07-25-2010, 04:13 PM
#10111 |
Oddometer: 657
Spokes are high stress parts, you dont want to mess around with a band-aid fix. Sorry, but I say get it fixed right.
-Stock '07 Triumph Scrambler 6200 miles |
07-25-2010, 04:35 PM
#10112 | |
Oddometer: 174
Im right there with ya Bro !! |
07-25-2010, 05:00 PM
#10113 | |
Oddometer: 657
07-25-2010, 10:11 PM
#10114 | |
I can pass this guy.....
Oddometer: 2,737
2012 Triumph Bonneville 2006 Suzuki Vstrom ![]() Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311 |
07-25-2010, 10:32 PM
#10115 | |
beat up ex flat tracker
Oddometer: 6,753
fake it some way,the Trans lab probably stressed em and then they broke later. I dont know what to do other then ordering a wheel or some how making another wheel fit,that would be a stretch also. Once 3 have broke it will continue to break others even if those were replaced most likely. That bend Triumph put in the spokes is an obvious weak point,they used to do dumb stuff like that on old bikes.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
07-26-2010, 12:12 AM
#10116 | |
Oddometer: 82
Cheers Walter Acceleration is when the tears of emotion flow out horizontally through the ears. Bike history: Z900, RD400, Z1000LTD, GPZ1100, FT500, XS1100, VF1100C, KLR600, CB1100F, V-Max, VX800, XL650V, GSF1200, R1200R, XL700V, Scrambler900, Scrambler900EFI, TDM900, Tiger800. |
07-26-2010, 12:41 AM
#10117 | |
Oddometer: 60
Don't get me wrong, I'm not adverse to fixing the problem rather than improvising |
07-26-2010, 01:35 AM
#10118 | |
Oddometer: 803
Try a PM to ' denizguide ' for a suggestion , I know he's in Turkey, it's kind of next door. I suspect you are now in the land of improvisation, keep us posted. Best of luck |
07-26-2010, 05:08 AM
#10119 | |
Oddometer: 60
I tried to get across that I'd like for them to test all the spokes and replace them as needed but we'll see what happens...I had actually intended to carry spare spokes but decided against it at the last minute In any event I wouldn't have carried enough to replace 4 broken spokes on the rear wheel. I called several Triumph dealerships here in Greece but none of them have spokes in stock, I also called a UK dealership and they think they could have them here in 3-4 days so that is an option as well if the Thessaloniki option doesn't work out. Replacing the wheel doesn't seem like a viable option at the moment because of cost/availability. |
07-26-2010, 05:48 AM
#10120 | |
A real Trucker Cap
Oddometer: 58
Does that make sense? |
07-26-2010, 06:33 AM
#10121 | |
Tigers R great.
2002 Tiger955i in black, 68500 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... |
07-26-2010, 06:37 AM
#10122 | |
Oddometer: 6,753
Maybe something as crude as fitting an old streetbike wheel of some sort with homemade spacers and rigging the drum brake to work some how. Or carrying on with ft brake only. Desperate times call for desperate measures.
07-26-2010, 07:20 AM
#10123 | |
Oddometer: 60
Footdragger, I've heard of people wiring spokes together to prevent them from flailing around when they break and I definately plan on doing that. One of the broken spokes hit the brake caliper, launching it into the inner tube and causing the flat. That would have probably been prevented if they'd been wired together. A couple of riders stopped and lended a hand though with fixing the flat which was very nice. |
07-26-2010, 08:35 AM
#10124 | |
Oddometer: 1,124
Some of us still do!
I still wire the spokes on a few of my bikes (including the Scrambler). It isn't a guarantee but usually can prevent a wayward broken spoke from inflicting further damage. More often these days I see dirtbike riders using ty-wraps instead of wire. I have no idea if it works as well or perhaps better but it certainly would be faster to do. What I have no idea about is IF wiring the spokes actually helps spread the load and thusly reduce breakage to begin with. With todays metal technology it would seem that breaking a spoke in normal use would indicate a design flaw. And when the only spokes you hear about breaking all come from one brand ........... Bruce
No one calls the Fire Department because they did something smart! 06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225 |
07-26-2010, 09:00 AM
#10125 | |
Oddometer: 6,753
Im thinking a 500 lb + load wt short travel twin puts a lot of abuse into the wheels.
