Old 10-25-2013, 10:16 PM   #82981
TRAVELGUY
Old Traveler
Oddometer: 637
Both of my DR's had that issue until I took what seems like I have taken all the play out of the lever adjustment. Then went into neutral no problem. With cable adjust like that I never had any problems for more that 20k miles.
TravelGuy
Originally Posted by gaahrdner View Post
I'm finding it difficult to get into neutral gear. I measured the play of the clutch lever and it is within spec, and when I had the case off and measured the plates they were OK as well. What else should I do, or is it a known issue?
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 10-25-2013, 10:31 PM   #82982
Rocktown
Reformed
Rocktown's Avatar
Oddometer: 323
Question
Originally Posted by ER70S-2 View Post
Wow, I'm a whole page behind; may have been 205'd
The following will make sense if you've towed someone with both a chain and then with a nylon tow strap.
Towing with a chain requires a skilled driver with a soft touch on the throttle. If not, the snatching chain will shake every nut and bolt in both vehicles. With a nylon strap, even a teenage girl (while texting) can tow a second vehicle with no conflict. However there will still be drama. With women, there will always be drama.
I don't know why you think a cush hub costs torque, it just cushions the hammering to the driveline of a 650 single with a power stroke once every 720 degrees of rotation. At 4000 rpm that's 2000 impacts per minute, think Jackhammer. Take your bike out and short shift at 2800-3000, roll the throttle on. Feel that banging in the footpegs? It's always there, that's why doG invented cush hubs.
Dirt bikes don't have cush hubs because the cushioning is taken care of by the slippage of the tire against dirt surface.
My xr650l didn't have a Cush drive and neither did the ktm 360 exc. both seemed to do just fine on pavement without it. I guess I really don't understand what the difference is. They both also wheelied easier (ok I know the ktm isn't a fair comparison). So it seems to me that there must be some torque being displaced or dampened. But maybe I'm just not understanding. Or connecting the wrong dots.
Rocktown is offline   Reply With Quote
Old 10-25-2013, 11:34 PM   #82983
ER70S-2
ER70S-2's Avatar
Oddometer: 6,130
Originally Posted by Rocktown View Post
My xr650l didn't have a Cush drive and seemed to do just fine on pavement without it.
So..............did you have 53,xxx miles on your KLR XRL?
Not fair
Although in a previous life, balance point wheelies were my passion (two stroke, 100 pounds lighter), the DR has completely denied me the pleasure (like my ex). It's been said "The DR wheelies so easily, it's almost like cheating." There are numerous youtube vids showing said antics.
Whatever is going on, it isn't the cush hub.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-25-2013, 11:36 PM   #82984
Gebogen
Gebogen's Avatar
Oddometer: 522
Cush
Better clutch on the ktm. More frequently replaced clutch on my honda. I suspect a cush drive hub is more expensive to produce as well. My little NX250 has a cush hub too so maybe it's a street thing. Both the NX and the DR came with Trail Wings stock and we all know how well they do off road...
Be Good, or be good at it.
Gebogen is offline   Reply With Quote
Old 10-26-2013, 06:15 AM   #82985
psmcd
Oddometer: 918
more cush
I just bought a DR350 that does not have a cush hub. You can feel every transition of throttle position and gear change. It chirps the tire on every downshift unless I'm careful to rpm match. I studied the cush sprockets and eventually I'll buy one, once it comes up in the farkling priority list.
I don't think there would be an issue with a cush hub on a race bike other than weight. What you might give up in instantaneous power transfer, would be more than made up in traction. But then that might be personal bias. I like cush, not hammer.
psmcd is offline   Reply With Quote
Old 10-26-2013, 07:28 AM   #82986
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,823
Originally Posted by FlowBee View Post
Why so hostile?
How do you judge whether your bike is actually in neutral or not? Most of us rely upon the green neutral light, which is triggered by the NSU. And if you judge a difficulty in getting the bike into neutral by the green neutral light then you will mis-diagnose an issue with your transmission. The most common issue with the NSU is, of course, the screws backing out and allowing slop in the engagement point of the neutral position.
And if it's not the NSU, are you sure it wasn't one of the other two alternatives?
This isn't JM. I'm just trying to help, ferchrissake.
Not being hostile what so ever,just asking a sensible question.
The green light hadnt been mentioned,just hard to get into neutral.
Most bikes shift into neutral easily while moving,many are hard to get into neutral at rest. With the gearbox spinning the shift forks can move gears around no problem. At rest the linkage and forks are being stressed to move gears back and forth. Just rocking the bike back and forth a little with the engine off can allow it to slip into neutral easier.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 10-26-2013, 07:30 AM   #82987
Foot dragger
singletracker
Oddometer: 12,823
It will still chirp the tire with a cush hub,shifting smoothly is how to make it not chirp the tire on downshifts.
Old 10-26-2013, 07:34 AM   #82988
Foot dragger
singletracker
Oddometer: 12,823
Originally Posted by MrBob View Post
Go back a few pages. This issue was extensively discussed since many of us are dealing with it. Cable adjustments rarely solve the problem.
On my DR,the cable adjustment needs to be done with the engine warm or hot,it changes a little from hot to cold and it needs to be right to shift well.
Old 10-26-2013, 07:41 AM   #82989
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,002
DR350 "S" models have a cush hub that will go right on. Probably not much more that a cush sprocket for price difference. Especially after a couple of sprocket replacements.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-26-2013, 08:36 AM   #82990
x32792
Cracker American
x32792's Avatar
Oddometer: 790
Best 80/20 Tires?
My stock Trail Wing is getting square on the back, so new tires will be needed soon...
Anyone care to weigh in of what are the best 80% Road / 20% Dirt tires?
TIA
John
It's all fun and games until the flying monkeys attack
x32792 is offline   Reply With Quote
Old 10-26-2013, 08:47 AM   #82991
GSF1200S
Oddometer: 976
TIA
John
What type of off road? Just dirt roads? Sand? Rocks?
GSF1200S is offline   Reply With Quote
Old 10-26-2013, 08:57 AM   #82992
TrophyHunter
Oddometer: 2,167
80%..... Depends on the dirt you want to do but the Shinko 705 is more road oriented and performs well in a lot of dirt. I have a set (thx JP) but we don't get sloppy mud here.
I mostly run the Shinko 244 for all around use. Inexpensive, pretty quiet on the road, decent traction for most of my uses.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 10-26-2013, 08:59 AM   #82993
psmcd
Oddometer: 918
Cool, thanks for the 350 guidance on the 650 thread. Hope this ain't some kinda thread infraction.
Old 10-26-2013, 09:03 AM   #82994
GSF1200S
Oddometer: 976
I figured I'd ask as even 10% off road could require knobbies depending on what it is. That said, the shinko 244s were likely to be my response. Maybe a shinko 244 front and a 705 rear? If gnarlier off road, IRC TR8 front and 244 rear; the tr8 is about the same price as a 244 but more aggressive. It won't last as long, but it will last a long time for a knobby
Old 10-26-2013, 09:04 AM   #82995
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 25,936
Hard to find Neutral
Here's the link of what was discussed previously. The NSU screws have nothing to do with it.
http://drriders.com/topic6671.html
Presione dos para español.
cyberdos is offline   Reply With Quote
Times are GMT -7.   It's 06:44 AM.
