Old 04-04-2013, 08:51 AM   #75436
ram1000
ram1000's Avatar
Oddometer: 1,832
I have used the IMS for my 2008 DR sine it was new with no complaints at all. In fact it seems to have stretched out to a little more than 5 gallons. I would chooose only based which one you think looks the part on the DR. I do like the angular lines of the Acerbis, but the IMS looks smaller to me. I have never needed more fuel than the IMS provided and actually would not want a tank that held another gallon or so for the extra size it would impose, unless I lived in Australia.
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 04-04-2013, 08:52 AM   #75437
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,453
Originally Posted by acap650 View Post
Wish it had the brass inserts for petcock screws like the IMS instead of forcing screws into plastic - seems like they cheaped out there.
7,100 miles so far. No issues.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 04-04-2013, 10:00 AM   #75438
dirt hokie
Oddometer: 645
How are the mid 90's DR 650 for reliability. I am looking at what i think is a 1995 DR 650 at a local auction and might bid on it. Looks decent and seems to be ussable know or with a little TLC. Has about 5000 miles on it.
I had a xr 650 L and currently have a XR 400. Thought i might try another large dual sport to scew around on and electric start is nice for following the kids around trail with lots of starts and stops.
dirt hokie is offline   Reply With Quote
Old 04-04-2013, 10:05 AM   #75439
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,509
Any DR from 95 back is whole different animal from 96 onwards. Not necessarily a bad bike, but it does have a balancer chain and a few other things to worry about which the newer ones do not. Pre 96 is a bit heavier, and does not have the reams of accessories you can find for the later ones.
Old 04-04-2013, 10:05 AM   #75440
refokus
Just Learning
refokus's Avatar
Oddometer: 2,377
Originally Posted by ShadyRascal View Post
The Acerbis is said to be of better quality and fit.
That's hearsay..........
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 04-04-2013, 10:21 AM   #75441
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,691
Originally Posted by refokus View Post
That's heresy..........
**Fixt
I have had my IMS for 10K now. Fit was spot on. Only problem I had is when they started using ethanol the rubber in the gas cap came apart. Called them...they sent a new one in 2 days. I even use the IMS petcock with no problems. I have the clear one and it has stained a little where my knees rub it. It is a DR- not a show bike.
I will say I like the look/lines of the Acerbis better- but I think it looks huge on the DR.
Mongle is offline   Reply With Quote
Old 04-04-2013, 10:58 AM   #75442
warp9man
Gravel in my Travel
warp9man's Avatar
Oddometer: 588
IMS VS Acerbis
I have tried both and they both have there issuies but i finally went with the Acerbis.
IMS pros and cons
. smooth finish that cleans up easy with a magic eraser
. the natural color quickly went brown in 3 months
. I really had to push it towards the neck to get the mount bolts to go in without cross threading
. cap threads on easier
. pet cock sets more inboard
. comes with black fuel line
. seams are hidden on bottom/inside of tank so they are not visible
. brass inserts for petcock mounting screws
. seat concepts seat fits perfectly
Acerbis pros and cons
. little more fuel capacity
. texured finish is a little harder to clean even with magic eraser
. the tank seams are facing outwards and they were a little rough for my liking so I smoothed the seams out with a file
. mounts up with no drama and the bolts align easily
. hardware is slightly better
. appears larger than the IMS tank
. petcock is placed further out on the tank, and while it doesnt appear it will contact the ground in a tip over it does make me wonder
. I like the angular lines vs the rounded lines of the IMS (personal preferance)
. comes with clear/pink fuel line
. petcock screws thread into plastic. mine threaded up solid but i think you need to be somewhat careful not to strip the plastic holes out
. my seatconcepts seat does leave a slight gap
bottom line both are good tanks, it just boils down to looks and if you want the ever so slight amont of more fuel. I think mine has now swelled as I can get 5.4 gallons in the acerbis.
warp9man screwed with this post 04-04-2013 at 03:58 PM
warp9man is offline   Reply With Quote
Old 04-04-2013, 11:16 AM   #75443
ER70S-2
ER70S-2's Avatar
Oddometer: 6,085
Originally Posted by Thumper Dan View Post
I'm looking at upgrading the rear shock to something that actually works.
I would love to get a cogent rear rebuild but money is a bit tight. I've noticed on Procycles webiste I could buy the Race Tech Rear Shock Gold Valve kit for $159.95 plus delivery.
I'm sure cogent would be the best, but would this be a decent upgrade for the rear shock in comparison to the poor performing stock shock??
What ever you do, get something with rebound adjustment. I know guys that paid $700 for a shock without compression or rebound damping and no external reservoir.
Originally Posted by Mongle View Post
heresy
**Fixt
"BTW, I don't do style. It's a bike, not some girlie dress-up thing." -Threewheelbonnie
2004 DR650: 62,400 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-04-2013, 11:26 AM   #75444
ER70S-2
ER70S-2's Avatar
Oddometer: 6,085
.......but I think it looks huge on the DR.
My tank makes my butt look fat.
2013 WR250R
Old 04-04-2013, 11:29 AM   #75445
dirt hokie
Oddometer: 645
Is the balancer chain simular to a timing chain, and is it a major PIA if it needsto be replaced, and dose it destroy the motor if it goes south fast. Even if the engine is toast i might get it to build a hybrid bike any way, but i would have to get it dirt cheap for that. I still need to confirm it has a valid street title ect... Might even be able to see it run. More research tonight, its only 1/4 mile from my house.
Old 04-04-2013, 01:32 PM   #75446
inroads
Wimberley,Texas
Oddometer: 224
dr 650 side covers
Anyone know where to buy side covers at the best price?
inroads is offline   Reply With Quote
Old 04-04-2013, 01:52 PM   #75447
Colorado CJ
Colorado CJ's Avatar
Oddometer: 921
Thanks everyone! I just ordered the Acerbis tank from justgastanks.com They have a coupon code for ADVRiders that saved me $14.00 and free shipping.
Can't wait to install it so I don't have to worry about finding gas out in the sticks.
My Photography Page:http://andrewmarjamaphotography.com
'09 DL650
'06 DR650
Colorado CJ is offline   Reply With Quote
Old 04-04-2013, 02:22 PM   #75448
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,841
Acerbis vs Stock Tank Weight
Wondering who has weighed them and if there is much difference.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 04-04-2013, 03:41 PM   #75449
barko1
barko1
barko1's Avatar
Oddometer: 3,304
It is a DR
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 04-04-2013, 04:20 PM   #75450
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,691
Funny, my butt makes my tank look small....
Times are GMT -7.   It's 04:23 AM.
