Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 02-12-2008, 05:52 PM   #721
M700
Oddometer: 421
Red, looks wonderfully warm and lush compared to where I've been riding mine here in Washington state!
Regards, Guy
M700 is offline   Reply With Quote
Old 02-12-2008, 06:27 PM   #722
[Red]
Intentionally Left
[Red]'s Avatar
Oddometer: 480
Spot on Dave, on the way to wombeyan
Looks bloody cold Guy!
It did start to rain on me shortly after i took that picture though.
All men dream... but not Equally.
Lawrence of Arabia
http://scrapheapadventureride.com.au
[Red] is offline   Reply With Quote
Old 02-12-2008, 08:16 PM   #723
jamboa
jamboa
jamboa's Avatar
Oddometer: 859
Thumb Scrambler Power Upgrades
I have a Bonnie with the 904 Big Bore and CR35 Racing Carbs. Dynoed at 73 HP if you are interested. The scrambler is a different cam design however.
04 Triumph 904 Bonneville SE
15 Yamaha FJ-09
13 CB1100F
15 Indian Scout
jamboa is offline   Reply With Quote
Old 02-13-2008, 07:34 AM   #724
jwrover
jwrover's Avatar
Oddometer: 633
Thanks RED...Next question then
Red,
If the 08's are fuel injected, how do people feel about the change? For instance, on the KTM 950 to 990 change to fuel injection it was seen as a big improvement as carb maintenance was a huge issue.
Is there an expected "great improvement" on the Scram's going from carb to Fuel injection? What is Triumph's history with Fuel injection systems? Good, Bad?
jwrover
jwrover is offline   Reply With Quote
Old 02-13-2008, 12:16 PM   #725
trustme
trustme's Avatar
Oddometer: 951
Carbs for me
One of the reasons I sold my sprint a got the scram was so I got a bike with carbs.Carbs are reliable, easy to service & easy to fix. You dont need to hook up to a computer to remap,You will probably be able to make a repair out in the boondocks which is hard to do with FI
Having said that , emmision regs seem to be killing off carbs & the Triumph FI on seems to work pretty well & is very reliable
FI can tend to operate a bit like a light switch at low revs,possibly a twin cylinder problem. I found the 990 quite disconcerting to ride at low speed , there just did not seem to be any finesse to small throttle openings at low speed & I can understand why that bikes owner uses his KLR 650 on dirt roads , it is an easier bike to ride
I wait with interest to see if FI on the scram gives the same type of gentle throttle response at low revs that carbs give but have not seen any feedback
I like carbs it is simple tried true & tested technology that works bloody well & that appeals to a techno dummy like me
trustme is offline   Reply With Quote
Old 02-13-2008, 12:29 PM   #726
trustme
trustme's Avatar
Oddometer: 951
Thumbs down Ps
Will probaly get better MPG on FI. Power figures appear to be pretty much the same. On Triumphrat site a lot of guys do quite major work to the air filters , air box , carbs etc to boost performance , I suspect things will not be so simple with FI
Old 02-13-2008, 01:48 PM   #727
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,086
I'm with trustme on both of his posts. FWIW, my carbed bike has worked perfectly in all kinds of temperatures and from sea level up to 10K+ feet elevaton. Nothing against FI, but so far no problems with the carbs either.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 02-13-2008, 03:14 PM   #728
[Red]
Intentionally Left
[Red]'s Avatar
Oddometer: 480
I agree with these comments too. I'm sure the FI will be great however I love the simplicity of carbs. Other than that I don't see it having a huge impact on the bike.
Lawrence of Arabia
Old 02-13-2008, 08:14 PM   #729
Mud Lightspeed
Mud Lightspeed's Avatar
Oddometer: 127
Tail Bag for scrambler
I would like to get a Tail bag for my scrambler for those short trips, and around town. Wolfmann and Ortlieb make some ok looking products but i am open to other ideas. Any thoughts or recommendations? Mainly I am concerned about heat from the pipes burning the material. Ideally it would be a roll top closure and water proof.(I'm not a fan of rain covers)
Mud Lightspeed is offline   Reply With Quote
Old 02-13-2008, 08:23 PM   #730
[Red]
Intentionally Left
[Red]'s Avatar
Oddometer: 480
Mud, I use an oxford tail pack. Straps just hook under the seat and there are no issues with heat. I don't have any pics of it on the bike but it's pretty much like this.
Lawrence of Arabia
Old 02-13-2008, 08:48 PM   #731
tri boy
Oddometer: 722
quick update guys. 9days into the ride, and the scrambler is purring.
It's engine braking has been invalueable on the steep loose rocky passes.
For those who wish to challenge their scrambler, riding some of the sth island passes is for you.
Gotta go. Running out of time online in Cromwell.
Trav'ln great distance....cause i just gotta.
tri boy is offline   Reply With Quote
Old 02-13-2008, 09:09 PM   #732
gomi no sensei
Oddometer: 13
Originally Posted by Orpheus
Gee whiz. For that price, you could have someone fabricate brackets (or modify Hepco & Becker brackets, which would be a piece of cake) and just use H&B aluminum cases. Oh, and you'd save about $700 in the process.
I just put in an inquiry with them about whether my H&B cases will fit in the Metal Mule frame. If so, even if it's crazy expensive, I'm going to consider getting it.
My custom frame is really heavy and only fits with my one-up seat. I'd like to be able to have a second rider without an ordeal to unmount the luggage frame.
gomi no sensei is offline   Reply With Quote
Old 02-13-2008, 09:20 PM   #733
[Red]
Intentionally Left
[Red]'s Avatar
Oddometer: 480
lookin forward to the pics tri boy
Lawrence of Arabia
Old 02-14-2008, 11:13 AM   #734
abruzzi
abruzzi's Avatar
Oddometer: 981
Originally Posted by jwrover
OK! So what is the practical technical difference between the '06 silver engine cases and the '07 and '08 black engine cases...other than the obvious, one is silver the other black...
Keep in ming that the 2008 models in the USA are still carbed. They will probably switch the US models in 2009.
Geof
http://tigertriple.com/
abruzzi is offline   Reply With Quote
Old 02-14-2008, 01:41 PM   #735
clamp007
Africaboy
Oddometer: 8
Scrambler
Here's my Scrambler I'm gonna take up the west coast of California. I've changed a few things, but desperately need to take care of the wind factor, as a recent trip made me want to sell it for that reason.
clamp007 screwed with this post 02-15-2008 at 09:46 AM
clamp007 is offline   Reply With Quote
Times are GMT -7.   It's 04:10 PM.
