Old 02-21-2013, 02:54 PM   #73966
FlowBee
Just me.
FlowBee's Avatar
Oddometer: 5,754
Originally Posted by shaddix View Post
I am having an issue with the starter button on my 09. Sometimes the button doesn't do anything, it acts like the kickstand is down and in gear, but the kickstand won't be down and it will be in neutral. I try feathering the clutch a bit to see if maybe it's that switch but it just seems to be random..... Is this a common issue with an easy fix?
You might also try disconnecting the sidestand immobilizer switch to see if that helps. Your nanny government in cooperation with personal injury lawyers mandated these to protect you from yourself. Once disconnected you will discover the freedom to start the bike and let it idle on the sidestand.
"And then this one time at banned camp ....."
FlowBee is offline   Reply With Quote
Old 02-21-2013, 03:10 PM   #73967
Icecold Dan
Oddometer: 583
Thanks for the response Escaped. I did remove the plates and as I said they appeared fine. I'll take your advice and put it all back together and see if that solves it.
Dan
"Travel is fatal to prejudice, bigotry, and narrow-mindedness, and many of our people need it sorely on these accounts" -Mark Twain
Icecold Dan is offline   Reply With Quote
Old 02-21-2013, 04:51 PM   #73968
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by dljocky View Post
Thanks Rusty,
Flowbee, I'm new to learnng how to work on bikes, and if I had a chain problem out in the wilderness, I might not know exactly how to fix it, but I at least want the right tools!
More suggestions please.
Over time/miles I've gained 100% confidence that a chain problem is unlikely. The key is having a high quality, properly adjusted chain to start with ... and properly installed Rivet link. In nearly 200,000 miles I've not broken a chain or had a Rivet link fail ... or seen one break in my group of riders.
Got a cheap, worn out chain? Got worn crappy sprockets? Using a poorly installed Clip Type link? In that case you are on your own. Proceed at your own risk.
Carrying a proper chain cutting tool is extra weight I can do without. That said, I do carry a spare master link ... clip type. That is an old habit left over from the "Bad Old Days" of riding ... before Rivet links and DID X Ring chains.
Keep your chain clean, lubed and adjusted, change your sprockets before they are worn out and use a good quality chain.
... you should be just fine.
Old 02-21-2013, 04:56 PM   #73969
Adv Grifter
Oddometer: 6,128
Flood switch with WD40 ... DO NOT disassemble.
Old 02-21-2013, 05:05 PM   #73970
dljocky
Oddometer: 868
Thanks for the input folks. I've had good luck also with chains Adv grifter and I carry 1 spare master link. Bergdonk, that is a nice little tool. I wonder if anyone in the states carries something like that?
dljocky is offline   Reply With Quote
Old 02-21-2013, 05:06 PM   #73971
Adv Grifter
Oddometer: 6,128
Originally Posted by FlowBee View Post
I recently bought a Motion Pro PBR press tool kit for inclusion on the DR for out of state trips. Dead weight, yes, but I'll admit I'm relatively newish to chains - my last chain driven bike was a CBR1100xx and I didn't take that thing on long trips.
Can you elaborate a little on what you mean by this? Do you then mount it like a clip and wire it?
Thanks.
Chains are night and day better since your 80's CBR Honda. Chains were a disaster back then ... lucky to get 5000 miles out of one.
I'm on my 2nd DID 525 VM-2 X-Ring Chain. First one did 25,000 miles and could have gone another 5K miles if needed. I've used this same chain on previous V-Stroms and Tri Tigers. Excellent. DID now make a new generation X ring chain ... I have not used one yet ... but I'm betting it's a good, long lasting chain like the VM-2 was.
IMHO, no need to wire anything or screw around with clip links. A well done Rivet link is the way to go.
Old 02-21-2013, 05:24 PM   #73972
procycle
procycle's Avatar
Oddometer: 2,403
The CBR1100XX was sold from 96-'07. Not any more antique than a DR650
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-21-2013, 05:59 PM   #73973
Adv Grifter
Oddometer: 6,128
Right, A BlackBird. Should have mentioned that right off ... Sorry, I was thinking 80's CB1100F.
http://www.bikez.com/motorcycles/hon...100_f_1983.php
Remember those?
Old 02-21-2013, 06:08 PM   #73974
sandwash
sandwash's Avatar
Oddometer: 1,366
Originally Posted by NYTrainer View Post
Mine did the same thing for a few times, then quit working altogether at the worst possible time. It is a poor design as the "button/lever" hangs down in harm's way. Check the kill switch & all connectors, if it then does not work consistantly, buy a new one!
Or you can buy a momentary mini switch from Radio Shack,fits inside the housing.
97dr650
sandwash is offline   Reply With Quote
Old 02-21-2013, 06:16 PM   #73975
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,517
Yeah, I started back when many bikes had 428 chains. Last several times my chain tool was used, it was for someone else.
Just like the mini jumper cables I carry. I'm like AAA for woods bikes.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 02-21-2013, 06:52 PM   #73976
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,276
OK, so ride behind Russ for free parts with phone numbers when they fall off. Ride in front of Russ when I might break and need tools. Got it
BTW I remember either you or GotDirt pulling out some tools and hardware once for something and one of you had some half links that were pretty cool to use in a jam.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 02-21-2013, 08:20 PM   #73977
ER70S-2
ER70S-2's Avatar
Oddometer: 6,884
Amen to that.
Mine starts and idles on the sidestand. (but it wouldn't when the NSU was unplugged)
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 02-21-2013, 08:44 PM   #73978
Chill
Chill's Avatar
Oddometer: 325
Originally Posted by Icecold Dan View Post
When the light turned, the bike wouldn't move. I got it into neutral and pushed it to to the nearest sidewalk. I thought at first that I had thrown the chain, but when I opened the front sprocket cover, I found that the chain was still in place.
So when you went to pull away did the revs drop as you let the clutch out (something locked in the transmission) or was it like it was in neutral (clutch not engaging)?
Have you tried to roll it backwards in gear with the engine off? This suggestion is not based on any sound mechanical knowledge but rather on my strange primitive understanding of things. If something has jammed and you've been lucky and it hasn't grenaded the engine... I'm thinking roll it backwards and it might come loose and drain out with the oil.
Chill is offline   Reply With Quote
Old 02-21-2013, 08:54 PM   #73979
Chill
Chill's Avatar
Oddometer: 325
Lol, I removed all the interlock stuff. Last time I stood there and proudly explained to someone all that I had done and removed and how it was only required to protect idiots from themselves in the first place..... Then I promptly pushed the starter with the bike in gear and clutch out, bike lurched forward, side stand dug in and I nearly dropped the lot.
What
a
tosser.
Old 02-22-2013, 02:50 AM   #73980
blackcap
blackcap's Avatar
Oddometer: 546
Originally Posted by BergDonk View Post
I carry one of these:
http://terra-x.com.au/chainbreaker/
Check the video to see what it can do.
Best to use, and lightest and smallest I know of, and I've tried a few over the years, including one like Rusty's above.
We not long did a group buy on the Oz sub forum. They are not cheap, but they will not let you down, they just work. They may or may not be available ATM.
I also carry a few masterlinks and some spare chain.
ask them to throw in a couple of extra pins with this one. i had my pin shatter. was at home so no big deal but on the trail that would be a little more serious.
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Times are GMT -7.   It's 10:34 AM.
