Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 10-08-2008, 01:04 AM   #2731
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,510
Originally Posted by Goofy1
hey Davo, nice shocks!! Which version is that?
don't know how to tell ya tho--somebody stole your exhaust!
YSS ones - the same as Rhodie's He's me hero
Seriously, it was a tight fit and I took my staintune cans off to make it easier.
Now I need to know Rhodies settings to lift the back a bit as I'm scrapeing the pegs a bit too often now.
Dave
Knit fast, Dye warm.
Seventh Day Adventourist
davorallyfan is offline   Reply With Quote
Old 10-08-2008, 03:48 AM   #2732
Peter640
Peter 640
Peter640's Avatar
Oddometer: 331
Dead Scrambler
Mine died today in the city!
Three short coughs and either the CDI or the coil has carked it. Anyone else had a sudden death? The dealer talked of Asian manufacturing etc etc. More to follow once autopsy completed.
P
Peter
Peter640 is offline   Reply With Quote
Old 10-08-2008, 11:28 AM   #2733
trustme
trustme's Avatar
Oddometer: 988
P
Dead coils are not unknown on the triumphrat site, but I would have thought that would only cut out 1 pot. Mine died in heavy rain but was easily fixed.
Hope you are up & running soon , it is a bugger when these things happen.
trustme is offline   Reply With Quote
Old 10-09-2008, 05:00 AM   #2734
Peter640
Peter 640
Peter640's Avatar
Oddometer: 331
All good proved to be a loose wire on the CDI box ....
All good now ...
Peter
Old 10-09-2008, 01:42 PM   #2735
Skidplate865
Oddometer: 146
Dave - You can fit shocks w/ overflow canisters on the Scrambler (without removing the exhaust by simply mounting the shock the other way (see photo of my bike)
Dave
Skidplate865 is online now   Reply With Quote
Old 10-09-2008, 08:01 PM   #2736
Krahe
Krahe's Avatar
Oddometer: 658
Do any of you have any tips on how to clean the rims without scuffing up the chrome? My rear tire rim is a nice shade of grey right now, covered with road grime...
Also, davo what is that red jack you have a few pictures ago, under the center of the bike?
Nice pics as always.
-Stock '07 Triumph Scrambler
6200 miles
Krahe is offline   Reply With Quote
Old 10-10-2008, 05:43 AM   #2737
milkman
can't find my screwdriver
milkman's Avatar
Oddometer: 137
When I clean the rims - the stuff that doesn't hose off nicely (tar, chain lube etc), i just dab/spray some WD40 or Degreaser etc on, let soak a little and wipe off with paper towel.
Just avoid overspraying on the sidewalls obviously
Works pretty well for me
When I'm done sometimes I just wipe the rims with a really light coat of WD40 - makes it easier next time
milkman is offline   Reply With Quote
Old 10-10-2008, 05:57 AM   #2738
Bad-Tat
800 XC
Oddometer: 125
Skidplate,
That thing is way too clean for a Scram!!
Bill
1995 XR 650L, Tiger 800 XC, 72 Triumph T100R, 86 SRX 6, 05 FLSTSCI, 13 Vespa 300, 08 Versys, 14 Grom
Bad-Tat is offline   Reply With Quote
Old 10-10-2008, 06:30 AM   #2739
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
I use one of those ball-shaped foam things attached to the power drill to clean the spokes on the Bonnie in our motor pool -- after using something like simple green to get the majority of the spooge off the rim and spokes -- mines branded "flitz," but there's a bunch of em out there
careful what you use to clean the rims -- if the wheel weights are the stick on type, what will take oil chain lube and tar off the rim may also dissolve the glue that holds the wheel weights on --
you don't have to ask how I know
Old 10-10-2008, 06:31 AM   #2740
wiseanhyzer
wiseanhyzer's Avatar
Oddometer: 1,540
Clean Rims
Krahe,
I use store brand disinfecting wipes and a small rag. The wipes have all of 0.13% ammonium chloride in them, and foam up really well. Cuts through the grease and dirt VERY well. Requires that you go behind with a rag to get up all the greasy foam. It's hard to get in between the spokes with anything, but with the small wipes and rag you can kind of run them through like floss.
I wouldn't use anything rough or abrasive to brush the chrome. I'm sure you could get some wheel cleaner from the auto parts place that would work also. The Eagle One stuff I use on my truck wheels works really well and I bet it would work on the rims of our bikes too. I like using the wipes because I don't have to be careful where I spray the other.
wiseanhyzer is offline   Reply With Quote
Old 10-10-2008, 04:34 PM   #2741
metlcutr55
LongGoneDaddy
metlcutr55's Avatar
Oddometer: 894
saw one of these yesterday, sat on it, had a really nice old school enduro feel. felt lighter than i thought it would. what can be done to gain a couple more inches ground clearance? bike was stock, clearance looked to be about the same as my valk. i did look thru this thread a bit but dont want to look thru all 184 pages. thanks!
My mammy was a shewolf, my daddy was a bar.
I'm 200 pounds of tooth and claw, covered oer in har.
Half fire, half smoke, the other half thunder.
I am what you may call the 8th wonder.
Hey look out boys, get out the way, ladies get in line.
I aint perfect but almost, I'm dyin' if I'm lyin'
metlcutr55 is offline   Reply With Quote
Old 10-10-2008, 05:29 PM   #2742
davorallyfan
Commonist
Oddometer: 16,510
Yeah I thought of doing that but it didnt look right to me ... looks OK tho and I'm sure they work fine that way too.
Old 10-10-2008, 05:31 PM   #2743
davorallyfan
Commonist
Oddometer: 16,510
I's a cheap China made "cruiser lift" it works fine but takes up a bit of space in the garage tho.
Old 10-10-2008, 05:33 PM   #2744
Mudhen
Foul Adventurer
Mudhen's Avatar
Oddometer: 3,250
Where you been, you could have ridden mine when I still owned it!
Ground clearance-schmound clearance...the bike is just fine the way it is...
"Triumph over adversity is good for the soul." -- Packmule
IBA# - 18804
Bikeless
Mudhen is offline   Reply With Quote
Old 10-10-2008, 05:33 PM   #2745
Orpheus
more like fool sport
Orpheus's Avatar
Oddometer: 505
I would suggest getting the extra-long 370mm YSSG366TRCLshocks:
http://www.bellacorse.com/bcc138-40.htm
With the length adjustment, you can take it to 380mm, which is 20mm over stock Scrambler length. Then find some Honda F3 forks. Use the F3 internals and the Scrambler lowers. I've heard that the Scrambler and Bonnie forks are different lengths, but I've never seen any part numbers to confirm that. So theoretically the F3 forks should give you up to additional 1.375" of height (of course, you have to account for rake, but...) in front. Adjust the rear and front heights to suit your tastes of rake, etc.
Alternately, get some Works Performance shocks custom-built and find 41mm conventional forks from another bike (new KLR 650, Honda XR250R, a few others) that meet your length needs. Of course, eventually you'll need a fork brace (Superbrace makes a nice one) and in the rear you'll start to run into some chain rubbing issues.
2006 Triumph Bonneville T100 - I'll turn this baby into an adventure bike yet, even if it kills me (probably will).
1969 Honda CL350K1 Scrambler - On the road to recovery!
1966 Honda CL160 - Durrr not sure about this one yet.
Orpheus is offline   Reply With Quote
Times are GMT -7.   It's 07:31 AM.
