Old 07-08-2012, 05:29 PM   #15751
thistle66
Oddometer: 360
Originally Posted by goodcat8 View Post
I usually throw one wrap of electrical tape around the bar under the control for a snug fit.
oooh, good tip. I dremmelled mine off a long time ago when I changed bars but the clutch side rotated round a touch since then.
thistle66 is offline   Reply With Quote
Old 07-08-2012, 05:58 PM   #15752
ep!c
Pannier Manufacturer
ep!c's Avatar
Oddometer: 210
Laugh
Originally Posted by mint julep View Post
Hey ep!c, bravo, looks really good!
I'll be following your trip, as my dream is to do a RTW on my scram too.
Any more pics of the frames and how its mounted? Maybe give me some ideas to do mine.
Thx.
Cheers,
Dave
Dave, it's not my bike. I built this setup for a customer. I'm. Also planning to build him a custom aluminum box that will attach on the inside of the exhaust side frame, that will be used for tool storage. If you send me an email at gosolobox@gmail.com, I'd be happy to provide you with more pics of the frames. BTW, I of course "had to" take the scrambler out for a "test ride".. Awesome bike!!
Solobox
360-840-7139
gosolobox@gmail.com
ep!c is offline   Reply With Quote
Old 07-09-2012, 12:14 AM   #15753
TerryK
Ulysses
Oddometer: 1,242
Fitted the Triumph skid plate today
Triumph Scrambler Blue & White Staintunes, bashplate
Triumph Thruxton Red, Staintunes
Yamaha TT-R250, B&B bash plate, Staintune
Check out my Youtube channel http://www.youtube.com/user/KaneTerry?feature=mhee
TerryK is offline   Reply With Quote
Old 07-09-2012, 07:12 AM   #15754
optical
Oddometer: 54
My bike went for bit of a swim.
Just moved to the NW Virginia area and was exploring some of the dirt / gravel roads around my house. Found a pretty sweet creek crossing and didn't do enough investigating before trying to ford across.
Got about 3 feet from the other side of the bank when the engine died - I was about knee high in water.
Thankfully, I was able to push the bike the rest of the way out. I let it sit for a few minutes while I tried to get some pictures (phone died, sadly) of what was now clearly a RIVER in my mind.
Pushed the start button and it tried, pulled the choke and the bike came to life. Fortunately, I was only 3 or so miles from the house and I got the bike home. I parked the bike and put it on its side stand and a wave came out of the left side cover.
I pulled that out and there was standing water / oil mix in my air filter
Drained the oil which was a nice creamy mocha color and pulled the air filter out and tried to soak up all the oil mix.
Put new oil in and a dried air filter and bike doesn't seem to know it was semi submerged. No problem with electrics so far... I'll probably pull the seat up later and just double check. Maybe put some more grease on the connections.
(for anyone interested, I have the EFI model)
So...
1) Bike rocks my socks. Can't believe it ran home after looking at it. Thing is a tank.
2) Clean up ideas? I've changed the oil once. Thinking of changing it and the filter again and then running it fairly hot to burn off any water.
optical screwed with this post 07-09-2012 at 07:23 AM
optical is offline   Reply With Quote
Old 07-09-2012, 07:53 AM   #15755
davevv
One more old rider
Oddometer: 2,206
Yes, I would definitely change the oil again. In fact, it is generally recommended to change it several times after an incident like that.
"Fast is fine, but accuracy is everything"--Wyatt Earp
'09 Electra Glide Classic
'04 Sportster XL1200R
davevv is offline   Reply With Quote
Old 07-09-2012, 08:16 AM   #15756
optical
Oddometer: 54
Should I run it at all between changes or just run oil through to run oil through?
Old 07-09-2012, 08:33 AM   #15757
HBN
plays in traffic
HBN's Avatar
Oddometer: 11,063
I know all about those woes...at Jeb Stuart
Old 07-09-2012, 01:08 PM   #15758
Steve SA
Adv Wannabe
Oddometer: 48
Originally Posted by rjf View Post
I suppose I should check in here since I picked this up last week.
