03:28 PM   #7369
svwayne
Oddometer: 945
Originally Posted by alprosound
I finally got 'em. Took a chisel to them and hammered them off. Thanks for all your help.
Geez I hope this mod helps.......
Sorry, I'm a little late to the party. If you look real close at those phillips head screws you'll notice a little dimple or punch mark located next to the phillips slot. That little dimple means that the phillips is a JASO, or some such jap specific, phillips pattern. A #2 or #3 US phillips will strip them suckers all day long. You did the right thing - chisel, vice grip, whatever, them off and replace with some socket head screws.
The DJ kit was the best $60 I ever spent on my DR.
P.S. Snap-on tools is the only company I've found that makes a screwdriver specific to the jap phillips.
svwayne is offline   Reply With Quote
Old 09-23-2007, 04:29 PM   #7370
CaptTurbo
CaptTurbo's Avatar
Oddometer: 1,099
Thanks for checking on that for me John. I'm very interested in following your experience with the rejet. Are you running the stock pipe?
I just found another problem with the second hand kit I just bought. The small washer is missing. I guess someone used the DJ150 and the washer from this kit. I hope this is the DJ needle and I think it is since it has six positions for the clip.
Can anyone tell me if I can find a substitute washer in a parts bin or hardware store that can be used? What size is it exactly? Pictures of it to show scale would be good. Thanks for any efforts.
"No Man's life, liberty or property is safe while the legislature is in session." --American lawyer, editor, politician, Judge Gideon Tucker (1826-1899)
CaptTurbo is offline   Reply With Quote
Old 09-23-2007, 07:08 PM   #7371
alprosound
HappyMan
alprosound's Avatar
Oddometer: 498
Cool2 No Problem....
I'm running the stock pipes. I'd love to change up but I could never live with the noise. Why can't they make a pipe with all the benefits and none of the noise? Laws of physics I suspect....
If you've got a used kit I wouldn't be suprised if you've got the stock needle and not the one that came with the kit. I know I put mine back in the kit for safe keeping. Just in case I'd need it in the future....or in other words I'll be throwing it out in a couple of years wondering why I hung on to it.
I think you can get a clip or washer elsewhere but I'm sure someone more knowledgable here can answer that for you. Have fun!!
John
MN
06 Triumph Tiger
Suzuki DR650SE
Yamaha XT350
Suzuki DR 200
Yamaha TTR
Yamaha RT
Old 09-23-2007, 08:43 PM   #7372
Juiceman34
Juiceman34's Avatar
Oddometer: 21
First picture posting
Let's see if this works. If it did work the ride was out on Mormon Well Rd north of Vegas.
Juiceman34 is offline   Reply With Quote
Old 09-23-2007, 08:48 PM   #7373
Juiceman34
Juiceman34's Avatar
Oddometer: 21
Talking Couple more
Old 09-23-2007, 08:51 PM   #7374
garymonster
Oddometer: 195
Couldn't have worked better...
Thought you were in AZ for a second. Great pic. I just got the black one myself.
garymonster is offline   Reply With Quote
Old 09-23-2007, 08:54 PM   #7375
garymonster
Oddometer: 195
Are those fairing brackets???
If so, please send pics later. thanks.
Old 09-23-2007, 09:06 PM   #7376
garymonster
Oddometer: 195
No sh*t, a Japanese phillips!
Well that helps. I was embarassed that I couldn't unscrew the tail light and was stripping the screws. And the damned thing was only screwed onto the plastic fender!
Old 09-23-2007, 10:46 PM   #7377
garymonster
Oddometer: 195
License plate bracket: Opinions please...
I would like to clean up my DR650's rear end as simply and cleanly as possible (without drilling holes etc.). There is a company that will produce metal items to spec at very reasonable prices provided more than 3 are ordered.
I want a simple aluminum bracket with one 50-55 degree bend that attaches to the existing 2 bolts under the fender. No mods needed. The lower part of the bracket (under the bend) is the shape and size of the license plate with 4 pre-drilled holes.
See Pic #1. This is a license plate holder with built-in LED available on the internet for $35. Available in chrome or black. Very clean looking. It would bolt over the plate and onto the bracket.
My question is: Will the stock wiring work with this as there will no longer be a red light, just the plate illuminator? Thanks in advance!
Old 09-24-2007, 12:11 AM   #7378
Top Bloke
Porky Rider
Top Bloke's Avatar
Oddometer: 111
Yup.
I made up my own bracket from scrap laying around the shed and whacked a 3 led licence plate light from fleabay on. The wiring on the LED's is absolutely tiny due to the minimal current draw and works like a beauty.
Name:  rearguard 023 (Small).jpg
Top Bloke is offline   Reply With Quote
Old 09-24-2007, 12:28 AM   #7379
garymonster
Oddometer: 195
Right ON.
Attachment 135579
That's what I'm talking about. There should be more aftermarket mods for the DR650. BTW your plates are huge compared to the US.
Old 09-24-2007, 12:39 AM   #7380
garymonster
Oddometer: 195
Howdy Bloke from Phx AZ...
Attachment 135579
Could you give us some detailed info about what you did to make this???
Times are GMT -7.   It's 06:51 PM.
