Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 05-21-2010, 03:26 PM   #9226
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,190
Originally Posted by blacktiger
Go on.........you took it off?
Quite similar to what you have done bt.
Where you have hex heads, I have done rubber, which did deteriorate by the end of my 1500 mile trip.
While it lasted... Silent centerstand!
I am searching down derlin plastic now for the replacement, which I will carve in a 'U' configuration as the rubber is, shown below.
Derlin is used in chain guides on swingarms on dirtbikes.
I hope derlin has the durability for the centerstand to vibrate against the boss on the frame.
Maxacceleration is offline   Reply With Quote
Old 05-21-2010, 03:43 PM   #9227
Edgewise
Edgewise's Avatar
Oddometer: 12
Still looking for an easy (way) out.
Over here we have things called "easy outs". These things are like a thread tap and have a very coarse reverse thread on them. You drill a hole down the centre of the piece you want to remove and tap/screw one of the easy outs in and it will/should undo.
Easy outs .... Hmmmm ... believe I have a couple in my tool box. However, the brake pivot bolt screws in from the inside of the frame. What I really need is a backwards easy out. Kind of like a ... duuuh ...case hardened, coarse threaded, metal screw. Never mind.
Onward through the fog....
Edgewise is offline   Reply With Quote
Old 05-21-2010, 03:45 PM   #9228
Edgewise
Edgewise's Avatar
Oddometer: 12
And thanks.
Old 05-21-2010, 09:54 PM   #9229
zane121
Oddometer: 120
Pro-taper SE bars. These are 7/8'' so no need for new clamps. Also black brake res, black mirrors and 08 bonnie seat. Now I can ride! Stock I could only go about 30 minutes on the bike without pain...It was worth it.
His--2002 1150GS
Hers--2009 Triumph Bonnie SE-Blue/White
zane121 is offline   Reply With Quote
Old 05-21-2010, 09:55 PM   #9230
zane121
Oddometer: 120
More important I can use my mirrors now...no more shoulder view...these bars are like 32" wide
His--2002 1150GS
zane121 screwed with this post 05-21-2010 at 10:09 PM
Old 05-22-2010, 03:09 AM   #9231
Grizzlybear
Oddometer: 511
Originally Posted by thistle66
Ok, I can't remember the details or name, but there was something a long while ago about a mini pocket sized bike lift to elevate the rear wheel.
Anyone remember that, or how I can get one?
Thanks.
Yep, I rermember that one because I'se the one that sells 'em! You can find them at http://www.aussiebiker.com.au/catalo...20and%20Covers and you can also order online from our shop. Disregard the freight charge because it will cost $22 to airfreight one to Hawaii and I will manually adjust the freight component after we receive the order. All prices in Aust dollars. Griz
Only a biker knows why a dog sticks its head out the window.
Current rides: 2009 Triumph Scrambler, 2013 KTM Adventure 1190
Grizzlybear is offline   Reply With Quote
Old 05-22-2010, 09:28 AM   #9232
bross
Where we riding to?
bross's Avatar
Oddometer: 4,522
Thanks.
For the DIY, crutch jack, trail jack
http://www.advrider.com/forums/showthread.php?t=262648
Old 05-22-2010, 02:13 PM   #9233
thistle66
Oddometer: 373
Cool. Lots of options. Thanks folks.
DIY is appealing but I'm a lazy sod & my time is worth something .
So for just 50 bucks or whatever I can save a trip to town and also my hacksawing time and effort and just get a nice compact sturdy looking thing delivered straight to the door by the postie.
Order placed Dave!
thistle66 is offline   Reply With Quote
Old 05-23-2010, 08:00 AM   #9234
panthercity
Cap'n Crunch
panthercity's Avatar
Oddometer: 481
Zane, thank you for your decal.
Bob AMA #162726 LPR #54
`94 BMW R1100RSA
`95 BMW R1100RSA
`05 R1200ST
`06 Triumph "Scrambled"
panthercity is offline   Reply With Quote
Old 05-23-2010, 08:49 AM   #9235
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,821
Those SE bars look like a good set up,are they the tall model? I know they come in low medium and high.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 05-23-2010, 01:07 PM   #9236
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,693
Undo the two 10mm bolts holding the complete brake pedal assembly on and then you'll get to it easy. You'll want to do that anyway to fit your new spacers....
2002 black Tiger955i, 72000 miles and counting.
2012 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 05-23-2010, 09:32 PM   #9237
Krahe
Krahe's Avatar
Oddometer: 658
Some people talked about the need for a tire repair solution for their bikes, I found this today:
http://www.advdesigns.net/adtipu.html
The nice thing is it appears you can order one package that has everything you need vs ordering bits and pieces from everywhere.
-Stock '07 Triumph Scrambler
6200 miles
Krahe is offline   Reply With Quote
Old 05-23-2010, 10:27 PM   #9238
technikiller
technikiller's Avatar
Oddometer: 68
Missoula, MT to Buffalo, NY
Hey fellas,
I just got back from riding my Scrambler home from western Montana. It ended up about 2200 miles. I avoided interstates at all costs and camped along the way. The Scram performed excellent it was a great experience.
Here's a few pics:
Riding through Helena National Forest was great, lots of curves.
I rode Route 12 much of the way it was built before the interstates, and now, consequently has a lot of basically ghost towns.
I rode for 50 miles at some points without seeing a single person. I felt like Mad Max or something.
Managed to avoid the fire ants and the prickly pear.
Bugs are the new black/South Dakota bugged me... I had to stop every 25 minutes at one point, just to clean my glasses so I could see. I didn't need any dinner that night either.
From South Dakota to New York, things weren't nearly as interesting. I did manage to ride along the Mississippi for most of MN/WI, so that was a nice break from the plains.
I made it home.
"Faster, faster, faster, until the thrill of speed overcomes the fear of death"
Hunter S. Thompson
technikiller is offline   Reply With Quote
Old 05-23-2010, 10:58 PM   #9239
Maxacceleration
Awol
Oddometer: 2,190
Nice ride tk. Your Scrambler looks great.
Old 05-23-2010, 11:50 PM   #9240
Blumtnman
Rider
Blumtnman's Avatar
Oddometer: 274
Thumb 2010 Scrambler
2008 Black and White Bonneville, going to be traded on Thursday. My new 2010 Black ( the fast colour ) Scrambler gets picked up that day. I'm going to love the Scrambler for sure. WooHoo.
Born to ride.
Blumtnman is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
