Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 01-24-2014, 12:40 PM   #19156
henryII
henryII's Avatar
Oddometer: 396
Originally Posted by blacktiger View Post
They don't look like they have any more travel in them. Just extra length.
Its more to a Ohlins setup than Just the extra length. The adjustment to fit the suspension to riding style and weight. Just try the differance on the s3 Vs s3r
________________________________________
[/URL]
henryII is offline   Reply With Quote
Old 01-24-2014, 03:20 PM   #19157
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,269
Anybody use the FreeSpirits rear caliper relocation bracket from New Bonneville? Were you able to install it without removing the brake line? I can't seem to make it fit. It looks like I will need to remove the line to reroute it from the master cylinder. Just moving to the top of the swingarm doesn't seem to yield enough slack to get the caliper to the mounts. Any hints? Any hints with photos(more better)?
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Old 01-24-2014, 04:16 PM   #19158
soundcc
Location: please, anywhere (on two wheels), but not here
Oddometer: 158
Originally Posted by soundcc View Post
Panama.
What engine crash bars are for real instead of the plant on garbage I have wasted my money having a time in the rafters laughing at a fool and his money. Dont dare say the factory with a stupid pipe tytogether "fix"
soundcc is offline   Reply With Quote
Old 01-24-2014, 04:26 PM   #19159
xaman
Oddometer: 554
See page 1241. One of the members here made it work, perhaps you can PM him... Post up here what you find out please, I just ordered mine today.
xaman is offline   Reply With Quote
Old 01-25-2014, 12:36 AM   #19160
ferals5
800+652
ferals5's Avatar
Oddometer: 1,161
You have to undo and reroute the line above the swingarm ( the claim that the original line fits is a marginal call from free spirits as it is a very tight fit , after hooking it all back up you must then bleed the caliper "upside down"
I'll be replacing the line later on with a slightly longer one as I think the swingarm will eventually wear the original line. I did 2500km last week so I should check it
I'll check and see if I have a pic for you...
It's a tight fit around the frame and the swing arm... so tight...my little finger will not fit between them to check for rubbing the sharp edge of the frame is probably the most concern...
ferals5 screwed with this post 01-25-2014 at 01:08 AM Reason: add pictures
ferals5 is offline   Reply With Quote
Old 01-25-2014, 05:55 AM   #19161
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,813
Panama.
That "stupid" tie together fix actually works. They are rock solid after adding the connecting tube.
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger is online now   Reply With Quote
Old 01-25-2014, 05:57 AM   #19162
ChuBrocka
ChuBrocka's Avatar
Oddometer: 130
I don't think he meant to insult. Pretty sure his point is that when spending that money you shouldn't have to mod it so it actually functions. As-built its pretty pointless.
ChuBrocka is offline   Reply With Quote
Old 01-25-2014, 06:19 AM   #19163
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,813
It wasn't taken as an insult. He called it stupid. And yes, you're right, you shouldn't have to modify it but when you do they become really solid.
Old 01-25-2014, 11:07 AM   #19164
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,087
Nice paint on this Scrambler on UK ebay.
Linked as photos are huge.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 01-25-2014, 03:50 PM   #19165
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,598
(not necessary to include the images in each and every reply!)
nice bikes....liking the '66, a lot.
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 01-26-2014, 10:26 AM   #19166
BiganDaft
BiganDaft's Avatar
Oddometer: 79
Some changes that I've done to my 2006.
Sent from my GT-P1000 using Tapatalk 2
BiganDaft is offline   Reply With Quote
Old 01-26-2014, 10:27 AM   #19167
RMAK
The Magnanimous
RMAK's Avatar
Oddometer: 347
I'm moving my Scrambler into a more desert rat/hare scrambler/kind of jack pine. I'm looking for fenders, either metal or fiberglass.
Anyone deal with these folks?
http://www.pjglassfibre.com/ShowCate...Rear-Fenders-9
Any good sources for light weight metal fenders?
Any interesting, easy methods for raising the front fender a tad? I guess I could use the flat washer spacing method, but hoping for a less tacky solution.
RMAK is offline   Reply With Quote
Old 01-26-2014, 11:22 AM   #19168
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,813
I'm sure Clive will be back to tell you how he did his...
Old 01-26-2014, 11:43 AM   #19169
RMAK
The Magnanimous
RMAK's Avatar
Oddometer: 347
Yeah, that's what I had in mind for the front fender.
I didn't even notice it though. I was looking at that cool seat. I pm'ed him to find out more.
Old 01-26-2014, 01:31 PM   #19170
BiganDaft
BiganDaft's Avatar
Oddometer: 79
Hi there,
Custom stuff is very scarce here in South Africa, so most of the work on the Scram is fabricated.
I wanted to "lighten" the look of the back of the bike, but keep the twin silencer look.
So, the first step was to take the seat of and look see what could be done.
The two rails that run to the back of the bike, where the original seat bolted into, were cut off just behind the shock mounts.
Then a pipe was rolled to create a link between the two shortened frame rails.
Next a aluminium plate was fabricated to fit on top of the frame, a tag was welded to the front to use the same mounting as the original seat pan.
At the back a plate with two captive nuts was fastened to the base to fasten the seat pan to the bike.
The wiring and CPU/ECU had to be relocated as there was not any space for it in the original place.
We have a huge bike scrap yard in Johannesburg called "Bike Hospital" where I managed to find a old front mudguard that looked right and this was then used as the rear mudguard.
The seat pan was sent to a bloke in Pretoria who built up the foam and covered it for me.
Because I wanted to keep the rear end clean, there are no indicators at the back, but I am using bar ends, which are quite clearly visible from front and back.
The tail/brake light, I have no idea where it's from.
I can take some more pics with the seat off if any-one is intrested.
Cheers from Sunny SA
Clive
Times are GMT -7.   It's 01:21 PM.
