Old 08-10-2006, 12:30 AM   #766
Tantrum
Condescending Nag
Tantrum's Avatar
Oddometer: 516
Curious to know if anyone has calculated miles on reserve for a Clark tank?
DR's are like potato chips- you can't have just one.
99' DR650 SEX "The Doctor"
99' DR200 SEX "Herbie" the Looove bike
"Life's odyssey is not to arrive at the grave safely, in a well preserved body but rather to skid in sideways, totally worn out,shouting,"...holy shit...what a ride!"
Blessed are the flexible, for they will never be bent out of shape
The purpose of fun is to have it
Tantrum is offline   Reply With Quote
Old 08-10-2006, 05:31 AM   #767
rockt
Oddometer: 1,166
Originally Posted by InertiaDR650
how many kms are you guys getting from one of those safari tanks ? or the ims ?
I've gotten over 400 kms with the IMS.
rockt is offline   Reply With Quote
Old 08-10-2006, 01:27 PM   #768
Vampire
Vampire's Avatar
Oddometer: 138
Originally Posted by jamodu-fishbulb
does anyone know the volume of reserve in a 34lt safari tank?
ive just put mine on and i think i should carry a 5 litre jerry can when i test it...
That's what I did, carried a 5 litre jerry can, that is, when testing the reserve.
The issue of reserve has more to do with the design of the fuel tap and it's compatibility with the tank shape. I believe that the Pingel fuel tap is commonly used on Harleys. For a given fuel tap design, a long flat tank will have a greater reserve than a tall narrow tank, simply because there is a greater volume of fuel at a shallow depth.
The answer is a longer primary intake tube.
Does anyone have a contact at Pingel, I can't find anything on the internet?
Wayne
I refuse to grow old until I grow up.
Vampire is offline   Reply With Quote
Old 08-10-2006, 03:41 PM   #769
AKParrothead
Alaska Motonaut
Oddometer: 68
Are you IMS tank guys dumping the fuel trapped on the rt. side of the bike over to the left. I don't know how much gets caught there but it may make a difference.
'97 DR 350
'08 Ural Patrol
AKParrothead is offline   Reply With Quote
Old 08-10-2006, 04:04 PM   #770
rokklym
one man wolfpack
rokklym's Avatar
Oddometer: 4,453
My IMS tank should be here on Monday, so anyone have any suggestions? Anything I should do or keep an eye on when installing? The IMS must come with a petcock? and it needs a better O-ring and the vaccuum line plugged?
Check out the Blog!
MotoGraphic
MotoGraphic Tumblr
Chad Berger DR650, KTM 990 Adventure R
Lone Wolf Expeditions
rokklym is offline   Reply With Quote
Old 08-10-2006, 04:24 PM   #771
M1Jeep
M1Jeep's Avatar
Oddometer: 1,958
Laugh
The petcocks lately should be good to go. I got mine last year and they had a batch of bad petcocks, which they've since replaced with good ones. Also, you shouldn't have to worry about the o-ring. Just take it out of the box and mount it on!
Rich
My YouTube
M1Jeep is offline   Reply With Quote
Old 08-10-2006, 06:31 PM   #772
rowend
FNG
Oddometer: 40
Just got my IMS about two weeks ago. Was leaking after two days. Don't even waste your time, get the o-ring.
The biggest fish in the river got that way by not being caught.
rowend is offline   Reply With Quote
Old 08-10-2006, 11:32 PM   #773
AKParrothead
Alaska Motonaut
Oddometer: 68
IMS ships with a bad rubber gasket for the petcock. Both of mine were eaten by the gasoline as was three others that I know of. The fix however is easy.
1) go to hardware store and get a square of good quality rubber that can withstand gasoline.
2) use crappy IMS gasket to model a new better one from rubber sqaure.
3) throw away crappy gasket.
4) install new gasket with petcock.
5) ride hard, longer with IMS tank.
'97 DR 350
'08 Ural Patrol
AKParrothead screwed with this post 08-10-2006 at 11:33 PM Reason: typo
Old 08-11-2006, 08:53 AM   #774
drpplepew
Oddometer: 2
Eek corbin seat
hi i'm new here...just bought a corbin for my dr...is it easy to install..?
drpplepew is offline   Reply With Quote
Old 08-11-2006, 09:01 AM   #775
Stackator
F800GS goodness
Stackator's Avatar
Oddometer: 1,343
Install
How does (2) side cover screws and (2) bolts sound? I reckon it would be quicker to fit the seat than place your post.
Enjoy your comfy ride
Golf courses are Enduro parks waiting to be discovered
Refresher for the Australian forum: http://www.deakin.edu.au/current-stu...outs/apost.php
Stackator is offline   Reply With Quote
Old 08-11-2006, 09:48 AM   #776
drpplepew
Oddometer: 2
thanks..i reckon i'm not much of a mechanic
Old 08-11-2006, 12:38 PM   #777
snowrider
snowrider's Avatar
Oddometer: 1,099
The petcock that my IMS came with already had an O-ring groove machined into it, so it was as simple as installing a proper O-ring instead of the gasket.
snowrider is offline   Reply With Quote
Old 08-11-2006, 12:55 PM   #778
Billy V
Oddometer: 8
Yes, and yes.
Billy V is offline   Reply With Quote
Old 08-11-2006, 01:03 PM   #779
Billy V
Oddometer: 8
Regarding the IMS fuel Petcock.
IMS sent me the wrong petcock when I purchased the tank last year. They wanted Me to drill out through the 2 holes in the bottom of the tank, making 1 Large hole to accommodate for their mistake.
I said No, send me the correct 2 pipe fuel petcock w/ the correct gasket.
The did finally admit to me that they were out of stock on the proper fitting petcock and it would take a couple of weeks for them to sent me the correct one.
I advised them to OPEN another box and take one out and sent it to me, or send a call tag for their tank. I had the new correct petcock in 3 days after that phone call.
--Heres a Pic of the incorrect petcock they tried to push on me. it was crap compared to the 2 pipe petcock I finally received.
Old 08-11-2006, 01:31 PM   #780
bonedale
Oddometer: 104
Is this just a trip to the local auto store to get a o ring that fits? Or is there any specific info for getting one.
Getting ready to pull trigger on the IMS soon.
bonedale is offline   Reply With Quote
Times are GMT -7.   It's 06:25 AM.