As you can see my accesorising and photograph skills arn't up to the high standard set by others, i promise to try and improve both
Hi RJF. Congrats on your purchase. Guaranteed you'll be very happy with your new ride. The great thing with the 900 Scrambler is that you'll make it your own (with time) in the modifications (big or small) that suit your personality and riding style. If I must be honest this is the bike for me right now! Just loving it and I'm sure you will too (as we all do. that's why we're here).
Send us a few more pics of your 'beast' in the near future.
Steve
Steve SA is offline   Reply With Quote
Old 07-09-2012, 01:48 PM   #15759
davevv
One more old rider
Oddometer: 2,206
I'd run it a few minutes between changes to help pick up as much of the water as possible. I'd also use the cheapest oil I could find until you're satisfied things are clean and then go to your normal oil. You shouldn't have any damage at all as long as you get the moisture out of the internals quickly.
Old 07-09-2012, 05:55 PM   #15760
optical
Oddometer: 54
Drained it one more time but when I let it run again I noticed the headers are glowing red
I'm hoping it was because the bike was stationary at about 3k rpms and it was dark out.
optical screwed with this post 07-09-2012 at 06:32 PM
Old 07-09-2012, 09:31 PM   #15761
MightyChosen1
Flim-Flam Man
MightyChosen1's Avatar
Oddometer: 1,054
Anyone ever had any experience with the Procom igniter ?
I lost spark on the right cylinder this weekend. After checking everything it looks like the igniter has failed. No way in hell am I going to spend $670 for the Triumph replacement unit.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 07-09-2012, 09:31 PM   #15762
tvscum
tvscum's Avatar
Oddometer: 110
I was gonna complain about getting a 3" nail stuck in my rear tire and having to wait 4 hours for my buddy to come truck me out, but after that tale about the amphibious Scrambler, I'll just count my blessings over an Arrogant Bastard Ale.
But, hey, how did the river water get mixed with the oil? If it went through the air intake, what route did it take to get into the oil pan? Right past the rings? (I'm no engine expert!)
Current: 2012 Triumph Scrambler;
'97 Honda XR440 (plated)
Past: '83 Honda XR500; '84 Honda XL600;
'86 Yamaha XT350
tvscum is offline   Reply With Quote
Old 07-10-2012, 02:31 AM   #15763
optical
Oddometer: 54
breather tube from the airbox to the crankcase
Bummer about the nail!
optical screwed with this post 07-10-2012 at 05:05 AM
Old 07-10-2012, 05:16 AM   #15764
babble
Oddometer: 21
Tire question to dunlop
I'm just about to replace my trailwings with Dunlop TR91s, following extensive internet research! For thos intersted, here is an email i just sent to dunlop about the correct size to use. (you lot might know the answers actally!)
Hello,
I have a couple of technical questions concerning the TR91 tire.
1) For the TR91, on your site, for a rear rim size of 3.5 inches, you recommend the 140/80R17 tire. (http://www.dunlopmotorcycle.com/tire...dventure/tr91/)
But on another site in europe, for the Triumph Scramlber, which has a 3.5 inch rim, you recommend the 130/80R17 tire. (http://www.dunlop.eu/dunlop_euen/Ima...386-116951.pdf )
(where normally you would only recommend this tire for a 3.0 inch rim.)
- Which should i follow? The rim size or your bike specific recomendation, or doesn't it matter?
2) For the rear tire there is a choice of 110/80R19, or 100/90-19 for the 2.5 inch rim. For the scrambler the non-radial tire is recommended, but I have always been told that you should match the front and rear tires. Do you have any advice on this?
Thanks!!
Ben
babble is offline   Reply With Quote
Old 07-10-2012, 05:43 AM   #15765
TerryK
Ulysses
Oddometer: 1,242
Fitted heated grips to the Scrambler today, will make those cold rides much better.
Cheers Terry
Times are GMT -7.   It's 09:51 PM.
