Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-24-2013, 12:16 PM   #16996
Extreme scrambler
Oddometer: 27
Talking
Originally Posted by B02S4 View Post
From my perspective that is a favorable improvement. What, if anything, was done to prep the chrome?
Sorry I don't know.
When I brought it to the powder coat guys, it was chrome.
And when it came back it was black
Extreme scrambler is offline   Reply With Quote
Old 03-24-2013, 12:31 PM   #16997
tvscum
tvscum's Avatar
Oddometer: 139
Originally Posted by Sam il Cinghio View Post
I coupled this shocks with pressurized cartridge (Bitubo too) on front.
I have the Bitubo cartridge in front too. My spring rate is .85 and I weigh 195 lbs.
Can you tell me what your spring rate is? And, how many turns in from zero preload are you running? (the preload range is 0 to 15 turns, I believe).
Current: 2012 Triumph Scrambler;
'97 Honda XR440 (plated)
Past: '83 Honda XR500; '84 Honda XL600;
'86 Yamaha XT350
tvscum is offline   Reply With Quote
Old 03-25-2013, 07:20 AM   #16998
Sam il Cinghio
dirty noob
Sam il Cinghio's Avatar
Oddometer: 56
I weigh 170 lbs: with the same spring rate (.85) I have kept the preload at zero.
Sam il Cinghio is offline   Reply With Quote
Old 03-25-2013, 07:38 AM   #16999
Sam il Cinghio
dirty noob
Oddometer: 56
Originally Posted by Extreme scrambler View Post
Sorry I don't know.
Think the rack has been sanblasted, before powder coating.
Congratulations! Looks very nice! I like the seat too..
I have ridden with the bike, without a chaintensioner.
It can be done.
Butt if you should for example jump the bike, the chain can hit the frame and the swingarm.
I had made a nylon chainroller to protect the frame.
Thanks Extreme...
Yesterday I measured with 340mm shocks (Bonnie) and 360mm shocks (Scrambler): there is only a little difference, I hope that with 390mm shocks there is no need to add a chainroller.
In any case, I think that at first I'll can try with a rear sprocket bigger.
Old 03-26-2013, 05:31 AM   #17000
chasssmash
chasssmash's Avatar
Oddometer: 1,483
I ruined my rear pegs in an accident a while back. But now want to carry a passenger. The cost of new rear pegs is $300+. Is there a better solution - all I have left is the holes where the peg holder bolted on.
......Ok I found some replacement pegs which might work. They come with 10mm and 12mm bolts. Does anyone know the diameter of holes for the rear pegs- I think they may be 8mm but not sure. I may have to drill them out.
chasssmash screwed with this post 03-26-2013 at 06:29 AM
chasssmash is offline   Reply With Quote
Old 03-26-2013, 07:02 AM   #17001
fotopat
Pat / Cleveland, OH
fotopat's Avatar
Oddometer: 111
Scrambler saddlebag
Like a lot of fellow Scrambler owners, I am looking for a saddlebag solution that will be functional as well as stylish - that is to enhance the look of the bike. I came across a product from Klicbag and was wondering if anyone had gone this route and had some photos to share - the pics on their website do not show the bag on a Scrambler - would appreciate any info. Thanks.
"Ouch! That's gonna leave a mark!"
photos on shutterfly
photos on flickr
photos on panoramio
photos on SmugMug
fotopat on facebook
fotopat is offline   Reply With Quote
Old 03-26-2013, 07:39 AM   #17002
Sam il Cinghio
dirty noob
Oddometer: 56
The diameter of holes, just measured, is 10mm.
But... $300 for the stock rear footrests? Look here http://www.worldoftriumph.com/triump...lock_03=233015
Old 03-26-2013, 08:14 AM   #17003
chasssmash
chasssmash's Avatar
Oddometer: 1,483
This is awesome - thank you!!!
Old 03-26-2013, 10:33 AM   #17004
Extreme scrambler
Oddometer: 27
Thanks Extreme...
I think that 390mm shocks won't give you any problems.
You might have to change the front and rear sprocket.
I use 435mm shocks and lengthened the swingarm 49mm.
This gives it a 260mm ground clearance.
Old 03-26-2013, 12:01 PM   #17005
The Bighorn
Oddometer: 2
Originally Posted by davorallyfan View Post
Mine
my effort
The Bighorn is offline   Reply With Quote
Old 03-26-2013, 06:47 PM   #17006
grebmrof
Oddometer: 200
Their bracket should work on the left side, won't on the right. The bag does not seem to be well supported for it to hold much weight - but maybe that doesn't matter to you. To me it looks like the best brackets currently available for Scramblers are those from MetalMule - they have a U.S. rep. Their brackets are not cheap, but they are strong. You also might want to touch base with HappyTrails in Idaho - they might have something or be able to make a suggestion.
grebmrof is online now   Reply With Quote
Old 03-27-2013, 01:21 AM   #17007
Shining
Shining's Avatar
Oddometer: 59
Ciao Norris, hi all (this is my first post also).
Look here my 2001 Bonneville T100 turned into a Scrambler
There is a long list of changes (and pics), if you are interested I can translate from italian in my bad english.
Sam il Cinghio, from Italy?
Who is this man? I don't know him
Shining is offline   Reply With Quote
Old 03-27-2013, 01:41 AM   #17008
llubi
Oddometer: 9
Here some other pics :)
Details
Woooow!!!
Can you please explain what brake discs are this? Are compatibles with OEM bike? And the Pretech? Is also compatible with the bike without doing nothing special?
ANd the plate holder?
I just registered myself to ask you things!
Br,
Albert.
llubi is offline   Reply With Quote
Old 03-27-2013, 06:10 AM   #17009
Sam il Cinghio
dirty noob
Oddometer: 56
Originally Posted by llubi View Post
Woooow!!!
Br,
Albert.
Ciao Albert ;)
Front and rear brake discs are produced by an italian factory (ITAparts, Lecco, http://www.itaparts.it/dischi_freno_kit.html).
Note that the front disc is 320mm: I used the Thruxton outer tube with the Scrambler inner tube in order to replace the 310mm stock front disc.
But, apart from the size (310 or 320mm) these discs are perfectly compatible with the front wheel hub.
Also the Pretech is compatible with Triumph outer tube, and no needs adaptations.
The plate holder it is a "vintage replica" of older enduro rubber plate holder, and needs some adaptations (but also the rear mudguard isn't OEM, then...................... )
Old 03-27-2013, 07:55 AM   #17010
llubi
Oddometer: 9
Ciao Albert ;)
Ciao Sam :)
I'm really thinking in taking my car to visit you this holidays...!
So you're using discs for Beta Enduro in 320 mm on front... and same as OEM in rear, no?
And the tube, you just changed the outer tube and used the rest of your fork, never tought it was possible!
Can I copy your brakes?
Times are GMT -7.   It's 05:26 PM.
