Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 02-24-2014, 03:16 AM   #19456
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,749
Originally Posted by BiganDaft View Post
http://www.retrowriteup.com/clives-triumph-scrambler/
Link to an article that was written about my bike.
Thanks for that Clive. It really does look fantastic.
Did you have to lengthen the forks at all to accommodate the 21" wheel.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 02-24-2014, 03:21 AM   #19457
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,749
Originally Posted by Blinky03 View Post
Does anyone know the difference between the arrow two into one high exhaust for the carb'ed motor's and the later arrow system's for the fuel injected bikes - they have different part numbers - I'm considering fitting a late arrow exhaust system onto a 2006 carb'ed bike - the only difference I can see is the later model exhausts have the sensor attachment for the fuel injection system - would this effect a bike with carb's ?? I cant see how it would - someone out there will know the answer - thanks
As far as I know you've hit it. The only difference is the holes for the O2 sensors . My Arrow came with blanking plugs so that it could be fitted to carb models.
Old 02-24-2014, 07:19 AM   #19458
oldroadie
Two wheel addict
Oddometer: 468
Exactly. I used EFI headers on a carbed America and fitted the bungs with some shortened bolts (blanking plugs) with excellent results.
oldroadie is offline   Reply With Quote
Old 02-24-2014, 01:25 PM   #19459
henryII
henryII's Avatar
Oddometer: 383
Spot on :-) like your exhaust mufflers. How did u rise the front fender?
________________________________________
[/URL]
henryII is offline   Reply With Quote
Old 02-24-2014, 01:51 PM   #19460
gseur
gseur's Avatar
Oddometer: 271
Originally Posted by henryII View Post
Yes 200gram is the tube
Sent from my SM-N9005 using Tapatalk
So they are with tube?
There aren't strangers, only friends you haven't ever met.
"You wouldn't understand, it's a Scrambler thing..." :TStorm
gseur is offline   Reply With Quote
Old 02-24-2014, 02:02 PM   #19461
henryII
henryII's Avatar
Oddometer: 383
No they are tubeless that is the point with alpina.
[/URL]
Old 02-24-2014, 02:32 PM   #19462
IRideASlowBike
Oddometer: 1,786
Are there any disadvantages to aluminum rims?
IRideASlowBike is offline   Reply With Quote
Old 02-24-2014, 04:20 PM   #19463
bighead3
Oddometer: 46
Originally Posted by irideaslowbike View Post
are there any disadvantages to aluminum rims?
Yes $$$$$$
bighead3 is offline   Reply With Quote
Old 02-24-2014, 04:37 PM   #19464
IRideASlowBike
Oddometer: 1,786
Originally Posted by bighead3 View Post
Yes $$$$$$
Obviously; besides that?
Old 02-24-2014, 05:10 PM   #19465
Blinky03
Blinky03's Avatar
Oddometer: 22
Q: Do you still happen to have the part number for your Arrow ?
Blinky03 is offline   Reply With Quote
Old 02-24-2014, 05:23 PM   #19466
RealOldDualSportGuy
RealOldDualSportGuy's Avatar
Oddometer: 483
02 Blanking Plugs
Just a note:
Be certain to use a cooper washer between the plug and the bung in the header.
A bit of Never Seize will also insure that you can remove the blanking plug should you want to do so in the future.
Regards
I wont be wronged, I wont be insulted, and I wont be laid a hand on. I dont do these things to other people, and I require the same from them. John Wayne -- The Shootist (1976)
RealOldDualSportGuy is online now   Reply With Quote
Old 02-24-2014, 06:42 PM   #19467
Manray
Killing Time
Manray's Avatar
Oddometer: 130
Aluminum rims are much lighter than steel rims. In the past steel rims were stronger but present day aluminum rims are equally strong when built up as a wheel.
Manray is offline   Reply With Quote
Old 02-24-2014, 08:26 PM   #19468
BiganDaft
BiganDaft's Avatar
Oddometer: 78
@Blacktiger: I didn't need to extend the forks, all that has been done is the internals were replaced with the Norman Hyde springs and spacers.
@HenryII, the bracket that the fender mounts on was removed and a extra 30mm was welded onto the bottom "legs".
It is a tight installation because of the tops of the forks been slightly wider, but with a few washers as spacers it works, no problems for the last 30 000 odd kilometers.
BiganDaft is offline   Reply With Quote
Old 02-24-2014, 11:10 PM   #19469
geezfools
geezfools's Avatar
Oddometer: 37
And I had to get mine drilled for them, lol. I did only spend $200 on the exhaust, thanks to someone not knowing what they had, so an extra $40 to have someone weld a bung on for me wasn't the end of the world.
geezfools is offline   Reply With Quote
Old 02-25-2014, 09:20 AM   #19470
henryII
henryII's Avatar
Oddometer: 383
BC seat
Got the seat from BC, so I guess I am ready... almost :-)
[/URL]
Times are GMT -7.   It's 04:30 PM.
