Old 10-02-2007, 01:35 PM   #7666
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Originally Posted by Foot dragger
Soooooooooooooooo any body know how these things go back together?
You missed a bit...
NordieBoy is offline   Reply With Quote
Old 10-02-2007, 03:32 PM   #7667
alprosound
HappyMan
alprosound's Avatar
Oddometer: 498
Laugh
That was worth the price of admission. Thanks! Made my evening as I'm stuck at work.....
John
MN
06 Triumph Tiger
Suzuki DR650SE
Yamaha XT350
Suzuki DR 200
Yamaha TTR
Yamaha RT
Suzuki JR 80 and JR50
“Success is not final, failure is not fatal: it is the courage to continue that counts.” - Winston Churchill
http://ridedualsport.com
alprosound is offline   Reply With Quote
Old 10-02-2007, 03:42 PM   #7668
v1owner
V1 Owner
Oddometer: 10
Originally Posted by svwayne
OK, so it is louder but does it really run any better? Are you running the spark arrester off road? Have you got one on those big "H-D" crests sewn on the back of your jacket?
Do us all (or maybe it's just me?) a favor and get one of those quiet inserts installed ASAP before more people get pissed from being awaked by another LOUD motorcycle.
To answer your question, Yes, the bike runs better with the new Two Brothers exaust. This is a racing exaust and is prolly making as much HP that a stock DR can give. The bike was wheeling easily in first and second in the dirt just by using the throttel only. I had a hard time doing that before with the stock exaust pipe. I think the new pipe, K/N air filter with the jet kit has given the bike an extra 3 or 4 HP. It's loud because it is a racing pipe.
Don't worry, I ordered the silencer tip yesterday. I actually ordered two different ones from Two Brothers. I had to purchase these because the bike is to loud for my taste also. All I am trying to do is get the ol DR to have as much power that it can. I do not want to wreck any family picnics while having a ride, that's for sure. Maybe I should have got the Q pipe, dunno, to late now. The new silencer tip says it will bring the pipe noise level down to 93 decibles. I think that this will be a great exaust after the silencer tip is installed. I will let you know and post a picture as well.
v1owner is offline   Reply With Quote
Old 10-02-2007, 04:56 PM   #7669
Just Jim
Oddometer: 19
Petcock question...
Is there an "off" position for the petcock? Neither the manual nor the petcock markings seem to show such a thing, yet there are times I would like to know that fuel flow is blocked.
My new blue '07 has a whopping 15 miles on the odometer, but WOW, what a bike! Thanks for all the good wisdom I've absorbed on this thread.
Cheers... Jim
Just Jim is offline   Reply With Quote
Old 10-02-2007, 05:50 PM   #7670
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Cheers... Jim
No. The stock petcock has three settings- ON, PRI, and RES. PRI is will flow fuel whether the engine is on or not. Use this when the bike has been sitting for a while, and the fuel level in the carb is low. Bikes start much easier when there is fuel The other two settings will only flow fuel when the engine is running and providing a vacuum signal to the petcock.
The fuel flow is "blocked" by the inlet valve in the carb. The float keeps this valve closed until more gas is needed. As long as it's doing its job, you are fine...
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 10-02-2007, 05:53 PM   #7671
sjourn
Oddometer: 32
Originally Posted by jamodu-fishbulb
everyone who does the convertion must take these photos.... the thing is huge!
heres one of mine....
cheers fish
I'm lovin' it!!
thanks for sharing, I was contemplating of getting one, now I'm more convinced. Btw, do you know if the Safari has fuel caps that lock?
sjourn is offline   Reply With Quote
Old 10-02-2007, 06:18 PM   #7672
MaxPower
MaxPower's Avatar
Oddometer: 169
hummmm
what is the fuel capacity on a new DR650?? stock
MaxPower is offline   Reply With Quote
Old 10-02-2007, 06:21 PM   #7673
Jimbozini
Misadventurer
Jimbozini's Avatar
Location: The Church of the Twisty Road - East Tennessee
Oddometer: 455
Originally Posted by Gary B.
Where can I get a power port like I see on some of your bikes to run my GPS?
Here' my simple setup:
1. Take a Battery Tender fused SAE lead and run from battery (had to lengthen the lead I had laying around).
2. Run lead along wire harness @ top frame tube.
3. Add SAE accessory socket found at your neighborhood WallyWorld.
Affix to speedo with a heavy-duty zip tie and some foam support.
Plug in to Battery Tender Lead
4. Add GPS.
-Jim
TiMe WaRP vINtaGe mOTOrCyCLe cLuB
Moto Images
$5 off on a Smugmug accout Use this coupon code: LlVtvdPX4gIjg
Jimbozini screwed with this post 10-02-2007 at 06:30 PM
Jimbozini is offline   Reply With Quote
Old 10-02-2007, 06:29 PM   #7674
DRinda505
I'm right behind you.
DRinda505's Avatar
Oddometer: 407
Originally Posted by switchback
I was riding to work today and while sitting at a light I gave the DR a little bit of gas and it stumbled for a few seconds then stalled. I tried to restart and the bike would not. I started the long roll home periodically trying to start the bike again. Once it momentarily started then died. After 2 miles of pushing the bike started and I rode it home.
