Old 06-27-2013, 02:41 PM   #78016
yourdrunkdad
I just wanna ride!!
yourdrunkdad's Avatar
Oddometer: 243
Being new to the DR is there anything else besides what We have already discussed that I should look for?
yourdrunkdad is offline   Reply With Quote
Old 06-27-2013, 02:46 PM   #78017
refokus
Just Learning
refokus's Avatar
Oddometer: 2,493
http://www.advrider.com/forums/showthread.php?t=366046
Read this
The dr650 one of course. It has some great details. Can this thread, lots of good info floating around.
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 06-27-2013, 02:59 PM   #78018
Thunderjet
Oddometer: 31
Went to the dealers today and looked at a 2013. Count me in! Like the idea it can be dropped and most likely picked back up with very little damage.
Disliked the hard seat and bike was not as tall as I thought it was. If it can be lowered 1.5 inches by the dealer it should be perfect for my 5'10 frame. Since we just moved into a new house and area lots going on this summer so I don't plan on buying one until the end of August then I'll have the winter to add the farkles and break it in on the highway as you can pretty much get out and ride once a week in Colorado even during the winter.
Thunderjet screwed with this post 06-27-2013 at 07:55 PM
Thunderjet is offline   Reply With Quote
Old 06-27-2013, 05:01 PM   #78019
netsuke
netsuke
Oddometer: 36
Can you get rid of the ignition and just conceal an on/off switch somewhere ? I realize the ignition is a kind of on/off switch, but a complicated one with a diode, barrel for the key etc... For me , less wires is better ! Any advice please ?
Since 1976 : Yamaha 50ss, Honda xl125, Kawasaki z1300, Suzuki gsxr750, Honda vfr 800, Yamaha xtz660, Bmw r1100r, Bmw r1150gs, Bmw r1150rt, Bmw r1150gsa, Bmw r1150 gs/se, Yamaha sr500, Yamaha tdm900, Bmw r1200gsa, Triumph Thunderbird 900, Bmw r1200gsa + Bmw r80g/s ParisDakar + Suzuki DL650 ('12)
netsuke is offline   Reply With Quote
Old 06-27-2013, 05:06 PM   #78020
805gregg
Just Stroming along
Oddometer: 1,574
Disliked the hard seat and bike was not as tall as I thought it was. If it can be lowered 1.5 inches by the dealer it should be perfect for my 5'10 frame. Since we just moved into a new house and area lots going on this summer so I don't plan on buying one until the end of August then I'll have the winter to add the farkles and break it in on the highway as you can pretty much get out and ride once a week in Colorado.
Just find a used one, I got a '96 for $1900, with only 10,000 miles, I'm 5'11 with a short 30" inseam and my DR is just the right height,a Sargent seat will cure the seat problems
805gregg is offline   Reply With Quote
Old 06-27-2013, 05:08 PM   #78021
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,696
Originally Posted by 8gv View Post
So the tutorial linked above refers to shimming the needle to get rid of "surging".
What is the definition of "surging"?
My bike comes on really strong from about half throttle and up. By comparison, the first half of the throttle is fairly mild. Would shimming help or must I drill the slide?
Of these two actions, which will hurt my gas mileage more?
The biggest help for what you describe, and for surging, is to get a 14 tooth C/S sprocket. The best way I could define surging is the seems to speed up and slow down almost imperceptibly when you are riding at a constant throttle setting.
The sprocket change eliminated that for me, and adds a bit of yank in the low end. I could not see any difference in the MPG. I did shim the needle and remove the snorkel, and it added a bit more low end response. Again, no measurable change in MPG. Mine almost always gets 50-53.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 06-27-2013, 06:13 PM   #78022
8gv
Oddometer: 2,496
I've noticed that while holding it steady at less than half throttle, it feels like I'm lightly pulsing the throttle. I've just today received a 14t sprocket. Does removing the snorkel make it louder or more susceptible to drowning?
