05-12-2010, 10:01 AM
#9076 | |
Insanity Questionable
Oddometer: 459
Trample the weak, hurdle the dead. Jacob Mast Photography - site under renovation |
05-12-2010, 10:42 AM
#9077 | |
Oddometer: 459
![]() Good thought on the locknuts. Getting halfway through the trip and being pulled over for not having a license plate would be more than just embarrassing. "But, but officer....I swear I had one!"
05-12-2010, 10:48 AM
#9078 | |
Flim-Flam Man
Oddometer: 1,054
My shield did that too. I put blue loctite on everything I bolt on the bike I dont want to come loose, anti-sieze on the ones you want to. I found several bolts loose on my 08 already . Probably not a bad idea to check the critical ones everytime you change the oil.
Formally known as Furious D, I'm getting to old to be furious. |
05-12-2010, 11:43 AM
#9079 | |
Oddometer: 657
I have been riding for 2 years now and still consider myself a noob, maybe...maybe...after a decade I will upgrade my status to amateur. This site has definitely steered me in the right direction more than a few times. People Like MistaVern, DangerDave, Footdragger, Rhodie, TrustMe and others really provide a good backbone of wisdom for us newbies. I am just glad I had something to share.
-Stock '07 Triumph Scrambler 6200 miles |
05-12-2010, 12:33 PM
#9080 | |
beat up ex flat tracker
Oddometer: 6,929
I will try an allen head screw with anti seize and see what that does.
Some bikes around at times |
05-12-2010, 02:53 PM
#9081 | |
Knows all - tells some.
Oddometer: 12,972
- "The turd follows the fart as surely as the rain follows the plow." Emily Bronte |
05-12-2010, 04:02 PM
#9082 | |
Oddometer: 73
2010 Triumph Scrambler, the black one. |
05-12-2010, 06:33 PM
#9083 |
Oddometer: 1,254
I use the National Cycle Deflector shield and have never had a problem with anything coming loose. It's also fully adjustable for height, angle, and distance from the rider. Really works well.
![]() TStrom, I found it almost impossible to insert the holders into the shield itself until I carefully removed the flash from those little balls that are supposed to pop into the mounting holes. Used an emory board to clean them up slightly. .
Registered offender "picking up hookers, instead of a pen, the words of my youth slipped away" Waylon Jennings MX '06 http://www.advrider.com/forums/showthread.php?t=176637 MX '07 http://www.advrider.com/forums/showthread.php?t=278826 |
05-12-2010, 08:36 PM
#9084 |
Oddometer: 408
Max - Great Setup!
05-12-2010, 10:36 PM
#9085 |
CSMC
Oddometer: 1,045
Gratuitous scrambler next to a fence picture:
I do want to express myself, okay. And I don't need 37 pieces of flair to do it. |
05-13-2010, 05:46 AM
#9086 | |
Cap'n Crunch
Oddometer: 481
I used a hair dryer to warm the holders before attaching them to the shield.
Bob AMA #162726 LPR #54 `94 BMW R1100RSA `95 BMW R1100RSA `05 R1200ST `06 Triumph "Scrambled" |
05-13-2010, 05:51 AM
#9087 | |
Oddometer: 184
Current bikes: Triumph Scrambler (09-), Honda CBF 250 (06-) Bike history: Simson 50 Enduro (84-89), MZ 251 ETZ (90-95), Suzuki XF 650 Freewind (97-02), Aprilia ETV 1000 Caponord (03-09) |
05-13-2010, 07:37 AM
#9088 | ||
Oddometer: 1,690
With the rack height on the solo seat above the pipe by a good margin, smaller panniers can be mounted above the high pipe in a balanced symmetrical fashion. Keep the weight down and there is minimal penalty for higher mounted bags. Aluminum sheet, boxed, bridged or otherwise supported can have good strength. Width is only 32-33" overall (including panniers). About the same as my bars. I'm sure someone can/will brainstorm a better set-up. For me, I also have the large Moto-Fizz tailbag for tent, bag, pad, chair, table etc. I have already acquired this gear. It is compact and light. REI is my friend. My theme is compact and light. I do not want to be pinned or gorged with aluminum/metal boxes if I crash. Funny, I have since the beginning thought of me & this Scrambler in the easy going 'Then Came Bronson" style of travel. (I grew up watching it, sorry) Oh, I have done a similar centerstand mod as blacktiger has. Only with a rubber bumpstop. Probably a temporary fix. The answer is a derlin block. As soon as I acquire that I have a dependable long lasting solution for the PITA centerstand. I DO need a centerstand for adjustment & lube on the road. The Scrambler is the anti BMW/KTM... Cheers
Horsepower is a distant second to useable torque, unless cafe cruising is the reason for the purchase... Quote:
05-13-2010, 08:16 AM
#9089 |
Flim-Flam Man
Oddometer: 1,054
Max , That is a great solution for luggage . Too bad it wont work on my bike, I have the full seat and stock exhaust. I fabbed up a couple of systems for my bike using 3/8 stainless tubing but never was happy with the results and ended up with the MC Resources setup.
My shop walls are lined with little projects that I made but never implemented. I really like the way your plates are bent to cradle the bottom of the bag. Thats a nice touch I may use someday If you dont mind being copied a bit. As far as the centerstand goes. I have a couple ideas I am working on. I Already have the dimensions to improve the pivot bolts where the stand mounts to the frame . I cant understand why there is so much slop there. As soon as I get some lathe time I will make a new set of bolts and post the pics. The clunky part of the center stand drives me nuts. For now I use velcro straps. I want to design a latch to firmly grab the stand, but could be unlatched with your foot. my 2nd idea is to use magnets. McMaster Carr sells some pretty cool mounts made for supporting conduit/pipes to steel structures. I have used them in the past and they are super strong. Pics to come...
05-13-2010, 10:18 AM
#9090 | |
Oddometer: 6,929
Took 10 minutes and works like a champ so far,no rattles and stand moves easy enough when I deploy it. I would be embarassed to charge what Triumph charges for this centerstand and have it fit like China bike parts. Obviously their OK with it.
