Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 03-29-2013, 02:52 PM   #17026
Nick Newton
Oddometer: 3
Originally Posted by trustme View Post
Do not fit progressive springs , use a straight wound spring , maybe a Racetech which are available in different spring weights.Do a static sag check to assess what rate you want. Preload caps will help but they are a band aid if the basic spring rate is wrong
Have you looked at YSS shocks. Cheaper than O but a step up on Ikons , not sure about Nitros
I spent up on suspension but my bike is a keeper so I figured it was worth it.
PS I'm really enjoying the input from you Euro guys , keep up the good work , kind of inspires me to do more to the Scram.
My attention has been diverted away from the Scram a little by ' Winston ' but still riding it every weekend
Thanks for the advice. I'll take a look at YSS. What do you have on yours?
I rode around NZ back in '02 on a BMW 1150GS would love to do it again on a scram
Nick Newton is offline   Reply With Quote
Old 03-29-2013, 03:40 PM   #17027
trustme
trustme's Avatar
Oddometer: 972
Racetech springs & emulators up front. Ohlins at back , you don't need the separate resevoir type as the std shock has sufficient volume to stop overheating unless you are pushing way harder than normal.
trustme is offline   Reply With Quote
Old 03-29-2013, 08:27 PM   #17028
geezfools
geezfools's Avatar
Oddometer: 37
just gonna throw this out
finally put the arrow 2:1 on, as well as the airbox delete and holy shit, this is like a new bike. Hitting the ton shouldn't be much of an issue for this fat guy, booyah!
geezfools is offline   Reply With Quote
Old 03-30-2013, 08:50 AM   #17029
Simon T
Simon T's Avatar
Oddometer: 28
Dr. Who
For those of you in the UK and others that have seen this classic program that's been around for ever....Dr Who is riding a scrambler in the new series starting tonight!!!!
Simon T is offline   Reply With Quote
Old 03-30-2013, 09:16 AM   #17030
Goat_locker
Oddometer: 114
Nice!!
I'm in...the Tardis is going to need a bigger door.
2006 Triumph Scrambler
1971 Triumph T120RV Scrambler
2007 BMW R1200GSA Scrambler
Goat_locker is offline   Reply With Quote
Old 03-30-2013, 11:53 AM   #17031
Krahe
Krahe's Avatar
Oddometer: 658
Tire change question
Howdy, its been a while!
I am currently trying to remove the front wheel on my 08' and am having trouble. Can someone tell me what the process is?
I have the axle nut off, but the axle doesn't seem to want to come out. Am I missing something?
Thank you!
-Stock '07 Triumph Scrambler
6200 miles
Krahe is offline   Reply With Quote
Old 03-30-2013, 12:02 PM   #17032
Sam il Cinghio
dirty noob
Sam il Cinghio's Avatar
Oddometer: 56
Thank you!
Ciao Krahe , you have to slacken the bolt on the lower of the right front fork outer tube (see # 23 here http://www.worldoftriumph.com/triump...lock_03=233015)
My bike
Sam il Cinghio is offline   Reply With Quote
Old 03-30-2013, 12:15 PM   #17033
trustme
trustme's Avatar
Oddometer: 972
Hi Krahe , Kind of feels like Waldorf & Statler doesn't it.
Old 03-30-2013, 12:21 PM   #17034
satcen
satcen's Avatar
Oddometer: 210
2013 mods
Took her out today to test the 2013 mods. CBF 1000 brakes are must. They give great feeling & real BRAKE. M-lock keyless ignition seems to work but it needs some time to get some life experince. But Iīam a bit puzzled about new mosfet rectifier location - I expected it would be 100% cold but it isnīt. Donīt know if itīs just heat transition from the engine....
I will ride & see and may be drill some holes to the side cover.
Current bikes: Triumph Scrambler (09-), Honda CBF 250 (06-)
Bike history: Simson 50 Enduro (84-89), MZ 251 ETZ (90-95), Suzuki XF 650 Freewind (97-02), Aprilia ETV 1000 Caponord (03-09)
satcen screwed with this post 04-03-2013 at 01:55 PM
satcen is offline   Reply With Quote
Old 03-30-2013, 12:48 PM   #17035
Krahe
Krahe's Avatar
Oddometer: 658
Aha, there is a silver cap covering the head of the screw! Thank you!
6200 miles
Old 03-30-2013, 12:52 PM   #17036
Krahe
Krahe's Avatar
Oddometer: 658
Yes, I cant believe this thread is well over a thousand now!
I have been lurking once and a while. Moved back to the eastern states from Arizona. Haven't found so much as a dirt road yet, so now I am putting a fresh pair of TWs on the ol girl.
Hows things in the southern cross area?
I still plan on visiting the NZ some day...
6200 miles
Old 03-30-2013, 01:17 PM   #17037
bighead3
Oddometer: 46
Nice!
2013 mods
"Took her out today to test the 2013 mods. CBF 1000 brakes are must. They give great feeling & real BRAKE. M-lock keyless ignition seems to work but it needs some time to get some life experince. But Iīam a bit puzzled about new mosfet rectifier location - I expected it would be 100% cold but it isnīt. Donīt know if itīs just heat transition from the engine...."
Hey Satcen, beautiful bike! What is the black object between the rear shock and the number board?
bighead3 is offline   Reply With Quote
Old 03-30-2013, 01:34 PM   #17038
Sam il Cinghio
dirty noob
Oddometer: 56
It seems a tools box ;)
Old 03-30-2013, 01:44 PM   #17039
Sam il Cinghio
dirty noob
Oddometer: 56
Ciao Satcen, nice bike (and great mirrors ;) ;) ;))
No.
Mosfet RR heats less than OEM Shunt RR, but it heats a little bit all the same.
Then don't worry, and no needs to add other holes ;)
Please could you give me some infos about this?
Sam il Cinghio screwed with this post 03-30-2013 at 01:50 PM
Old 03-30-2013, 03:20 PM   #17040
satcen
satcen's Avatar
Oddometer: 210
2013 mods
Yep, H-D toolbox.
Times are GMT -7.   It's 04:23 AM.
