Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 07-17-2013, 09:26 AM   #17791
gumpt100
gumpt100's Avatar
Oddometer: 48
Originally Posted by Tritwin View Post
Good looking,but think it is to much Space between the front Wheel and the fender
Hi Tritwin, the space is the same between the wheel and fender because I used the standard bridge to mount the fender.
It looks a bigger gap because the alloy fender is narrower than the standard one.
Here is Henry's with a standard fender
Here is mine with alloy fender
Here is the difference between the two fenders,
We're all doomed!!!!!!!!
gumpt100 is offline   Reply With Quote
Old 07-17-2013, 09:36 AM   #17792
gumpt100
gumpt100's Avatar
Oddometer: 48
Originally Posted by Simon T View Post
That's a nice look....were the mudguards easy to fit?
Hi Simon, the mudguards were quite easy to fit.
The rear I cut to the length I wanted, then marked and drilled it to fit to the 4 rubber mountings that the original fixed to. I had to make spacers to go between the frame and the mudguard to make it fit right, and then used bolts with penny washers from underneath the fix it.
The front one I cut to length, re-drilled the original bridge on the centre line and tapped the holes. I used 2 bolts instead of the 4 originals, as they were quite close to the edge of the mudguard with it being about 1" narrower.
Old 07-17-2013, 01:03 PM   #17793
b0rderman
Oddometer: 134
thanks for the close-ups gumpt100...I have been meaning to get some sort of fender back on my rear...I installed an FEK but there's just too much back spray when I get on the wet dirt. I'll have to figure out how to get one to fit with some modifications to the FEK's taillight.
b0rderman is offline   Reply With Quote
Old 07-19-2013, 06:26 AM   #17794
manx_20
manx_20's Avatar
Oddometer: 426
Hi,
Possible new scrambler owner here. Since the engine on my bike puked a few weeks ago i've been looking for a replacement and want to try something new. I had a Kawasaki Versys which was a 6 speed. I do a lot of highway riding since that primarily how I get to work. Can anyone tell me at what rpm does the scrambler cruise at 80 mph?
Arek
┌∩┐(◣_◢)┌∩┐ Noo Joisey
manx_20 is offline   Reply With Quote
Old 07-19-2013, 06:57 AM   #17795
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,844
Originally Posted by manx_20 View Post
Hi,
Arek
The older Scrams didn't come with a tach and I have never really felt the need for one. Not sure what rpm you will get at 80 mph, but the motor will be comfortable at that speed even if you are getting the full wind blast on this naked bike. A fly screen helps smooth out the airflow and looks OK on the bike.
Rick, Chapleau, ON
Triumph Scrambler 900
Honda Trail CT90
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline   Reply With Quote
Old 07-19-2013, 07:01 AM   #17796
manx_20
manx_20's Avatar
Oddometer: 426
Great, thanks for the advice. I might stop by the dealer this weekend and try one on for size
Old 07-19-2013, 07:06 AM   #17797
hbmichael
hbmichael's Avatar
Oddometer: 625
Typically, i see about 4000 rpms at 70mph and just under 5000 rpms at 80mph, youre right in this bikes sweet spot at those speeds and still have plenty to hit the ton and just a hair above.
hbmichael is offline   Reply With Quote
Old 07-19-2013, 05:07 PM   #17798
optical
Oddometer: 64
Anyone get any wheel wobble with TKC 80s? Front wheel starts wobbling at 80mph
optical is offline   Reply With Quote
Old 07-19-2013, 05:10 PM   #17799
Donkey
Donkey's Avatar
Oddometer: 785
used to at 80 and after nh steering damper install, it's at 90.
sent from my iPhone 5 via Tapatalk
1978 BMW R100, pre-war, vintage inspired custom, black & white
1985 BMW R80G/S Paris-Dakar
2004 BMW R1150GS Adventure
2010 Ducati Monster 1100S abs
2012 Ducati Hypermotard 1100 Evo SP Corsa
Donkey is offline   Reply With Quote
Old 07-19-2013, 05:48 PM   #17800
xaman
Oddometer: 583
Mine has been steady at any speed, through three sets of TKCs...
xaman is offline   Reply With Quote
Old 07-20-2013, 04:40 AM   #17801
soundcc
Location: please, anywhere (on two wheels), but not here
Oddometer: 158
Steady wobble? or ?
soundcc is offline   Reply With Quote
Old 07-20-2013, 05:27 AM   #17802
optical
Oddometer: 64
I think I'm going to have them rebalanced and see if it fixes it.
Old 07-20-2013, 08:19 AM   #17803
ClineDesign
Grandpa
ClineDesign's Avatar
Oddometer: 383
Speaking from experience, having had mud caked under that front fender so badly that the bike would not move, more space is good!
ClineDesign is offline   Reply With Quote
Old 07-20-2013, 06:21 PM   #17804
xaman
Oddometer: 583
Originally Posted by soundcc View Post
Steady wobble? or ?
No wobble :)
Old 07-21-2013, 12:16 PM   #17805
Gormley Green
Gormley Green's Avatar
Oddometer: 74
Luggage sale
Just wanted to point out that I put my Ventura luggage system (complete) and OEM tank bag up in the flea market. They are in good shape and want to be used on your bike, buy them! Cheers
2010 Triumph Scrambler, the black one.
Gormley Green is offline   Reply With Quote
Times are GMT -7.   It's 05:36 AM.
