Old 05-20-2013, 02:43 PM   #76831
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 411
Just changed out my cush rubbers today......WOW! It's like I have a brand new bike. I got the bike (1996 'cause purple is faster!) about a year ago with 16,000 miles, and apparently still the original cush rubbers. I did 8,000+ miles cruising around the US last summer, plus lots of local riding. It's now at 28,000 and I can't believe the difference! Shifts are much smoother, so is deceleration, I didn't realize how much slop was in the hub! I had to use some spray silicone to get the hub back together enough to fit in the swing arm since the new rubbers were so tight. I'm a believer now, if your drive feels sloppy at all, change those babies out!
Tim
3DChief is offline   Reply With Quote
Old 05-20-2013, 04:14 PM   #76832
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Originally Posted by dresda View Post
Long live the mighty DR!
Amen to that!
Old 05-20-2013, 04:54 PM   #76833
TrophyHunter
Oddometer: 2,251
Thanks for the bash plate reminder. I witnessed one of those oil draining - tow your bike back to a road we can get a truck to - adventures. Been putting it off.
Ordered the PWD today.
Tuckers - yup. I think I've done 7 DR's NSU's. 3 family & the rest for ridin' buddies. Sounds like you have one down, 1 to go.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 05-20-2013, 05:11 PM   #76834
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,999
Yes, one to go. Better get right on it
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 05-20-2013, 05:25 PM   #76835
ER70S-2
ER70S-2's Avatar
Oddometer: 6,778
Originally Posted by 3DChief View Post
Just changed out my cush rubbers today......WOW! It's like I have a brand new bike. I got the bike about a year ago with 16,000 miles, and apparently still the original cush rubbers. I did 8,000+ miles cruising around the US last summer, plus lots of local riding. It's now at 28,000 and I can't believe the difference! Shifts are much smoother, so is deceleration, I didn't realize how much slop was in the hub! I had to use some spray silicone to get the hub back together enough to fit in the swing arm since the new rubbers were so tight. I'm a believer now, if your drive feels sloppy at all, change those babies out!
Tim
Good reminder, I'll be putting mine in when my new wheel bearings get here (this week).
Fastest:
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-20-2013, 05:56 PM   #76836
procycle
procycle's Avatar
Oddometer: 2,389
Inside the stock muffler
I took an old stock muffler to the band saw. Here's the inside view:
More pics and info can be found here at DRRiders
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 05-20-2013, 06:17 PM   #76837
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,732
Last year, on several occasions, I said "If I could only have one bike it would be the DR.". Well, it has come to pass. The BMW just left on a trailer. I'm a bit sentimental about it but its the only bike that I've cried about since our BSA Rocket III left.
Yup. I did the excact same thing. I just really enjoy the DR. Found myself reaching for the DR everytime and the GSA was being shunned.
Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 05-20-2013, 06:38 PM   #76838
ER70S-2
ER70S-2's Avatar
Oddometer: 6,778
Thumb
Thanks for taking the time to cut, photo and draw.
You could put that and the DRRiders link in the DR650 Index so it doesn't get lost forever.
http://www.advrider.com/forums/showthread.php?t=636381
2013 WR250R
Old 05-20-2013, 07:29 PM   #76839
JagLite
JagLite's Avatar
Oddometer: 1,336
Thumb CS seal retainer
In case you haven't noticed, Procycle is now selling the genuine Suzuki DR650 counter shaft seal retainer.
I don't think losing a seal is at all common, but one of my DR's came to me with a very leaky seal (drip-drip-drip...) that had been glued in badly.
Leaking isn't a drastic problem but if the seal pops out while you are riding... you probably will not know it and it will not take very long to lose all the oil and then have your engine seize up. A locked up rear wheel that will probably be covered with oil will certainly ruin your day.
And then a total engine rebuild that will cost big money.
I am installing the seal retainer on my other DR (that does NOT leak a drop) also just for safety insurance.
I destroyed a car engine once by losing oil and not knowing it...
Thanks Jeff for adding the retainer to your stock!
Even though you already had a nice custom piece.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is online now   Reply With Quote
Old 05-20-2013, 07:53 PM   #76840
procycle
procycle's Avatar
Oddometer: 2,389
Now that Suzuki has a solution there's no reason for us to make our own. That is until Suzuki runs out and they go on terminal back order (that might already be the case). When Suzuki runs out we can always make more of our own.
Old 05-20-2013, 08:02 PM   #76841
DockingPilot
Oddometer: 9,732
Are they both equally effective Jeff?
Frank Reinbold
Old 05-20-2013, 08:07 PM   #76842
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,723
Only one bike. I'd probably just end my life.
Old 05-20-2013, 08:20 PM   #76843
procycle
procycle's Avatar
Oddometer: 2,389
Sure, it just has to stop the seal from being pushed out.
Old 05-20-2013, 08:29 PM   #76844
ketur
dat stonk
ketur's Avatar
Oddometer: 29
Hey guys! First post here, was waiting for this moment: just came home with a 2003 DR650 with 8,000 miles on it. I'm upgrading from a KLR 250 that I rode for three years, felt it was time for an upgrade!
I've been reading this thread on and off for a few months now, it's a great resource and sold me on a DR650. I was first looking into a DRZ400, but then found out the larger-displacement dual-sports fit my riding needs more. Technically a KLR 650 would have been 'better' but I love the look and mechanical simplicity of the DR too much to pass up.
There's a massive list of maintenance the PO seemed to disregard, including proper rear wheel alignment... but to my pleasure I think the base gasket is the newer metallic one since I see tabs sticking out!
It has an aftermarket exhaust but he gave me the stock one... I think I may put the stock one on and see how that feels, might be easier to hear if there's the proper jetting. No idea if any jetting mods were made but there's also a K&N filter... I wonder if I'm running a bit too lean now.
Anyways the bike so far rides like a dream though; it's unbelievable what I've been missing.
ketur is offline   Reply With Quote
Old 05-20-2013, 08:32 PM   #76845
BergDonk
BergDonk's Avatar
Oddometer: 3,722
Do we know why Suzuki decided to produce their own? Does someone actually monitor the forums, or did they have enough warranty claims, or.....?
I'm intrigued, and I feel sort of humbled in some ways, having made a few for sale, but got bored making batches, but confirming that there is a market for them, then PC got their latent design up and available, and now Suzuki themselves. Be interesting to see if they are attached standard to the 2014 model, along with possible BNG.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Times are GMT -7.   It's 01:22 PM.
