Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 07-13-2012, 02:42 PM   #15796
BronkoRob
Oddometer: 72
i happen to have a triumph dealer about 20 minutes from my house....not sure if this is a good thing or a bad thing. i went out this morning to check out the scramblers in person.....yup i gotta have one!
everything felt good on the bike. i could feel how the seat could get to you after a long time. how does the solo seat with the rack compare to the stocker? lucky for me it was raining and i had flip flops on otherwise i may have made some rash decisions in there..lol so i didnt get to test drive one. i dont think i would be put off by the performance either way, my last bike was a KZ650 which felt fast enough for me.
EFI vs Carb? is their a significant difference in performance? how are the carbs on triumphs? are they pretty solid or on the finiky side? i can deal with carbs, not an issue, but i dont want to have to immediately start hunting for carbs on a new bike either. id rather hunt around over the next few months and find a used bike that has all the typical aftermarket goodies and save a few bucks. other than the motor going from silver to black, paint schemes, and carbs to efi, any other significant changes over the years?
i noticed the 2012 had dual guages, i kind of like the one larger guage and the smaller tachs you guys are putting on under the bars. what year did they go with the 2 guages?
No Pads, No Helmet.....Just Balls!
BronkoRob is offline   Reply With Quote
Old 07-13-2012, 03:00 PM   #15797
Extreme scrambler
Oddometer: 27
Originally Posted by Shercoman View Post
This is a very cool looking Scrambler.
Can you detail your mods?
Your suspension changes look like what I want to do.
Forks?
Travel?
Shocks?
Travel?
Sprocket sizes?
Rear travel looks longer,any chain tension issues?
Front brake?
Very nice job!!!
The front fork is a modified drz400e one and the rear shocks are custom hyperpro.
I lengtend the swingarm by 50mm.
I modified a bmw chaintensioner from a g650x.
The front brake is a galver disc with a brembo caliper
Extreme scrambler is offline   Reply With Quote
Old 07-13-2012, 03:08 PM   #15798
Extreme scrambler
Oddometer: 27
Old 07-14-2012, 08:52 AM   #15799
tvscum
tvscum's Avatar
Oddometer: 141
Originally Posted by delwilli View Post
I am considering fork mods on my 2012 Scrambler. I have kind of narrowed it down to the Bitubo fork cartridge kit vs. the Ricor intimidators with heavier springs. Both look like they would work well but I am kind of leaning towards the Bitubo setup as it is more "modern" technology. Have any of you first hand knowledge of the above units? The fork mods will be matched to either the Bitubo WMT or Works billet tracker shocks
Thanks in advance!
I recommend the Bitubo cartridge kit. See comments here:
http://www.triumphrat.net/twins-tech...th-photos.html
Current: 2012 Triumph Scrambler;
'97 Honda XR440 (plated)
Past: '83 Honda XR500; '84 Honda XL600;
'86 Yamaha XT350
tvscum is offline   Reply With Quote
Old 07-14-2012, 09:04 AM   #15800
LookoutMountainTiger
Oddometer: 127
Bars
Very nice bike, what handlebars are you running?
Originally Posted by Extreme scrambler View Post
This is my Scrambler.
It's still work in progress.
I did a 21" / 18" conversion,
I hope you like it.
LookoutMountainTiger is offline   Reply With Quote
Old 07-14-2012, 09:07 AM   #15801
Extreme scrambler
Oddometer: 27
It's a domino vintage mx bar
Old 07-14-2012, 09:33 AM   #15802
Shercoman
Oddometer: 457
What is the extended and compressed length on your shocks?
How much rear wheel travel do you have?
Did you add the 50mm length to the swing arm between the pivot and the shock mount or behind the shock mount?
Your rear sprocket looks much larger than stock.What gearing are you running?
And......did the changes make a big difference in the smoothness of the ride off road?
Sorry for so many questions but I think you have done exactly what I want to do!!
Shercoman is offline   Reply With Quote
Old 07-14-2012, 10:35 AM   #15803
Extreme scrambler
Oddometer: 27
I can't remember the specs of the shocks at the moment.
I have written it down.
When i find it i will let you know.
I added the 50mm between the pivot and the shockmount.
I used 19/47 sprockets.
It runs the same as before.
Old 07-14-2012, 03:59 PM   #15804
tvscum
tvscum's Avatar
Oddometer: 141
Are you saying there is no improvement in off road handling with the extended swingarm and 21" front tire?
Do you know what your travel is? Stock is what, 4 inches?
'86 Yamaha XT350
Old 07-15-2012, 12:11 AM   #15805
Extreme scrambler
Oddometer: 27
No, there is a big inprovement with the offroad handeling.
I meant that the gearing feels the same as before.
I don't know the exact travel it has now.
It's the max we could get out of it with out running in to problems with the chain.
Old 07-15-2012, 10:15 AM   #15806
Shercoman
Oddometer: 457
To those that are interested in more travel on their Scrambler.
I sent all of the dimensions for the swing arm and shock mounting locations to the engineer at Works Performance Suspension.
In his opinion,the maximum wheel travel on a stock swing arm is 7.5 inches.
This is based on suspension action,anti squat and chain considerations.
This is using shocks (custom made) with an extended length of 16.25 and a compressed length of 10.5.Shock travel 5.75
With triple rate springs he quoted me a price of $600 for the pair.
This much travel will require a chain tensioner to control the chain as it gets very loose at full droop.
I have a pair of Works Performance shocks that are 16.25 long but only 4.5 shock travel. This will give me about 6 inches of wheel travel. I am going to try these before having a custom set built and see how it rides.
I am going to finish the installation of the DR650 front forks and try these shocks.
Should make a big difference.
I'll post pictures when done.
Old 07-15-2012, 01:04 PM   #15807
xaman
Oddometer: 607
That's great, looking forward to your report
xaman is online now   Reply With Quote
Old 07-15-2012, 08:52 PM   #15808
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,259
Extreme scrambler, your bike is TITS!
Maxacceleration is offline   Reply With Quote
Old 07-15-2012, 08:55 PM   #15809
Shercoman
Oddometer: 457
Agreed!!!
Old 07-16-2012, 03:38 PM   #15810
DoubleCafe
DoubleCafe's Avatar
Oddometer: 114
Extreme Scrambler,
It's the bee's knees!
'14 Explorer XC, '07 Scrambler, '13 Ural T, '82 Montesa
'02 BMW 1150 GS, '13 Super Tenere, '06 Triumph Thruxton
DoubleCafe is offline   Reply With Quote
Times are GMT -7.   It's 08:11 PM.
