06-01-2010, 02:18 AM
#9361 | |
Oddometer: 183
Well guys, the original light is „not ideal“ – no discussion about it. But don´t you think that using SV 650 light (or whatever light with modern clear glass and not bullet-shaped body) destroys the nicely balanced vintage styling of Scrambler? For me personally SV 650 is not the option. But I liked the light relay option (if it helps) together with effective bulb.
Current bikes: Triumph Scrambler (09-), Honda CBF 250 (06-) Bike history: Simson 50 Enduro (84-89), MZ 251 ETZ (90-95), Suzuki XF 650 Freewind (97-02), Aprilia ETV 1000 Caponord (03-09) |
06-01-2010, 02:29 AM
#9362 | |
Oddometer: 165
06-01-2010, 02:39 AM
#9363 | |
Oddometer: 324
02 Bonneville, 05 SV650, Dnepr MT-16 |
06-01-2010, 02:52 AM
#9364 | |
I mounted them on each side of the head light using the bolts that hold the head light in position. I wired them into the headlight using the main beam as the power source,. these units only draw 0.7 amps, and the light from them is fantastic. When I have a gap I'll post some photos |
06-01-2010, 03:19 AM
#9365 |
Oddometer: 192
Landrovers don't use a relay in the headlamp circuit, and everyone says fitting them makes the world of difference. I tried it on my previous defender and used nice big cables straight from the battery, it made no difference at all
So I fitted some decent bulbs (not the piaa ones) and was amazed at the difference. Removed the relays and they stayed the same. If the manufacturer has sized the wiring and the switches correctly and you use standard wattage bulbs, relays are unnecessary IMHO.
'11 Triumph Tiger 800XC, |
06-01-2010, 03:47 AM
#9366 | |
Oddometer: 165
The bike wiring is designed and specified to carry the necessary current (and more) without overheating, as are the contacts. Now, lets be generous and offer you a 1volt increase by replacing all the headlight wiring with heavier gauge cable plus the extra relay. That would equate to around 8% increase in voltage which, ignoring the losses induced by extra heat generation rather than light output, being wildly optimistic might give you 8% more light output from the already pathetic 55w yellow bulb. You think you'll notice that? You think that will be a 'night and day' improvement? I don't think so. With far less effort you can replace the bulb with a PIAA and get effectively double the output. The claims are not backed up by any facts or any real data. In fact, bullshit. |
06-01-2010, 05:01 AM
#9367 |
\ˈwī-zən-ˌhī-zər\
Oddometer: 1,323
![]() I am using a PIAA bulb and it's much whiter and brighter than the stock one. I don't do much riding at night. Even in broad daylight, the PIAA bulb is very bright and noticeable for traffic. Here is the bulb I am using: LINK I think the stock lens still sucks, but this bulb is an improvement for sure.
06-01-2010, 05:26 AM
#9368 |
I might give the intense PIAA bulb a go as I just don't have time to chase down a unit from the wrecker and change it over, if they ship to Oz.
While I would like to keep the general look of the Scrambler, I'm that attached to it. I seem to recall someone on here doing the SV650 light conversion and it looked ok. Another reason is when I start heading down bush tracks the bike is going to get dropped. When that happens I don't want to be up for a Triumph headlight unit. |
06-01-2010, 06:05 AM
#9369 | |
\ˈwī-zən-ˌhī-zər\
Oddometer: 1,323
06-01-2010, 06:48 AM
#9370 | |
beat up ex flat tracker
Oddometer: 6,754
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
06-01-2010, 07:05 AM
#9371 | |
Oddometer: 1,124
Thank you! It might not be the ultimate solution but knowing that the whiter bulb is an improvement makes that the first place that I will try. I expect that while everything is still relatively new and clean (switch, connectors, etc.) there may not be a big improvement with the relay ..... yet, probably something to think about in the long run, particularly after seeing how quickly some parts of the bike have begun to oxidize (sounds so much better than RUST!). A reflector and lens designed for something other than to provide lighting similar to that of the old, Lucas (they weren't called "Prince Of Darkness" for no reason) equipped, Meriden built, machines would be the best improvement but I believe that it has already been found that nothing good will fit the existing shell. Bruce
No one calls the Fire Department because they did something smart! 06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225 |
06-01-2010, 07:27 AM
#9372 |
\ˈwī-zən-ˌhī-zər\
Oddometer: 1,323
It's too bad there is no improvement for the stock lens. It's an odd size. I find that the low beam lights up the road in front of me very well at night. At dusk and dawn, I use my low beam. The high beam puts out more light, but it seems so scattered. Oh well...
06-01-2010, 07:58 AM
#9373 | |
Oddometer: 91
06-01-2010, 08:20 AM
#9374 | ||
Oddometer: 1,638
No wonder insurance continues to go through the roof. People fall over with their full coverage ins, take it in and viola!, instant big number$ damage to brag about. Between the crotch rocket geeks and the "I don't touch it' squad, who loses out on insurance rates? All of us. Fix your own bike and learn! You'll learn how to work on your bike and not want to drop it the next time...
Horsepower is a distant second to useable torque, unless cafe cruising is the reason for the purchase... Quote:
06-01-2010, 10:10 AM
#9375 |
Oddometer: 73
Done
Ok finally ready to go! Tank bag, Ventura pack and rack system, engine guards, skid plate, fishing rod tube, and 800km break in oil change done! Going for 1500-2000km ride and camp around Ontario this weekend over 4 days with an 81 cb750k and a 04 Bonny.
Pics will follow.
2010 Triumph Scrambler, the black one. |
