Old 04-30-2013, 04:13 AM   #76216
arnold4
Oddometer: 1
Hello,
I have a plan to install kick start mechanism to my 93`dr650SE. Originally it has only electric start. Has anybody tried to do it? Tips, advices?
Tarmo
arnold4 is offline   Reply With Quote
Old 04-30-2013, 04:18 AM   #76217
spannerman
spannerman's Avatar
Oddometer: 51
Originally Posted by BergDonk View Post
Some just do.
There is a pressurised oil feed right behind the seal. Oil comes from the pump to the space behind the seal, contained by the inner seal on the countershaft bearing, then into a hole in the countershaft for distribution to the gears.
Max oil pressure is when the oil is cold at startup. There is minimal crank pressure then, and even so, its shielded from crank pressure by the seal on the css bearing.
The seal is only retained by friction, so needs to be assembled dry. There is also a suggestion that some cases were machined a bit oversize and Suzuki have released an oversized seal, but dunno about that.
Thanks only thing that worries me is will just push a different seal out if i fit plate one thing i am wondering is did i push seal in to far ????????
spannerman is offline   Reply With Quote
Old 04-30-2013, 05:38 AM   #76218
rch10007
Dotted Quad Ranger
rch10007's Avatar
Oddometer: 39
I got a couple questions the other day that I can't answer so I figured I would ask here:
A couple of the bearings inside the cases have dust seals on them. Why are they retained inside the motor and what will happen if they are removed?
The only thing I could think of is related to circuit pressure? Couldn't think of any real downside other than maybe reduced pressure but I would assume the bearings would get enough oil on them through spray...
Should I tell the guy to take his motor back out and apart or will he be ok?
Thanks.
Philosophy is written in that great book which ever lies before our eyes... Galileo
rch10007 is offline   Reply With Quote
Old 04-30-2013, 06:48 AM   #76219
procycle
procycle's Avatar
Oddometer: 2,403
The seals on those bearings cause oil from the oil pump to be directed through passages in the transmission shafts. Installing unsealed bearings will allow the oil to just flow through the bearing and drain into the bottom of the case instead of being channeled to the inside of the transmission gears and to the clutch. If somebody put their motor together without the bearing seals they are risking premature transmission and clutch failure.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 04-30-2013, 06:49 AM   #76220
Tripl Nikl
Tripl Nikl's Avatar
Oddometer: 3,158
Originally Posted by Indytriumph View Post
Just wanted to say Hi. I have been a lurker for many years. I picked up a 96 DR650 two years ago and I am having a blast with it. My main mode of transportation has been a DL650 with 170,000 miles on it.
Tom
I run the same 5.11 vest. It's better than the m/c specific vests, IMHO.
Tripl Nikl is offline   Reply With Quote
Old 04-30-2013, 06:57 AM   #76221
rch10007
Dotted Quad Ranger
rch10007's Avatar
Oddometer: 39
This is what I was thinking too...
Can you confirm which bearings the seals are installed and which orientation? On second thought, I think all the bearings are different sizes, aren't they? I know the inner output shaft bearing has a seal that faces the right side but I don't remember the other one. Maybe the outer input shaft with the seal facing the outside of the motor? It's been too long that I had my motor apart that I don't recall exactly but hate to give out wrong info.
Thanks again!
Old 04-30-2013, 07:00 AM   #76222
procycle
procycle's Avatar
Oddometer: 2,403
Originally Posted by spannerman View Post
...only thing that worries me is will just push a different seal out if i fit plate...
It won't push anywhere else. The countershaft seal is the only external seal that has oil pressure behind it.
Go to the last two posts on this page. --> http://drriders.com/topic6662-70.html
There are photos of the oil passages and an explanation of the oil flow to the transmission with a flow diagram for the oil distribution. You'll have to click on the diagram and enlarge it to see.
