Old 03-24-2014, 02:44 PM   #89866
Mudgee
06' Vstrom650
Oddometer: 12
Who has done the most mileage on their DR? Mine is brand new and I'm planning on doing at least 150,000km on it.
Mudgee is offline   Reply With Quote
Old 03-24-2014, 02:44 PM   #89867
thump!
thump!'s Avatar
Oddometer: 1,444
Originally Posted by Kommando View Post
It can depend on how much power your bike puts down (dependent on tuning, engine condition, altitude, etc.), and what kind of load/aerodynamics you're dealing with on the bike.
I didn't like 16/42 riding 2up with luggage on a mostly-stock DR with just the Procycle carb kit and a UNI filter at sea level with just moderate headwinds. 15/41 was about as tall as I liked. If you don't ride 2up, or your DR puts more than 40WHP down, you might like gearing taller than 15/41.
If you fight headwinds a lot, your passenger/luggage load is fairly "considerable", or your DR isn't putting down more than 35WHP, you may prefer the stock 15/42 or some shorter gearing.
BTW, I don't use a fairing/screen.
I agree with Kommando but for me a more significant question is why would someone choose this bike for that kind of duty. You CAN do it just as you can ride single track on an FJR1300 but neither one would be much fun IMO.
thump! is offline   Reply With Quote
Old 03-24-2014, 02:44 PM   #89868
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,569
temp
Originally Posted by thump! View Post
The difference in observed operating temperature may be due to the location of the sensor. The OP has his sensor mounted under the old pipe banjo nut so he is measuring oil temperature. If you have your sensor mounted under the spark plug as recommended by a TrailTech you are measuring cylinder head temperature. Temperture readings from those two locations could be significantly different.
Trailtech do offer an alternative sensor that bolts in to the sump, I believe, as an alternative to the Spark Plug Ring. I chose to just go the way I did and it has worked out nicely. The vapour comes stock with the spark plug setup because it's cheaper for them to produce and supply but offer the alternative, more expensive option aftermarket. Obviously the two locations (spark plug or oil) are going to offer different ranges of temps.
My logic was that a water cooled engine temp guage measures coolant temperature and not cylinder head temperature. So an oil cooled bike like the DR650 could also measure oil temp in a similar way.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 03-24-2014, 02:47 PM   #89869
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 26,632
Originally Posted by DockingPilot View Post
Right, I just swung it (the oem filter) over to that hose. Not sure is does anything at all, but it cant hurt I guess.
But that smaller hose (the one "that has nothing") does run to the carb like I got it, correct Cyber ? Take a look-see for me
The top hose is correct. It it the carb vent.
The bottom hose, well, I've got no hose where you have a hose.
I can double check when I get home but I'm pretty sure i don't have anything connected to there and I just checked the parts fiche and I don't see any hose there either.
Presione dos para español.
cyberdos is offline   Reply With Quote
Old 03-24-2014, 02:51 PM   #89870
ER70S-2
ER70S-2's Avatar
Oddometer: 6,471
Originally Posted by cyberdos View Post
two vent hoses?
I think DP added the yellow filter to this hose. Looks like it could use it. I'm pretty sure it's the float bowl vent to atmospheric pressure, there's very little actual air flow.
Originally Posted by Falconpunch01 View Post
Which sprocket set would be good for people who go over 75 a lot. Hypothetically let's say a friend
Edit . Dirt riding is like 3ish%
Hypothetically ...
I like the lower rpm the 16/42 gives me at 60+ mph, I'm running it right now. But I don't use 5th until 50+ mph. When the snow melts, and I can ride the forest service roads again, I'll go back to the stock 15/42.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 03-24-2014 at 02:57 PM
ER70S-2 is offline   Reply With Quote
Old 03-24-2014, 02:52 PM   #89871
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,615
Strike that request Cyber.
I have it all correct lookign at "KezzaJohnsons" pic
and you doubted me.....
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 03-24-2014, 02:55 PM   #89872
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 26,632
what the hell is all that extra crap on there?
Old 03-24-2014, 02:55 PM   #89873
DockingPilot
Oddometer: 9,615
Yes, thats what I did ER70S. And I just slightly re-routed it over away from the airbox "blowhole" so as not to block it.
Frank Reinbold
Old 03-24-2014, 02:58 PM   #89874
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,277
Non USA bikes have electric crap on the carbs.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 03-24-2014, 03:00 PM   #89875
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 26,632
hose to nowhere.
http://drriders.com/topic6730.html
brilliant.
edit: damn, 205'd by ER himself.
Old 03-24-2014, 03:02 PM   #89876
ER70S-2
ER70S-2's Avatar
Oddometer: 6,471
Snooze, ya loose
2013 WR250R
Old 03-24-2014, 03:14 PM   #89877
sandwash
sandwash's Avatar
Oddometer: 1,358
Lower roller gone,looks like it unscrewed itself out.Going to get a double bearing/sealed one.Looks like it gets screw on the back side of the side stand switch.Yes?
97dr650
sandwash is offline   Reply With Quote
Old 03-24-2014, 03:15 PM   #89878
cyberdos
Easy Bonus Loop
cyberdos's Avatar
Oddometer: 26,632
Do yourself a favor and leave it off.
it committed suicide for your own good.
oh, you said lower? hmm...
Old 03-24-2014, 03:49 PM   #89879
TrophyHunter
Oddometer: 2,215
Some answers probably HERE
Hope it helps make your decision. Off the top - Adam sold his DR with 75K Miles on the odo and somebody here still has it.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 03-24-2014, 04:03 PM   #89880
ER70S-2
ER70S-2's Avatar
Oddometer: 6,471
Yes
2013 WR250R
Times are GMT -7.   It's 11:16 AM.
