Old 04-07-2013, 04:09 PM   #75526
JagLite
JagLite's Avatar
Oddometer: 1,434
Thumb Cogent shocks at PC now!
HUH?
When'd that happen??
I checked the PC site today to place a little order (yeah, right!) and see that they are now selling Cogent shocks, rebuild kits, and the Cogent "Bling Ring" that is so slick.
They do say "coming soon" so everything may not be available yet.
Excellent!
Two thumbs up for Rick at Cogent and for Jeff at Procycle.
There are a few other new items on the DR page at PC too if, like me, you haven't looked recently.
Or, if you are trying to budget your money like me, DON'T LOOK!
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 04-07-2013, 04:11 PM   #75527
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,095
Yeah, noticed that the other day. Interesting. I wonder why Jeff didn't build his own shock, instead of re-selling Cogent's.
There are so many options now it's hard to know what's best. Most expensive, Cogent?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights screwed with this post 04-07-2013 at 04:27 PM
acesandeights is offline   Reply With Quote
Old 04-07-2013, 04:23 PM   #75528
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by rch10007 View Post
Has anyone used silicon or sealant to seal the inside of the wheel so that if you did get a flat, it would slow the air leaking from the tube? Kinda like trying to make a tubeless setup but still using the tube?
Just wondering if anyone has went through the trouble of doing so...been thinking about sealing mine the next time I change tubes and tires, which are in my garage waiting.
This is not a bad idea, IMO. You achieve two things:
1. sealing the wheel may not make it air tight ... but will most definitely slow air loss if you get a puncture. With tubes you can have INSTANT AIR LOSS. Going 70 mph, mid corner and having instant air loss on your front tire is not a good thing. The sealing could mitigate air loss ... enough to give you warning and get off the road.
2. A minor puncture could be just a "slow leak" instead of a flat, and could give you time to pick your repair spot ... or just air it up once in a while and continue.
Old 04-07-2013, 05:09 PM   #75529
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,951
Just ordered two sets of Warp 9 levers for our DRs. Since my wife and I are selling our BMW F650 and 800GS, it just makes sense to farkle the bikes we want to keep.
Long live simple bikes!
Emmbeedee is online now   Reply With Quote
Old 04-07-2013, 05:13 PM   #75530
procycle
procycle's Avatar
Oddometer: 2,463
Yeah, Rick and I think this will be a good fit.
The plan is for ProCycle to build up enough inventory of 'Cogent Built' shocks to be able to sell them on an exchange basis rather than the old way of sending a shock to Cogent and having the bike down for a couple weeks. It also should be easier for Rick as he will be running ProCycle shocks in batches without having to coordinate the anodizing with several separate shock customers.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 04-07-2013, 05:17 PM   #75531
procycle
procycle's Avatar
Oddometer: 2,463
Originally Posted by acesandeights View Post
I wonder why Jeff didn't build his own shock, instead of re-selling Cogent's.?
The DR market isn't that big. It made more sense to me to work with Cogent rather than competing against them.
Old 04-07-2013, 05:18 PM   #75532
acesandeights
Asperger
Oddometer: 4,095
So, what's the best off road shock for the DR, a rider @ 200 lbs that rides moderately aggressive off road?
Old 04-07-2013, 05:20 PM   #75533
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,901
Its always good to think and come up with new ideas.
But,if the tube gets a hole and leaks, the offending item most likely came through the tire. So there's a hole in said tire for air to escape.
Just my 2 cents
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-07-2013, 05:22 PM   #75534
Foot dragger
singletracker
Oddometer: 12,901
So you cant have INSTANT AIR LOSS with tubeless?
Old 04-07-2013, 05:24 PM   #75535
Foot dragger
singletracker
Oddometer: 12,901
Originally Posted by Emmbeedee View Post
Another broken top roller... on my '96.
It didn't tear a huge chunk out, fortunately. Mostly just the nut itself.
Chain was too tight. Those rollers dont pull them selves out of the frame.
Old 04-07-2013, 05:31 PM   #75536
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,951
Possible, but it wasn't too tight on my watch. I never run chains too tight.
Actually this came out when I finally got around to taking the roller off. I turned the bolt, and it's clear that the attachment was still strong enough so that I had to use as much pressure on the wrench as it would normally take to loosen the bolt, but that pulled the roller and mount off. So it could have happened at any time in the past.
The bike is a '96 which I bought a few years ago.
Old 04-07-2013, 05:35 PM   #75537
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,944
Originally Posted by DockingPilot View Post
Guys like you are a riot ! And easy to wind up.
Im sitting right now with Bruce (2 time USA ISDE rider and 2 time ECEA Grand Champion, owns a 990, SE and the 08 690) in his living room. I showed him your concern for his bike and he laughed of course "What's he give a rats ass about my bike for, it's not like you talking about his mother"
But hey, as funny as it is, it's also getting juvenile, so to get off the subject and back to the DR, and so you can sleep tonight, I'll proclaim, my friend who lives half way around the world from Albie, Bruce Kenny's 690 is the most dead nuts reliable bike he has ever ridden or I ever had the honor to ridden with.
No harm or ill intent was meant Albie me boy.
You live in a cool country though, been there once, Sydney, "The rock", Kings Canyon, and the Whitsunday Islands on the GBR. Unfortunately not on a bike though.
Very cool
You somehow managed to make up a whole novel of things from my post. You've got skillz ! Stay frosty my friend.
Old 04-07-2013, 05:38 PM   #75538
Foot dragger
singletracker
Oddometer: 12,901
Originally Posted by inroads View Post
Im speaking for myself.Sandwash is speaking for "90%"
You do have to spend $700,as stated unless your buying used stuff.
You say"some people just can't leave things alone" that is part of the problem
I say start with a $18 engine sprocket and a tuned carb and keep your MPG and better altitude compensation.
I agree,just a 1 tooth smaller countershaft sprocket gives a nice boost in getting going.
There are SO many bikes made for going fast that run great right out of the box,hopping up a DR is an interesting way to spend your time but hardly cost effective.
Then the flexy heavy frame and el cheapo forks and shock will have to be fixed if you do get more power out of the the thing,then it gets really pricey.
Ive flailed my DR on trails my KTM's barely notice,the poor DR is dragging bottom and tank slapping trying to break in half.
Its an econo bike pure and simple and I like it that way,for long distance dirt road traveling its a great bike and I almost never have to work on it.
Ive modded lots of stuff on my DR,just not the engine.
Old 04-07-2013, 07:36 PM   #75539
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
A well set up Ohlins.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 04-07-2013, 07:41 PM   #75540
BergDonk
BergDonk's Avatar
Oddometer: 3,926
Works great for me, haven't tried better, but not tried the popular Cogent or Ricor, or Racetech upgrades either. Ohlins just work, when setup.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Times are GMT -7.   It's 03:18 AM.
