03-09-2013, 09:40 AM
#74671 | |
Oddometer: 1,169
![]() doug s. |
03-09-2013, 09:44 AM
#74672 | |
Butler Maps
Oddometer: 14,430
I had a KLR and understand what to talk of. I got that KLR opened-up comfort & felling with a big tank, windscreen, taller bars (atv mid) and dropped foot pegs (ProCycle).
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
03-09-2013, 09:49 AM
#74673 |
Oddometer: 650
hi guys, putting everything back together on the dr and needed to know the torque specs on the front and rear sprockets.
1996 Kawasaki KZ1000P (currently being rebuilt) World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements! Earn extra income, become a distributor or just purchase: Advocare products-www.advocare.com/12084065 |
03-09-2013, 09:58 AM
#74674 | |
Butler Maps
Oddometer: 14,430
Rear Sprocket – 19.5 ftlbs http://www.advrider.com/forums/showp...6&postcount=20
03-09-2013, 10:09 AM
#74675 |
Life behind "Bars"
Oddometer: 6,252
No, but I seriously considered putting my DR motor in my 2000 KTM frame before I ended up selling it.( the KTM that is).
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
03-09-2013, 10:56 AM
#74676 | |
on the road o'dreams
Oddometer: 5,381
It's not terribly stable but if you work carefully when removing front wheel you will have no problem. Put bike IN GEAR and BLOCK rear tire. Find suitable place to position prop stand ... even under header pipe works ... Helps to have help hoiking the DR up into position while assistant inserts prop stand. I can do it solo ... but I'm a world class Bodger. A few folks sell adjustable prob stands. Not sure of links, but they are around. But a piece 2X4 can work just as well.
03-09-2013, 11:37 AM
#74677 | |
Oddometer: 650
thanks for the numbers but how the beck do you get the wheel back in after a Cush rubber replacement??
03-09-2013, 12:07 PM
#74678 | |
Kool Aid poisoner
Oddometer: 4,826
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
03-09-2013, 12:13 PM
#74679 |
Kool Aid poisoner
Oddometer: 4,826
Not with that front brake line hanging out in the wind!
03-09-2013, 01:02 PM
#74680 |
Oddometer: 837
I sprayed some lube (lightly,)or something slippery) on the new cush rubbers,they will slid easier into place.That's what I had to do.
97dr650 bad ass FCR-MX pumper ,plus other goodies
03-09-2013, 02:00 PM
#74681 |
Oddometer: 144
03-09-2013, 02:12 PM
#74682 | |
Butler Maps
Oddometer: 14,430
in the end I removed that thin metal spacer on the left side where the shaft goes thru. i then mounted the wheel and snugged it down enough where i could see the cush drive move in deeper into the hub. i let sit like that for a few days then put spacer back on and it all fit then. no idea how they build the bike from the factory?
03-09-2013, 08:32 PM
#74683 |
suck-squeeze-bang-blow
I decided to check my NSU screws today. I have a 2011 that I bought new and have racked up around 6500 miles. I cracked open the case and this is what I found.
![]() I was under the impression the screws were something other than allen heads, considering that's what most people are putting in there?? Anyways, they were tight. While I was in there I put everything back together using loctite. No need to pull the clutch or any of that crap... Even reused the old gasket.
Never underestimate the power of stupid people in large groups. |
03-10-2013, 01:36 AM
#74684 |
Oddometer: 3,503
Harbor Freight Transmission Jack
We've had it for years and seems tough as nails. Heaviest bike we've had on it is Doug's KLR, it lifts that thing without a problem and held it several days while he did a 685 kit.
Sarah
'08 DR650 |
03-10-2013, 03:16 AM
#74685 | |
Oddometer: 641
Thanks for the link, I may try one of the IRC CP-1's. Which size is closest to 120/90-17, the 4.60-17 or the 5.10-17?
