Old 04-30-2013, 11:57 AM   #76231
rch10007
Dotted Quad Ranger
rch10007's Avatar
Oddometer: 39
Originally Posted by procycle View Post
3 bearings - both left side transmission bearings and the right side bearing on the countershaft.
Thank you Sir!
Unfortunately, I will be storing this info myself as I tried to share it with my neighbor only to be informed that he has the motor in the bike and he doesn't care to take it out. I wished him luck... I hope the trans can get enough oil otherwise.
Philosophy is written in that great book which ever lies before our eyes... Galileo
rch10007 is offline   Reply With Quote
Old 04-30-2013, 12:32 PM   #76232
MADurstewitz
MADMark
Oddometer: 159
Originally Posted by rch10007 View Post
Thank you Sir!
Take pictures with your phone as you work. Eliminates the guess work.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 04-30-2013, 12:40 PM   #76233
rch10007
Dotted Quad Ranger
rch10007's Avatar
Oddometer: 39
I took pictures of my rebuild a few years back and I even looked at them but the problem is that the seals are to the inside, meaning you don't know they are there until you pull the bearings. When I walked down to my neighbors house, he had the seals laying on floor and when I asked what they were for, he said the case bearings. I immediately thought, "Ruh-Roh!" but couldn't tell him definitively if it was really an issue or not. At least now I know if I ever have another motor needing bearings.
What's sad is that someone is going to buy that bike from him one day and never know about the bearings.
Old 04-30-2013, 03:44 PM   #76234
luckychucky
luckychucky's Avatar
Oddometer: 1,255
Is this my motor cracking?
luckychucky is offline   Reply With Quote
Old 04-30-2013, 03:46 PM   #76235
sandwash
sandwash's Avatar
Oddometer: 1,358
Nope just casting marks.If they where cracks it would be leaking oil all over the place.
97dr650
sandwash is offline   Reply With Quote
Old 04-30-2013, 03:51 PM   #76236
luckychucky
Oddometer: 1,255
DR 650 Case
You mean they have been there all along? I don't remember ever seeing them. It looks like the metal is drying out?
Old 04-30-2013, 04:33 PM   #76237
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,686
You've just got some dust in the lines highlighting them more than usual. They've always been there.
Old 04-30-2013, 07:38 PM   #76238
ER70S-2
ER70S-2's Avatar
Oddometer: 6,485
Ignore the arrow, it's pointing out a metal head gasket.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 04-30-2013, 08:03 PM   #76239
Booze&Meat
Bar Crawler
Booze&Meat's Avatar
Oddometer: 37
Took the awful Rotel Tomato can exhaust off of my Purple People Eater and installed an OEM setup scored off of eBay.
The bike even looks happier.
Booze&Meat is offline   Reply With Quote
Old 04-30-2013, 11:01 PM   #76240
Chill
Chill's Avatar
Oddometer: 321
Mine has them too. I panicked a bit when I first saw them until I looked at another DR and realised they all have them.
I found the recent comments about valve clearances interesting. I adjusted mine recently for the first time (12,000km) and they were quite loose. I was thinking that the way mine were would have meant a decreased valve-open duration and now adjusted it would increase the valve open duration. But was unsure as to which state would give more power if any.
Since adjusting it's noticably quieter. Also, before it would start without the choke and would run slightly slower and then speed up after 20 seconds or so. Now, if I start without any choke it tries to die and it starts ok with a tiny bit of choke for the first 20 seconds or so. It's about 20C (68F) degrees here in the mornings.
Not a problem I just find it interesting.
Chill is offline   Reply With Quote
Old 05-01-2013, 01:05 AM   #76241
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Originally Posted by dentedvw View Post
I thought my new (to me) dr was a bit short, so I peeked at the dogbone, and sure enough it could come up. So up it went, and it's more comfortable for me now.
Only, the sides stand is now too short. Any shorter stature Utah residents want to trade with me?
I'm using a short side stand on a full height DR and wouldn't run a stock stand if I was given a gold plated one...
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 05-01-2013, 01:18 AM   #76242
BergDonk
BergDonk's Avatar
Oddometer: 3,596
My stock one is a bit too short
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 05-01-2013, 06:24 AM   #76243
Sgt H
Sgt H's Avatar
Oddometer: 42
Price check
Looking for another DR650 and found a 2003. It appears to be completely stock, no farkles and less than 2000 miles. Owner will take $2800, NADA value is about $2000. Original asking price was over 3K. Good, bad, OK on price.
Sgt H is offline   Reply With Quote
Old 05-01-2013, 06:25 AM   #76244
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,894
Originally Posted by joefromsf View Post
Apparently, it was a stretched choke cable. Oops I mean fuel enrichment circuit cable.
Interesting how you discover things, eh?
You could always go with one of these, from Pro Cycle:
That would eliminate the cable (and its adjuster) entirely.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-01-2013, 07:54 AM   #76245
Meter Man
Living on a prayer
Meter Man's Avatar
Oddometer: 7,696
Can't get anyone to come look at my DR, only one lookey loo who decided on a smaller bike. Decided to get it serviced for the year and keep on riding.
Meter Man is offline   Reply With Quote
Times are GMT -7.   It's 10:36 AM.
