Old 05-08-2013, 03:42 PM   #76426
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 921
Originally Posted by eakins View Post
Is there an upgrade piece available for the stock 2-piece rear preload adjusters? They suck adjusting just whacking the carp outta them to move them. I've seen better solutions on other shocks.
Thnx, Bill
Try turning the spring with your hands with the bike off the ground..... worked for me for years on many different bikes. you may also use a preload spanner or a strap wrench
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 05-08-2013, 04:45 PM   #76427
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
How much total rear travel are we now all using as a baseline? and this how much race sag should i be looking to see? still 25% of total travel?
Per Cogent & my redone shock, I do believe I have the correct spring rate for my weight so after I set my race sag correctly, my static sag should be spot on.
With a stiffer spring you will get a better ride with LESS preload. Not sure on amount of travel. I would try backing off pre load and doing test rides using the same track or route.
If you can't get a better result ... Go to a softer spring or modify compression settings. Might help.
The DR650 is a tough customer. We need to have it work well on pavement AND off road. The requirements and ideal setting for both ... don't really compliment each other ... so ... compromise!
Thnx, Bill
Yes, grabbing it firmly by hand (wear gloves) and turning spring can work.
Or ... if you can get hold of a Spring Compressor (cool little tool) ... and compress spring slightly, then preload rings can be easily wound up or down.
When going by hand ... Clean and lube with WD40 first ... and you may bust a knuckle or two!
Old 05-08-2013, 04:46 PM   #76428
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Thnx, Bill
Cogent's "bling ring". now available from PC too, I believe.
I have one on my Cogent re-engineered rear shock and it's more than just "bling"... it's a nice piece of kit, easier to adjust and lighter.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 05-08-2013, 05:25 PM   #76429
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,161
Originally Posted by Bronco638 View Post
No, 10.2" is the amount of suspension travel in stock form. 8.7" is the amount of travel after the suspension has been lowered (per the Shop Manual). So, I'm wondering how I got to 6.5" as measured from the tire to the front fender mounting bolts. It would seem I'm 'missing' 2" of travel.
Sorry, I thought you were measuring it while it sat on the ground- which would make sense. 10.2- 2 (lowered)= 8.2 total travel.
8.2- 1.7 (sag)= 6.5 as it sat on the ground/sidestand.
yeh, if you are getting 6.5 while FULLY EXTENDED you have something else going on.
Mongle is online now   Reply With Quote
Old 05-08-2013, 05:32 PM   #76430
r_bin
r_bin's Avatar
Oddometer: 744
Greetings from Pensacola!
I bought a very clean, low mileage, 98 DR650 a couple of months ago. It was going to be a "bike between new bike" until I my BMW sold. But I don't think so anymore. Each day I find that this is maybe one of the most useful/fun bikes I've ever had, and I have had more than a few. So, I'm going to keep this for a good while instead.
I ordered the Seat Concepts kit and had it installed by someone that knows what to do. Suzuki getting us back for WWII is my theory on the OEM seat. Very funny. My first 250 mile ride was pita... the SC seat is all you guys say. My butt thanks you for the recommendation.
Replaced the the PO's Anakees with K270s for more 50/50 exploring (the 270's work well with the plentiful sugar sand that's overly common around here).
I've been soaking in your collective wisdom and thank all of you guys for the great information.
Here's a photo from this weekend. It got muddy later.
Seemed like a good idea at the time.
r_bin is online now   Reply With Quote
Old 05-08-2013, 05:41 PM   #76431
Kommando
Kommando's Avatar
Oddometer: 7,389
Welcome!
You're gonna have a blast with that DR. Check out the AMS Sand Snake for a cheap front tire that works well offroad in FL. Be careful in paved turns with a front knob though.
Kommando is offline   Reply With Quote
Old 05-08-2013, 06:52 PM   #76432
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,089
Originally Posted by acesandeights View Post
I'm sorry, I made an assumption that your bike was on the ground. There will be the weight of the bike that will use some of the travel, and there will be stiction (the amount of friction that keeps the suspension from moving fully through the range of travel). So, your bike, off of a stand will never show the full amount of travel just sitting there, and even on a stand probably won't. It'll always be slightly compressed, and more depending on whether the bike is on the ground or in the air and the amount of stiction.
I am measuring while the bike is on the ground. I didn't realize that the 10.2" and 8.7" measurements were with the bike on a stand (suspension totally unloaded). So, I'm guessing that 6.5" measurement is ok. My fault for not realizing the context in which those measurements were given. Thanks for setting me straight.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-08-2013, 06:54 PM   #76433
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,281
there ya go. thanks.
http://www.procycle.us/bikepages/dr650.html#suspension
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-08-2013, 06:55 PM   #76434
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,281
thanks. i'll try that.
Alaska
Old 05-08-2013, 06:56 PM   #76435
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,281
i'm going to give that a try and see how things change.
Alaska
Old 05-08-2013, 07:20 PM   #76436
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,022
Travel would be the full range of the suspension. When it sits on the ground the weight of the bike takes up some of that range, or the weight of the bike is already using some of the stroke if that makes sense. You'll notice you can lift up on the front or rear (at least some) when it's on the kickstand
That's what people are referring to when they discuss sag, the difference between full range and how it sits with its own weight or the weight of the rider.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 05-08-2013, 07:37 PM   #76437
TrophyHunter
Oddometer: 2,265
First off - welcome - and you're right. The bike surprised me too and it's my go to for rides.
Check this before you continue - courtesy of Keintech Engineering
DR650 update on the 650 grenade issue. 1998 and early '99 were equipped with a solid idler gear that created a problem when the engine kicked back during shutdown, breaking out the gear bearing bosses. This also breaks out and destroys the left case half due to its ridged design. The case halves always come in matched pairs and cost in excess of $650.00 not to mention labor charges to change all internal parts into new cases. This should not be taken lightly. '96 and '97 had the torque limiter gear that is designed to slip due to a preloaded slip clutch arrangement. Well they went back to this design in mid '99 after vin # X2100561 so if your Vin # predates this you should consider installing this updated item shown
http://www.kientech.com/DR650TorqueLimiter.html
'07 WR450 2013 HD Road King '73 Hodaka Wombat '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 05-08-2013, 07:59 PM   #76438
motolab
motolab's Avatar
Oddometer: 2,777
You could always go with one of these, from Pro Cycle:
That would eliminate the cable (and its adjuster) entirely.
The thing in this picture will not work properly on a BST40 as it's missing a metering rod.
Regards,
Derek
motolab screwed with this post 05-08-2013 at 08:23 PM
motolab is offline   Reply With Quote
Old 05-08-2013, 08:11 PM   #76439
ER70S-2
ER70S-2's Avatar
Oddometer: 6,955
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 05-08-2013, 08:23 PM   #76440
motolab
motolab's Avatar
Oddometer: 2,777
Sorry, can't quote specific posts siting specific problems, just have a memory of various posts about Barnett and EBC clutch kit issues. Not even sure what the problems were beyond a lever pull that wears you out.
In my experience Barnett clutch springs can be a bit on the heavy side, which will of course cause a heavy lever pull, but can also cause the clutch to drag, as some of what would otherwise be travel at the clutch gets used up by the cable housing compressing and the cable stretching a touch. On clutches with even-numbered springs, you can alternate Barnett springs with stock, which should solve the problem. On clutches with odd-numbered springs, you can install some shims inside the springs under the outer spring seats in order to reduce the preload a bit.
Regards,
Derek
Times are GMT -7.   It's 07:32 PM.
