Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-22-2013, 04:00 AM   #16966
Kainic
Almost there
Kainic's Avatar
Oddometer: 386
Originally Posted by Sam il Cinghio View Post
Ciao Norris, hi all (this is my first post also).
Look here my 2001 Bonneville T100 turned into a Scrambler
There is a long list of changes (and pics), if you are interested I can translate from italian in my bad english.
Very nice looking bike you have there!
Sent from my iPad using Tapatalk HD
Kainic is offline   Reply With Quote
Old 03-22-2013, 04:12 AM   #16967
gseur
gseur's Avatar
Oddometer: 285
Originally Posted by Boola-Boola View Post
Ernie Vigil has posted, on his website, a great write-up on his Triumph Scrambler riding - covering a near 3000mile in 48hrs Border to Border run (Mexico - Canada - Mexico) and the ScrambleME video that followed.
'The Scrambler Story' on ernievigil.com at http://ernievigil.com/home/?p=360
Right on!!
Are you speaking about "Scramble me"?
Nice video but not new. I was thinking he has made a new one. I will enjoy a new one as nice as the first.
There aren't strangers, only friends you haven't ever met.
"You wouldn't understand, it's a Scrambler thing..." :TStorm
gseur is offline   Reply With Quote
Old 03-22-2013, 04:28 AM   #16968
greer
Oddometer: 3,821
Oh wow, Sam! Can we see some more pictures, please?!
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 03-22-2013, 04:54 AM   #16969
bighead3
Oddometer: 46
New Vid
Yes, there is a new one out with Ernie on the Scrambler and Nick Apex on a Tiger 1050. Here is a link. (hope it works)
http://www.youtube.com/watch?v=eewnPbh0ww8
bighead3 is offline   Reply With Quote
Old 03-22-2013, 05:10 AM   #16970
Sam il Cinghio
dirty noob
Sam il Cinghio's Avatar
Oddometer: 56
I'll try to reply to your questions
Originally Posted by Norris Packard View Post
Can a Bonneville T100 set up with better shocks
Of course, without problem you can change the 340mm Bonnie rear shock with 360mm Scrambler shocks (or better like Ohlins and many others); you can also mount the Scrambler inner tube on Bonnie outer tube, and adopt better springs .
But… besides the (poor) performances of standard Triumph suspensions, you must consider that ground clearance and particularly travel suspensions are inadequate to a REAL and intensive use on off-road.
and converted to the high pipes
Yes with 2to1 Arrow, Zard and others…
I figure if I change the front sprocket to a 17T, or even a 16T, that I can get about the same felt torque as what the 270 degree crank motor puts out..
Whitout changing the engine with a 270 degree, you’ll never obtain the scrambler torque.
However, in my opinion Bonnie torque it is yet adequate, anyway you can try with a 17T front sprocket (I think 16T it’s too much little... in this case I suggest to change the rear sprocket)
Because a Bonneville uses 1" handle bars it was difficult to locate a motocross bar that would fit but found these: http://www.biltwellinc.com/index.php...t_detail&p=185
Ok… you can:
- Mount a 1’’ (25mm) handlebar
- Mount a 28,5mm handlebar changing the risers
- Mount a 28,5mm handlebar modifyng the Triumph risers (look mine)
I was also planing on putting an Arrow 2:1 on it and know that I need to get the bracket and right side cover for that modification.
No problem for the bracket (for example the 2to1Zard it’s complete of his bracket); concerning the right cover you can cut the Bonnie right cover (look mine)
That's all, I think ;)
Sam il Cinghio is offline   Reply With Quote
Old 03-22-2013, 05:16 AM   #16971
Dcc46
Dcc46's Avatar
Oddometer: 509
Nice bike you got there Sam il Cinghio. I like it
“People sleep peaceably in their bed at night only because rough men stand ready to do violence on their behalf.” –George Orwell
Dcc46 is offline   Reply With Quote
Old 03-22-2013, 05:20 AM   #16972
Sam il Cinghio
dirty noob
Oddometer: 56
Sarah
Here some other pics :)
Details
Old 03-22-2013, 09:37 AM   #16973
Sam il Cinghio
dirty noob
Oddometer: 56
Sarah
I tried to link other pics, but if I have understood a moderator must to authorize my post.
Then... be patient ;)
Old 03-22-2013, 10:06 AM   #16974
Sam il Cinghio
dirty noob
Oddometer: 56
Originally Posted by Extreme scrambler View Post
This month I will be mounting a spring supported chaintensioner
Ciao Extreme, your work it's really interesting!
I'm thinking - from some time - to raise the Scrambler too.
My goal it is to find a little bit of ground clearance and above all a longer suspensions travel... but not too far from standard.
I found a KTM W.P. upside down front fork (travel 140mm) that raise the bike of 55mm, it must be coupled with a pair or 415mm rear shocks (travel 120/130mm... I'm still looking for them!).
But I have also some doubt, concerning the work of the chain with new bike dimensions.
How work the chain on your bike with new suspensions? Have you some pic of chai detail?
Also, the idea of chain-tensioner it is interesting: some detail?
Thanks in advance ;)
Old 03-22-2013, 10:47 AM   #16975
gseur
gseur's Avatar
Oddometer: 285
Yes, thanks, I've seen it, but not so perfect as the first one, in my opinion.
Old 03-22-2013, 11:32 AM   #16976
Aeon
Oddometer: 6
Amazing bonnie! If I may ask, what mirrors are those? They are nice - not too much deviation from stock but much cleaner.
Aeon is offline   Reply With Quote
Old 03-22-2013, 11:44 AM   #16977
Sam il Cinghio
dirty noob
Oddometer: 56
Of course you can ask!
They are "enduro" FOLDING mirrors, founded in a little shop here in Italy.
More more cheaper than stock mirrors (15/20 euro vs 150 euro!!!)
You can find (and buy) here, for example.
http://www.ebay.it/itm/Specchietto-E...-/150842742822
Old 03-22-2013, 11:52 AM   #16978
Sam il Cinghio
dirty noob
Oddometer: 56
Of course you can ask ;)
They are "enduro" FOLDING mirrors, you can found also on ebay.com (item location "worldwide") using key "specchietti enduro ripiegabili"
Much cleaner and much much cheaper than stock (in Italy the pair 15/20 euro vs 150 euro!!!).
Old 03-22-2013, 01:01 PM   #16979
Extreme scrambler
Oddometer: 27
I'm still working on the chaintensioner.
So I don't have any photo's at this moment.
If you want to raise your scrambler, you will need a chaintesioner.
Otherwise the chain will be to loose when there is no load on the bike and to tight when there is.
I will make some photo's as soon as I can.
Extreme scrambler is offline   Reply With Quote
Old 03-22-2013, 01:50 PM   #16980
ferals5
800+652
ferals5's Avatar
Oddometer: 1,164
Cool2
Very nice Sam il Cinghio
ferals5 is offline   Reply With Quote
Times are GMT -7.   It's 12:47 AM.
