Old 03-25-2013, 04:38 PM   #75136
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,012
Originally Posted by Mongle View Post
I guess grammar comes second.
Just messing with you man!
Touche (by the way, I know there is an ' over the e in touche ;) French for "to touch")
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 03-25-2013, 04:50 PM   #75137
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Originally Posted by eakins View Post
how about everyone take the high road here and let's get back to talking about the DR650!
You're right, of course.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 03-25-2013, 05:04 PM   #75138
ER70S-2
ER70S-2's Avatar
Oddometer: 6,920
Talking
Originally Posted by rpet View Post
But on the other hand, I was an English major who was recently laughed at by coworkers for using the term "petcock."
Originally Posted by refokus View Post
He is definitely in the minority.
2004 DR650: 62,605 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 03-25-2013, 05:09 PM   #75139
NYTrainer
NYTrainer's Avatar
Oddometer: 145
Not choked!
Originally Posted by motolab View Post
Unless someone did a really strange retrofit, your FCR41 has a cold start enrichment circuit.
A choke is closed when an engine is cold and opened when it is warm, whereas a fuel enrichment circuit is opened when the engine is cold and closed when it is warm. A choke works by restricting the air flow, whereas an enrichment circuit works by adding extra fuel. A choke requires a fast idle cam or something akin to it (or you have to hold the throttle open manually), whereas an enrichment circuit adds a little extra air simultaneously with the extra fuel, so the fast idle is already built in.
Regards,
Derek
Thanks for the clarification, Derek. I assumed that it served the same function as a choke. All I know is that I pull out the button whenever it is cold...it starts...after the motor is warmed up, I push it in & go!
"Win without boasting...lose without excuse!"
2004 DR650 Suzuki,1978 Yamaha XS750,
1981 Yamaha XS650 Street Tracker,1981 Yamaha XV920 Chain-drive
1986 Yamaha YZ490-Vintage MX project, Yamaha TW200(Girl Friend's Ride) Yamaha TDM 850
NYTrainer is offline   Reply With Quote
Old 03-25-2013, 05:15 PM   #75140
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
[/QUOTE]
Another difference, the stock petcock is 1" taller than the Acerbis. This might be a problem since the uphill loop is now 1" higher. Note: ignore the vacuum port, which is less than 1" (a bit misleading in the photo).
The uphill loop and potential vacuum lock. When the fuel level gets low, there isn't enough head pressure to overcome the air bubble in the loop. This means the bike quits running even though you can still see gas in the tank. It's a common problem on both the IMS and Safari aftermarket tanks, some work, some don't. I haven't heard anything on the Acerbis yet.
[/QUOTE]
I just fitted my bike with the same tank and used the provided screws . what i did for the fuel line was a long loop that does a complete circle . I also got my fuel intake to the carb twisted forward like every one talks about. got 324 KM out of the tank before i switched to reserve
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 03-25-2013, 05:23 PM   #75141
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,042
Originally Posted by RichBeBe View Post
I disagree with a lot you have to say, but I kept my mouth shut, but this tops it. Do you really dyno bikes? Have you ever tuned a bike with an FCR on it?
Just about every bike I have ever been around with an FCR had a choke on it. My stock WR had a choke on it, and my DR with an FCR has a choke on it.
Added: I am sure you are going to chime in about the technical difference between a choke and an enricher circuit, but for the average person they are they same in the way they work to warm a cold bike up.
This should answer your question....
Originally Posted by procycle
No DR650.
I've already said many times that I have not tuned one.
Regards,
Derek
Originally Posted by Adv Grifter
Do you own a DR650? Ever ridden one? Worked on one?
The answer to all three questions is no.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 03-25-2013, 05:29 PM   #75142
ER70S-2
ER70S-2's Avatar
Oddometer: 6,920
Originally Posted by PPCLI-Jim View Post
I just fitted my bike with the same tank and used the provided screws. what i did for the fuel line was a long loop that does a complete circle . I also got my fuel intake to the carb twisted forward like every one talks about. got 324 KM out of the tank before i switched to reserve.
If the bike quits before the tank is empty, I'll be turning the carb inlet too. Do you have a photo of the fuel line routing?
Which petcock did you use?
324 km, that's about 73 miles right?
2013 WR250R
Old 03-25-2013, 05:35 PM   #75143
TRAVELGUY
Old Traveler
Oddometer: 699
+1
Originally Posted by acesandeights View Post
i prefer use the use of correct terminology, in the hopes it will become common terminology.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 03-25-2013, 06:18 PM   #75144
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 412
I posted this up about a year ago, but here it is again. If you turn the carb inlet to the rear, no high spots and you can get all the fuel out. It is also in the bike specific thread under fuel system. It's an IMS tank with Raptor petcock.
Tim
3DChief is offline   Reply With Quote
Old 03-25-2013, 06:31 PM   #75145
ER70S-2
ER70S-2's Avatar
Oddometer: 6,920
Tim
Hi Tim:
Timely repost.
2013 WR250R
Old 03-25-2013, 08:04 PM   #75146
JagLite
JagLite's Avatar
Oddometer: 1,379
Cool2 Dr?
Before I reach for a Kleenex, er, tissue, let's get back to DR's.
Here is the fiberglass tank I made with my first attempt at painting with base and 2 part clear coat.
And my first ever buffing and polishing effort.
It's not great, but good enough for a dirt bike
I was trying to get a good reflection on it.
All I have left to do is the lettering and pinstripes on the tank and tail, and to mount the oil cooler, chain, and chain guide...
It has been a fun project and I look forward to riding it.
Although I will be riding my other DR a lot more often. Now I have a street (and smooth dirt road) hot rod as well as my dual sport DR that is far more comfortable to ride.
Love it or hate it but it beats some of the boring posts recently.
If only because it has pictures
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is online now   Reply With Quote
Old 03-25-2013, 08:50 PM   #75147
DisTech
DisTech's Avatar
Oddometer: 616
Originally Posted by JagLite View Post
That is bad ass!
Love to see a video just to hear it!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 03-25-2013, 09:13 PM   #75148
shu
Oddometer: 1,053
More from 15* North latitude...
Originally Posted by ER70S-2 View Post
Thanks, all dressed up and nowhere to go.
So that's what my wife's been telling me about.
Meanwhile, south of the border...
Tires are looking good. MEFO rear at 4200 miles, still round and fun to ride on. It'll start to get square at about 6,000 but still have life in it. Good all round touring tire- works very well on lots of road surfaces and lasts a long time.
I'm running the Heidenau k60 Scout on front for it's long life and resistance to cupping. The MEFO front cups badly by 5,000 miles. Heidenau feels better to me in the dirt also. Looks like it's got a lot of life left in it.
We happened on the clubhouse of a local motorcycle club. 'Respect Motorcyclists!!" Right on.
.........shu
shu is online now   Reply With Quote
Old 03-25-2013, 09:41 PM   #75149
TrophyHunter
Oddometer: 2,263
JagLite - love it. That tank reminds me of a '70's CZ tank a little. Very nicely done.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 03-25-2013, 09:48 PM   #75150
dukegnarley
Oddometer: 224
has anyone had the starter torque limiter start to slip? my bike has developed a weird whining sound when trying to start the bike. The engine will still turn over, but it sure doesn't sound right.
Any thoughts? It's a 2001. with about 7,000 miles.
dukegnarley is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
