Old 03-02-2013, 07:46 AM   #74176
TrophyHunter
Oddometer: 2,263
Jeff - I've had both so yes, they'll both work. I had the FCR but sold it as my son's bike had the TM40 and I wanted the bikes to be as identical as possible for long range travel.
They'll both work well and I really couldn't tell the difference...other than a slightly harder throttle twist with the TM. The FCR has a roller slide so twist resistance is minimal.
Unless you want to get really spendy, you'll most likely get a used FCR, modded for the DR. Even if you do it yourself, some parts will be new, some old. The FCR is a more complex carb. The cables are more protected at the carb but is a neglible item unless you plan on packing mud in there. It hasn't been an issue on the TM nor have I ever read of it being one.
The TM-40 is brand new. It's also not as tight as a fit as the FCR.
I got my TM-40 from Procycle and asked them to set it up for me based on mods to the bike & elevation. Plug & play and I haven't touched it after the install.
I did aim the squirt tube at the needle prior to install based on a recommendation from Tech23. Runs perfect.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 03-02-2013, 07:50 AM   #74177
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 412
Mambo Dave,
Only 3 things you messed with that could do that:
Kill switch
Clutch safety switch (remove if you haven't already)
Starter switch
I've been foiled by the kill switch more than once, always the first thing I check now!
Clutch safety switch will leave you stranded at an inopportune time if it fails, better to bypass it now and not have to worry about it. Just means you have to pay more attention when starting the bike, lord knows I've nearly bumped mine off the sidestand a few times when I didn't put it in neutral first!
Starter switch is a known weak link on these bikes. Mine failed miserably and was replaced with a Highway Dirt Bikes switch assembly that is much more robust and half the price of OEM.
I would start with those three. There's not really anything that would be affected in the wiring harness while changing bars unless you were really tugging on the wires and cables. If something came unplugged, it would probably be behind the headlight shroud.
Tim
3DChief is offline   Reply With Quote
Old 03-02-2013, 08:16 AM   #74178
greener556
Oddometer: 115
Originally Posted by 3DChief View Post
Mambo Dave,
Kill switch
Starter switch
Tim
Does HDB make a switch assembly or just the mount for a switch? I was just wondering about this a couple posts above.
greener556 is offline   Reply With Quote
Old 03-02-2013, 08:18 AM   #74179
maynard911
Oddometer: 142
Originally Posted by gofast1320 View Post
Does anyone know what the fattest tire is you can run on the front and rear on a stock DR650?
According to the tire fitment chart that I have the widest tire recommended for a 1.85 (Stock front rim width) is a 90, and for the 2.50 rear, a 130. Any larger and the tire design profile is distorted.
If you want wider than that it's time to get new wider rims. The supermoto style 17's with a 3.50 front and 4.25 rear rim width usually run a 120 f and 150 r.
I have the 'adventure' setup on my bike with a 110/19 f and 150/17 r.
Maynard " Youth is fleeting, immaturity is forever"
maynard911 is offline   Reply With Quote
Old 03-02-2013, 08:33 AM   #74180
00Buck
dirt rules
00Buck's Avatar
Oddometer: 202
My own experience, I have a Heidenau 140/80-17 Scout on the rear.
Lots of room.
Mike
00Buck is offline   Reply With Quote
Old 03-02-2013, 08:55 AM   #74181
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
Mambo Dave,
Kill switch
Starter switch
Tim
Thanks Tim!
LOL, the only area I played with to get it to start was around the kill/starter switch wire area, TOTALLY forgetting about the clutch switch (or to even look to that side) before heading off to work. I'll look when I get home.
Did you bypass it at the clutch handle? Just solder the wires together?
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 03-02-2013, 08:58 AM   #74182
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Originally Posted by Mambo Dave View Post
Thanks Tim!
Just chase the wires to where they conect behind the cowl, diconnect them and plug them to themselves to make it a complete circut. This is the easiest mod on the bike, plus it's reversable.
jessepitt is offline   Reply With Quote
Old 03-02-2013, 09:06 AM   #74183
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
I didn't realize so many were doing this mod. Awesome! Thanks for the reply!
their motorcycles
RyanR
Old 03-02-2013, 09:09 AM   #74184
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Yup!