I am thinking I have crap in the carb plugging the jets. This happened once before on the freeway but cleared itself quickly after I maneuvered to the shoulder. Any other ideas out there? The bike is stock with a full Safari tank, only 3 months and 3k miles old.
How recent was your tank swap? Junk from tank clogging the main or carb inlet filter?
Just a thought.
05 DR650....Yea I know.... but it was cheap, Couldn't afford the Trail 90 I wanted.
DRinda505 is offline   Reply With Quote
Old 10-02-2007, 07:20 PM   #7675
madf
madf's Avatar
Oddometer: 620
Dr 650 OS
I just could´nt finish reading all 500 plus pages on this thread...
I´m interested in buying a 2002 DR 650 OS. What´s the difference with the S, SE and OS models?
Thanks,
MADF.
madf screwed with this post 10-02-2007 at 08:01 PM
madf is offline   Reply With Quote
Old 10-02-2007, 08:14 PM   #7676
Gary B.
Older than dirt...
Gary B.'s Avatar
Oddometer: 542
Hilarious!!! Ya made my night. And thanks guys for all the power port tips!
"Male menopause is a lot more fun than female menopause. With female menopause you gain weight and get hot flashes. Male menopause ? you get to date young girls and drive motorcycles."----- John Wayne
DR stands for "Daily Rider"
'06 Suzuki DR650SE
'06 Kawasaki Concours - 2up Cruiser
'99 Yamaha YZ400
'05 KTM 125SX-SOLD!!!
'90 KTM LC4-the bike's gone, but the memory remains, along with the oil spots on the floor
Gary B. is offline   Reply With Quote
Old 10-02-2007, 08:17 PM   #7677
Dynosport
Oddometer: 2
DynoJet Tuning
Proud owner of a 2006 DR650 SE but it ran a little lean right out of the show room. Dealer said that most guys install a jet kit and that solves the problem. I got a Dynojet kit, 3138 for a DR650 S and here's the deal: it idles smooth and runs really well on light throttle but when I call for the horsepower it dies and then as I let off the throttle is comes back to life and then surges with a burst of power. Here's my setup: stock pipe and airbox, idle mixture 2.5 turns from set, DJ 150 jet with needle at fourth notch. I checked and double checked all vacuum hoses and I also removed the inline fuel filter. I live in Florida so that's practically sea level. From what I can tell the bike is running rich but I'm no pro at this. Any suggestions?
I am new to the form and I have learned a lot about the bike from all of the postings that I have read.
Dynosport screwed with this post 10-02-2007 at 08:30 PM
Dynosport is offline   Reply With Quote
Old 10-02-2007, 08:24 PM   #7678
CaptTurbo
CaptTurbo's Avatar
Oddometer: 1,099
Originally Posted by Dynosport
Proud owner of a 2006 DR650 SE but it ran a little lean right out of the show room. Dealer said that most guys install a jet kit and that solves the problem. I got a Dynojet kit, 3138 for a DR650 S and here's the deal: it idles smooth and run really well on light throttle but when I call for the horsepower it dies and then as I let off the throttle is comes back to life and then surges with a burst of power. Here's my setup: stock pipe and airbox, idle mixture 2.5 turns from set, DJ 150 jet with needle at fourth notch. I checked and double checked all vacuum hoses and I also removed the inline fuel filter. I live in Florida so that's practically sea level. From what I can tell the bike is running rich but I'm no pro at this. Any suggestions?
Your bike needs more air. Open that airbox. For starters you should pull out the snorkle and see if you have an improvement. You will probably need to open it up a bit more then that though. Try that and then let us know what happens.
"No Man's life, liberty or property is safe while the legislature is in session." --American lawyer, editor, politician, Judge Gideon Tucker (1826-1899)
CaptTurbo is offline   Reply With Quote
Old 10-02-2007, 08:29 PM   #7679
urbancowboy
Vicious Cycler
urbancowboy's Avatar
Oddometer: 1,782
bulb question
i asked this question in the garage section and got no answer. maybe someone here knows:
i hope to very soon become the new owner of a '97 DR650 that is now outfitted with one of these 8" lights as its only headlight.
http://trailtech.net/atv_8in_race_lights.html
right now the low beam is ON and the high beam turns the light OFF. the light has an H1 bulb which is single filament.
is there another bulb that is dual filament that is close enough in size to wire up for HI beam/LOW beam use in this light?
thanks. i'll be here alot now that i'm joining the DR club too. gonna use the DR for commuting and maybe easy dirt and keep the GS for longer distance stuff.
bmw makes motorcycles now?
smugmug link: https://secure.smugmug.com/signup?Coupon=fMX8CMi5nSlps will save you $5 at the best photo hosting site on the internets. you can almost buy a beer in nyc with that. your welcome.
[/B]
urbancowboy is offline   Reply With Quote
Old 10-02-2007, 08:39 PM   #7680
OnlyVees
Moto-journalist
OnlyVees's Avatar
Oddometer: 875
What are you guys liking for brake pads? OE? other?
2 kids, 1 wife, no bike.
OnlyVees is offline   Reply With Quote
Times are GMT -7.   It's 08:49 PM.