Old 04-30-2013, 07:02 AM   #76223
procycle
procycle's Avatar
Oddometer: 2,403
Thanks again!
The bearings are all different sizes. The oil seals face outward - away from the transmission gears.
Old 04-30-2013, 07:11 AM   #76224
rch10007
Dotted Quad Ranger
rch10007's Avatar
Oddometer: 39
Gotcha. Just 2 bearings use the seals, right?
Old 04-30-2013, 07:50 AM   #76225
spannerman
spannerman's Avatar
Oddometer: 51
Thanks for that you clearly understand the dr 650 more than me would you ship the retainer to uk i have paypal account if that makes payment easyier ????
Thanks Will
spannerman screwed with this post 04-30-2013 at 08:06 AM
Old 04-30-2013, 07:51 AM   #76226
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,075
Originally Posted by joefromsf
BTW, this is the cliff jumping DR made famous by my crash video. After scores of hours, I finally got it running this weekend and then this freak incident happened two hours into my first shakedown ride.
Joe,
What was the issue? My wife got a big kick out of chatting with your wife, on FB (all to the detriment of their common friend Steve).
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-30-2013, 08:50 AM   #76227
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,564
Originally Posted by Bronco638 View Post
Joe,
Apparently, it was a stretched choke cable. Oops I mean fuel enrichment circuit cable.
Friday morning I trucked the bike up to my friend Darrell's place. He was my TAT riding partner and also has a DR650. There I began swapping known good parts from his bike to mine. At one point my bike had his IMS tank, fuel line, carburetor, ignition coil, CDI module, regulator/rectifier, diode and battery. Nothing made a difference, so I swapped it all back. At one point I mentioned the only thing we didn't swap related to the fuel system was the choke cable, but we dismissed it because the choke seemed to work fine. It would make the bike easier to start when cold and the RPMs would noticeably drop when choke was closed as bike warmed up. And although we noticed adjustment nuts on the cable sheath, there was no mention of cable adjustment in the service manual.
I was ready to load the bike back into the van and head home, but had to wait until some contractors finished up and moved their truck. While waiting I killed some time adjusting Darrell's air/fuel mixture screw. Then still twiddling my thumbs, I decided to take a closer look at the choke cable.
First I looked at the adjustment on Darrell's, and adjusted mine the same, which l think shortened the cable sheath. No change in the bike. Then I went in the opposite direct to lengthen the cable sheath. At first it ran a bit worse and I didn't think it was even going to make it back up the hill. Then something happened and the bike took off. No more stumbling or bucking.
My guess is that the cable was stretched when the handle bars were hammered in the crash and the plunger at the end of the cable wasn't fully closing in the carb when I closed the choke. A small part of me isn't convinced that accounts for the problem, but since it was the last thing I adjusted, I'll accept it for now.
joefromsf is offline   Reply With Quote
Old 04-30-2013, 10:07 AM   #76228
procycle
procycle's Avatar
Oddometer: 2,403
3 bearings - both left side transmission bearings and the right side bearing on the countershaft.
Old 04-30-2013, 10:11 AM   #76229
procycle
procycle's Avatar
Oddometer: 2,403
Thanks Will
We ship worldwide. It's easiest to just order right from the ProCycle web site. You can find the DR page here. International shipping on one little part can be a bit painful. It may be more worthwhile if you can find a few more items you need. If you want to pay with PayPal send an email to the sales department through the web site. One of the sales staff will be able to send a PayPal invoice.
procycle screwed with this post 04-30-2013 at 10:35 AM
Old 04-30-2013, 11:57 AM   #76230
rch10007
Dotted Quad Ranger
rch10007's Avatar
Oddometer: 39
Thank you Sir!
Unfortunately, I will be storing this info myself as I tried to share it with my neighbor only to be informed that he has the motor in the bike and he doesn't care to take it out. I wished him luck... I hope the trans can get enough oil otherwise.
Times are GMT -7.   It's 12:10 PM.