Old 03-02-2013, 10:10 AM   #74185
badweatherbiker
badweatherbiker's Avatar
Oddometer: 706
so I picked up some rear wheel bearings and seals yesterday and went with KML 6204 and 6205 mainly because that is all anyone had in stock locally. The seals are in question though, I have a 30-4709 and a 30-5207, does anyone know if these are the right ones?
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 03-02-2013, 10:22 AM   #74186
TRAVELGUY
Old Traveler
Oddometer: 699
The kill switch. Press and release. I think that will cure your problem.
TravelGuy
My DR won't turn-over/ start after changing out the handlebars.
Well, I knew this was a possibility based on the experience of a friend 25 years ago... but it was an off-day and I didn't test the bike at all after installing them yesterday.
So my morning commute was changed from a ride with my new bars to driving the truck.
I'm quite sure I must have pulled some wire connection that didn't want pulled.
Where, kind sirs, in your experiences would you have me look first?
Symptoms:
Turn key on - get the neutral green light and the light for the high beam.
Push start button - nothing changes.
Rider - sitting on bike, dressed for cooler weather and work, laughing at himself... then pushing the bike back to its parking space, later driving off in a 1999 F-150 sans motorcycling gear.
Are you looking for fattest, or tallest? I went for the gearing change of taller, but am sure there is still room for more.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 03-02-2013, 10:47 AM   #74187
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Well, I knew this was a possibility based on the experience of a friend 25 years ago... but it was an off-day and I didn't test the bike at all after installing them yesterday.SNIP
Yes, no doubt you've disturbed something when you removed the controls.
Could be either the kill switch or the clutch safety switch. Try wiggling wires gently ... see if that gets it to start. If not you may have to replace or take apart one or both switches. Good luck.
Old 03-02-2013, 10:49 AM   #74188
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by SingleTrackJeff View Post
Which is the better upgrade for my DR
TM-40 Pumper Carburetor
Keihin FCR MX39 Carburetor
Some would argue that the TM is "more" adjustable, or more easily adjusted. On the FCR, all openings besides idle and WOT are controlled by needle shape and clip position. This may sound like an advantage, until you realize that for all intents an purposes, the needle must simultaneously have the correct diameters at heights that control 1/16, 1/8, 1/4, 1/2, and 3/4 openings (if the "dots are connected" then the areas between these openings should be acceptably close). On the other hand, the TM needle only has to have the correct diameters at heights that control 1/2 and 3/4 openings, as 1/16 and 1/8 openings can be controlled by the pilot jet size and 1/4 opening can be controlled by the needle jet size.
Some are annoyed by the heavier throttle pull of the TM.
Note that with slide carbs in general you are stuck, for a given throttle position, with whatever shape and slope of fuel delivery curve you have, i.e. if you have some lean areas at some rpm and some rich areas at some other rpm, that cannot reasonably be fixed. All that can be done is to move the entire curve up and down, i.e. add or subtract fuel for the entire throttle position. If you add fuel, you will fix the lean areas, while making the richer areas worse. If you subtract fuel, you will fix the rich areas while making the lean areas worse.
The compression and ignition timing on a DR are probably such that the improved cylinder filling afforded by a slide carb will nothing but beneficial, but I'd still want to have a look at NOX or a cylinder pressure trace to be sure. Perhaps a move to premium would be in order.
Regards,
Derek
motolab is offline   Reply With Quote
Old 03-02-2013, 11:01 AM   #74189
Adv Grifter
Oddometer: 6,128
Derek,
What about the consideration of things like squirt duration and angle, the use of different pump diaphragms, different post heights, and tuning with the leak jet.
Last month's MCN had a nice piece on tuning an FCR. It talked about the various elements in this carb and the various options and kits available to fine tune it to suit use.
I went through this back in '08 when setting up my '07 WR250F. Since then much more has been learned. I'm running a JD Jetting kit (3 needle tapers, 4 main jets, two leak jets) in my WR and it's OK ... but from the MCN article I see that now there is more I could do ...
like using the Boyesen Quickshot or different pump rebuild kits.
I'm assuming some or all of these innovations could be applied to an FCR being used on the DR650.
Any thoughts on this?
Old 03-02-2013, 11:12 AM   #74190
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by Adv Grifter View Post
Derek,
Of course tuning flexibility of any kind is a great, but in my experience there are instances where people unnecessarily engage in inordinate gymnastics with the pump when in fact the jetting is incorrect and should be tuned instead.
Regards,
Derek
Times are GMT -7.   It's 08:59 PM.
