Old 07-24-2013, 08:29 PM   #79051
8gv
Oddometer: 2,488
I've never ridden with hand/lever protection...
and now I think I should. So what do you guys like? Is the name "Bark Buster" now a generic term? Are they good? Are there better? How's the fit with no changes to stock levers and stuff on bars?
Thanks.
8gv is offline   Reply With Quote
Old 07-24-2013, 08:51 PM   #79052
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 411
You can spend as much as you want on hand guards, but they are all pretty much the same. Some are fancier than others and install easier, but the cheap ones work just as well as the expensive ones in my experience. I got mine from ProCycle. All will require a little bit of manipulation to make fit, but it is not difficult. The trick to installing them is to leave all of the bolts loose until you get it lined up how you want it, then tighten them down while holding it in position.
If you still have the stock bars, you might want to look at new bars while you are installing the hand guards and have to move stuff around anyhow. Mine (96) still had the stock bars and they had been tweaked a little bit, so I replaced them with new Pro-Taper bars with a higher bend for better ergonomics while standing, plus new grips since all the "bite" was worn off the original grips.
Tim
3DChief is offline   Reply With Quote
Old 07-24-2013, 09:20 PM   #79053
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,980
Thanks.
I don't think Barkbuster is the same as Kleenex, but maybe some people do. I have Barkbusters and like them. I haven't tried anything else. They are good. I don't think there are better and they fit with no changes to stock levers and stuff on the bars (although I don't have stock bars )
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 07-24-2013, 09:32 PM   #79054
TrophyHunter
Oddometer: 2,245
I took Grifter's advice (if memory serves) and went with some Tusk brand handguards thru Rocky Mtn ATV/MC. They're reasonably priced, installed easily and have held up well on some spills.
I've had a variety and they've all done their job but the price was right on the Tusk.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 07-24-2013, 11:27 PM   #79055
Carbster
Carbster's Avatar
Oddometer: 77
Question Biggest carb?
What's the biggest carb you've seen mounted on a DR?
I have gone pretty big, 790, 4mm oversized valves, cam, mega port work and pipe/header. My fcr 39 can't feed it. I'm talking with someone more knowledgeable than me about boring 43-44mm.
Has anyone done such a thing?
Carbster is offline   Reply With Quote
Old 07-25-2013, 12:19 AM   #79056
Thumper Dan
Oddometer: 325
Thanks.
Highway dirt bike makes some robust handguards. Although expensive, look at their site and you see why you pay a bit more.
http://www.highwaydirtbikes.com/HDB_...ref=handguards
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 07-25-2013, 04:02 AM   #79057
greer
Oddometer: 3,821
cush drive shims and EK link
Yep, I believe I posted about shims a few months back; went that route after I read about it here:
http://www.advrider.com/forums/showthread.php?t=825325
Another thing, the EK screw-type chain link (scroll down a bit on the site):
http://www.ekchain.jp/feature/index.html
About 4,000 miles on it now and it looks just like it did when I put it on there. I've always used clip links but every now and then I'd lose one and it would unnerve me a bit, especially on long trips. But I didn't know if I trusted myself to rivet a chain properly, plus I'm too cheap to buy a good rivet tool. The EK link presses the plate on as part of the install, so it's a no-brainer. I think it'll be the ticket for me from now on.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 07-25-2013, 04:13 AM   #79058
Ever Onward
Time Killer
Ever Onward's Avatar
Oddometer: 812
It just keeps gettin better !
After the success of the Motolab carb parts, I went and did a bit more service the other night.
Lubed the chain with Blue Dupont teflon spray, Changed oil and filter useing high end Castrol 10w-40, adjusted the enrichener plunger to be sure there was some slack in the cable to FULLY seat it in the carb. I readjusted the idle mixture screw again to get it spot on also..
I took the long way to and from work yesterday to make a 91 mile test loop.
Conditions were no wind, slightly hilly pavement with a bit of overgrown double track short cuts for a few miles. Speed on pavement was 50 - 60 MPH and 1st gear putt putt in the short cuts.
In 91 miles I used 1.45 gallons of non ethenol fuel.....thats 62.75 MPG !
Im not gonna mod a single thing on the airbox / engine or exhaust !
Ever Onward is offline   Reply With Quote
Old 07-25-2013, 04:31 AM   #79059
thump!
thump!'s Avatar
Oddometer: 1,504
Sarah
I have a good chain rivet tool (D.I.D.) and I nearly always rivet my chains because it's just one less potential failure point AND a failed chain can be catastrophic. That said I put a clip style link on my son's SV650 in order to "use up" a partially worn chain taken off my DL before an extended road trip. However, I safety wired the clip link. That was required protocol on tracks back when clip links were the standard.
thump! is online now   Reply With Quote
Old 07-25-2013, 05:06 AM   #79060
AKASY
Noob
Oddometer: 2,170
Guards
Thanks.
IMHO two issues on a stock DR. Go to the Pro Cycle site and go to controls, then to the hand guard kit. In my experience on my last two DR's clearance for the hand guards over the levers was an issue. The Pro Cycle kit worked for me--cleared the stock levers. Second issue is what size bars do you want. If you are going to the larger bars from the 7/8 stock then get the bars and the guards that are compatible together and install them together. I stayed with the stock 7/8 bars.
Don't make the mistake of believing everything you think.
AKASY is online now   Reply With Quote
Old 07-25-2013, 05:41 AM   #79061
brucifer
brucifer's Avatar
Oddometer: 2,483
Talk to Cyclewizard. You can usually find him on the Honda XR650L thread. He has modified carbs to work with his full-house 742cc XRL engines. He may be able to help you with something for your DR.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is online now   Reply With Quote
Old 07-25-2013, 05:53 AM   #79062
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 789
Rochester 4 barrel ?
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 07-25-2013, 05:58 AM   #79063
greer
Oddometer: 3,821
Thank you, thump!
I always sealed the clip with silicone, but safety wire would be the real deal.
By the way, if you were to re-lube your starter, would you use something other than the DuPont stuff next go round? I got a little early-morning squawk wanting to back. Thanks again.
Sarah
'08 DR650
Old 07-25-2013, 06:25 AM   #79064
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
Thank you, thump!
Sarah
If you're going to the trouble of lubing your starter bushing, you might want to do it right and put the Warp 9 cover/bearing in, instead. Then you won't need to do it again.
Emmbeedee is online now   Reply With Quote
Old 07-25-2013, 06:27 AM   #79065
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,654
Thanks.
I use the term like the term Kleenex, so yes from my stretch of the world.
The 'bark busters' I bought are Moose Racing, and I like them... but I haven't fully tested them like some of my enduro racing friends used to. But Moose has been around a long time, and seems to make (or sometimes rebrand) OK parts.
For my uses, since I live in a state that is hot more than not, I didn't go for the extra plastic hand guard extensions on top of them - more air to he gloves this way.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave screwed with this post 07-25-2013 at 06:33 AM
Mambo Dave is online now   Reply With Quote
Times are GMT -7.   It's 06:01 AM.