50 or better mpg is fine for me.
8gv is online now   Reply With Quote
Old 06-27-2013, 06:17 PM   #78023
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,522
The coming on strong at half throttle has been my experience with stock DR, you can fix this by getting a different needle, moto lab sells the adjustable needle that is a good needle, can be moved up and down, i also have put a DJ needle in and left the stock main jet in, made the bike run real strong at all throttle positions, from right off idle, but fuel mileage was only in the low to mid 40s, probably was a too rich set up, but i did it and liked it.
I would not drill the slide, some do, but i think if you get the needle set up right you may not feel the need to.
I just recently installed the moto lab needle along with a new needle jet, i have not had time to play with the clip positions, jets etc to get it right, will be working on that soon, i hope to get better fuel mileage than the DJ needle and still have the lower end pull i want.
ChromeSux is online now   Reply With Quote
Old 06-27-2013, 06:28 PM   #78024
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Amateur on soft sand with a dr650
I'm new to motorcycle riding. Bought a new DR650.
Took it for the first time on sand tracks. Here is a short clip:
http://www.youtube.com/watch?v=S2nMMxCP-Zc
[IMG][/IMG]
I've already dropped my bike twice on sandy patches
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 06-27-2013, 06:37 PM   #78025
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Read this
Here is a better link:
http://www.advrider.com/forums/showp...2&postcount=32
Old 06-27-2013, 07:07 PM   #78026
refokus
Just Learning
refokus's Avatar
Oddometer: 2,493
Originally Posted by Adv Grifter View Post
Better? Really?
Old 06-27-2013, 08:08 PM   #78027
Adv Grifter
Oddometer: 6,128
Better? Really?
I should have said "more direct".
Old 06-27-2013, 08:33 PM   #78028
GSF1200S
Oddometer: 976
Alright, I have ridden from Florida to Alaska and all over here and the Dr has been great to me so far (yes grifter, that means 3rd hasn't blown yet). When I'm back in Florida, I'm considering the 3rd gear swap as I believe that will pretty much eliminate the potential of catastrophe. I could be wrong..
So, since I'm going to tear the motor down, I have some questions for the group. If there is anything I don't like about the Dr, its that it doesn't have enough power on highway. I get it isn't a KTM or beemer, but I have been giving the 790 kit a look. I'm going to be going to south america and I need a reliable setup, so is there any consensus on the 790 effect on durability? I know power isn't free, but I figured I'd ask.
I'm also considering leaving the bore alone and going with an oversized head (pro cycle) and camshaft. I know the power gains are not as much, but I would suspect with larger valves the head should last as long or longer than the stocker and give me a little power in the process.
Fwiw, I have put about 13500 miles on the bike since I left and the valves haven't moved from where I set them. Also, is there some page with all the tricks to making a rear tire last? I will have destroyed a K60 in about 2500 miles, and everything else short of a road tire would be worse. I am very impulsive and turn down dirt trails off main roads frequently, so a road tire is no go. I know of the mefo explorer which I might try, but all the dual sport tires I ruin too quickly. I'm willing to compromise with wet both on street and in dirt so hard compound is no issue.
GSF1200S is offline   Reply With Quote
Old 06-27-2013, 08:53 PM   #78029
refokus
Just Learning
refokus's Avatar
Oddometer: 2,493
I'm just yanking your chain
Old 06-27-2013, 08:54 PM   #78030
Escaped
Escaped's Avatar
Oddometer: 488
For long life and reasonable performance, I really like the Metzeler Tourance (130 / 80 on the rear) tires on the DR650. I think because they are designed for the big dual sports they give extra long like on the DR. Negatives are that they are expensive and very difficult to change in the "Field".
I hate to even mention it (because its hard to believe) but I have put over 14,000 miles on each of my last two sets.
43,000 miles now on my 2006 DR650
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Times are GMT -7.   It's 05:42 AM.
