Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 05-31-2010, 07:20 AM   #9346
regnock
Oddometer: 96
Some homemade panniers
My father and I just finished fabricated these panniers for my Scrambler. I used Motor-Sport Panniers Mounting Loops and Universal Mounting Set along with two Pelican 1550 cases.
Total Cost was $361.24
Mounting Loops and Universal Mounting Set - $123.99
Two used Pelican 1550 case off eBay - $157.25
Steel - $20
Powder Coating - $60
More and higher resolution pictures can be found here
regnock is offline   Reply With Quote
Old 05-31-2010, 09:05 AM   #9347
Mastodon
Mother F'n Dinosaur
Mastodon's Avatar
Oddometer: 661
Steel - $20
Nice setup. Especially for a first post.
That looks similar to DavoRallyFan's setup, and similar too somewhat I was wanting to fab up for myself. I have the mounting hoops, but don't have any of the stuff to fab them into brackets with. And good fab shops here are hard to come by.
BTW, what ever happend to him, or Rhodie, or DangerDave, or any of the original members of this thread?
Mastodon is offline   Reply With Quote
Old 05-31-2010, 09:07 AM   #9348
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,312
Steel - $20
You did a good job! I started to build a set like that using stainless steel but I wasnt happy with the way it looked on the bike. Looks pretty strong.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is online now   Reply With Quote
Old 05-31-2010, 09:43 AM   #9349
Fire Escape
Fire Escape's Avatar
Oddometer: 1,554
Reminders to self
I took the Scrambler out with some friends for an anniversary (theirs) trip to the coast yesterday, lots of fun but it did serve as a reminder that:
The stock seat still leaves much to be desired after an hour or so (ymmv)
and
The stock headlight really does suck, the low beam is passable but IF there is really any pattern whatsoever to the high, I can not discern what they were trying to achieve. The darkest spot in front of me was where I created a shadow in the headlight of their R-6!
Guess I have some projects to work on!
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is online now   Reply With Quote
Old 05-31-2010, 11:04 AM   #9350
MightyChosen1
I wanna be sedated
Oddometer: 1,312
I'm not a big fan of the headlight, I thought about trying a different bulb but I think the root of the problem is the lense. About half of my driving is at night and really want something to reach out farther to see the deer that like to pop out in front of me.
The SV-650 headlight seems to be the best option for the money. I have been on the lookout for one on ebay lately. There are probably other bikes that would work as a donor too.
Old 05-31-2010, 11:40 AM   #9351
Motoblag
Replacing skill with will
Motoblag's Avatar
Oddometer: 388
The first thing I would do is install a headlight relay kit. Cheaper than a new headlight assembly or bulb and will certainly improve the brightness!
Motoblag is offline   Reply With Quote
Old 05-31-2010, 01:21 PM   #9352
RoyNC
RoyNC's Avatar
Oddometer: 6
Please excuse my noob ignorance, but can you tell me what the headlight relay kit does to improve the light. I am interested in boosting my view at night as well.
RoyNC is offline   Reply With Quote
Old 05-31-2010, 02:32 PM   #9353
bross
Where we riding to?
bross's Avatar
Oddometer: 4,524
A relay kit just makes sure that you get a full 12V to your headlight. Some headlights are run through the high / low switch etc. and if you measured the voltage at the headlight it would be quite a bit less than 12V. When you install a relay kit, you basically setup a straight 12V shot from your battery to your headlight, so you get a brighter beam output. Good info here and I use his kits for all my electrical stuff, quality gear...
http://easternbeaver.com/Main/Stuff/...elay_info.html
Old 05-31-2010, 02:46 PM   #9354
ColoradoKevin
Colorado Scrambler
ColoradoKevin's Avatar
Oddometer: 234
Steel - $20?
Wow, Moto-Sports panniers is in my back yard! I live in Evergreen, CO--I'll give them a call. Did you need to do any fabrication or was it a direct fit?
ColoradoKevin is offline   Reply With Quote
Old 05-31-2010, 04:29 PM   #9355
Simon Smith
Simon Smith's Avatar
Oddometer: 192
I just fitted one of these to the scram. They are bloody expensive, but the difference is unbelievable and the standard headlight works just fine now. I thought about fitting a Thruxton headlight but I like the look of the small unit on the Scrambler, and now I don't need to!
Also these bulbs are legal in the UK which 99% of HID kits and all hi wattage bulbs are not.
http://www.shopatron.com/products/pr...PIA70456/353.0
'11 Triumph Tiger 800XC,
Simon Smith is offline   Reply With Quote
Old 05-31-2010, 07:01 PM   #9356
Gormley Green
Gormley Green's Avatar
Oddometer: 74
Tank Bag
Anyone installed a Triumph brand tank bag? I'm wondering where the two little metal brackets attach for the straps. Where did you attach the brackets and the front and back straps? Thanks.
In my defense I've only looked at the bag in my house and not played with it on the bike yet...
2010 Triumph Scrambler, the black one.
Gormley Green is offline   Reply With Quote
Old 05-31-2010, 07:50 PM   #9357
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,100
If you take the seat off you'll see where the brackets go. Been so long ago I can't recall where the front straps went exactly, but I think under the steering head. Could be wrong, as I am on my 3rd gin.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 05-31-2010, 07:51 PM   #9358
Beach40
Beach40's Avatar
Oddometer: 2,975
Any chance of some before and after pictures of the illumination difference?
I'm leaning towards the SV650 headlight. There seems to be a lot of them available at wreckers and they are quite cheap.
Beach40 is offline   Reply With Quote
Old 05-31-2010, 08:07 PM   #9359
Gormley Green
Oddometer: 74
Thanks! Good luck with the 4th....
Old 06-01-2010, 02:02 AM   #9360
Simon Smith
Oddometer: 192
Sorry, didn't take any before pics, but will try and get a side by side pic with a standard one if I remember to take a camera to club meets.
The light output is not only bright white instead of dull yellow, but the beam is better too which would indicate that the filaments are not positioned correctly in the cheap standard bulbs.
Times are GMT -7.   It's 05:42 AM.
