06-24-2012, 10:25 AM
#15676 |
Oddometer: 212
pulls
Hi Mint, Ax that mechanic and let the dealer know why IMHO, I run my sprocket in the center of the chain when I adjust it and I have no pulling problem, and it should not leak fuel at any time, they all do it is a poor excuse
just my thoughts on the subject.
06-24-2012, 11:47 AM
#15677 |
Oddometer: 60
Sounds to me like the Rover dealer I once boght a Mini Balmoral
I bought it brandnew in the 90ies there and when I had serval issues in a few months with the car, the dealer asked me why I bought such a crap car in the first place. I was speechless.
06-24-2012, 11:49 AM
#15678 | |
Oddometer: 8
I still think it is the rear wheel that is out of alignment. |
06-24-2012, 12:03 PM
#15679 |
Oddometer: 60
I did a longer trip a week ago. I loaded my iPhone at the plug for about 3 hours (bike was off). Then when I wanted to start, not even the cockpit lights turned on. I hooked the Batterie at a car and it took some time to get it started. First it only klicked and then it finally fired. No problems with inbeteewn stops on the way back. bike fired up as always. This morning the bike would only klick but not start. Took some time hooked to my Mini to get it startet. Rode abot 70 km and tried again: nothing. Hooked to a car again, and it took nearly 20 minutes to get it started. Only klicking inbetween. Now back at home, it started as usual. Now I'm loading the batterie and see what happens. Considering the batterie is broken , the alternator or the voltage-regulator isn't working. What do you think?
06-24-2012, 12:37 PM
#15680 |
Oddometer: 212
chain
smt925, the sprocket in the center of the chain and not off to one side, when it is centered it tells me I have the alignment correct, if you look at the rear sprocket at the teeth you can see if it rides in the center or if it is pulling to the left or right, when correct it should ride in the center of the chain, I was told this early on in riding because the marks are not always correct when you adjust a chain, hope this helps.
06-24-2012, 08:43 PM
#15681 |
Yep! That's me...
Oddometer: 112
Exploring the back roads... In Quebec's Eastern Townships.
06-25-2012, 11:14 AM
#15682 | |
Oddometer: 8
06-25-2012, 12:27 PM
#15683 | |
Oddometer: 8
First check that connections at battery are clean and tight. Charge battery and check voltage with engine off start engine and check for voltage increase( you might have to increase rpm above idle to see a increase in voltage) If connections were clean and tight and bike is charging the battery is most likely dead. Think about getting a battery tender and plug the bike in especially in the winter when it is cold and you might not ride as often as the rest of the year. I have a '06 still using the original battery with no problems so far. |
06-26-2012, 12:49 AM
#15684 |
Oddometer: 60
Battery is only 3 months old. But I got a hint.
There might be a problem with the switch at the clutch lever. If there is a loose contact, that might be the reason why the bike will not start imedialtey after bypassing the batterie to a car. After servalt attempts, it might work. I'lll check.
06-26-2012, 03:11 PM
#15685 |
Ted Simon Acolyte
Oddometer: 208
I had this happen a couple of times when I was on a trip as well, where the bike was showing neutral, but I think was slightly in gear, and therefore wouldn't start. I stomped it into first and it came to life on the next button push. Might not be exactly what is wrong but it sounds a bit similar, with the bike not even clicking over.
Watch out for snakes! - Crow T Robot 2000 Honda Sabre (Sold) 2010 Triumph T100 Black |
06-28-2012, 05:55 PM
#15686 |
Tiger Cub
Oddometer: 406
a little ride on the Scram...
http://foothillryder.com/sabmag-rock...smr-cedaredge/
A bit over 2500 miles start to finish. Turns out the Scram isn't terrific loaded above 75mph, especially with a headwind. Having thoughts about swapping for an early model Tiger. PM me if you have an interest. The Scram is a fine little runabout; but on the road it can be a little twitchy and nervous. Still a fun time, and we made it without issues.
- FoothillRyder AMA# 289558, BIR #47, COP #001 '97 Trophy 900, '98 Tiger, '03 Speed Triple 955i My Blog: http://foothillryder.com/ |
06-28-2012, 08:26 PM
#15687 | |
Dork
Oddometer: 19
GIANT LOOP Coyote on a Scrambler
http://twolf.zenfolio.com/img/s2/v50/p796909388-4.jpg http://twolf.zenfolio.com/img/s3/v44/p1043086761-4.jpg http://twolf.zenfolio.com/img/s3/v45/p514933430-4.jpg |
06-29-2012, 12:17 AM
#15688 |
I'm not an alcoholic.
Oddometer: 258
I have used the Ventura luggage system on several long trips on the Scram. I'm very happy with it. Plenty of capacity for my needs.
Jon Semper Fi 1963 - 1969. A/1/11, B/1/14 |
06-29-2012, 10:25 AM
#15689 |
Oddometer: 60
My packed Scram
When I'm doing longe distances with the Scram, I use a racepack (http://shop.sw-motech.com/cgi-bin/co...typid=67867624) and a waterproof roll. The racepack is waterproof and easy to fix on the bike. You can even get a tent roll for it to click on.
06-29-2012, 05:30 PM
#15690 | |
Oddometer: 77
vibration @ certain rpm's
2nd gear around 2000-2500 rpms there is quite a vibration in the front end. Makes the windscreen make a lot of noise. I'm surprised others haven't had this issue. Doesn't seem to be problem with the forks, front wheel or any usual suspects of a vibration like that. No one else experience this?
Allan 2007 Triumph Scram 2008 Ktm XC 300 2001 LC4 640e > sold Super Tenere > sold |
