Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 10-25-2010, 06:49 PM   #11191
littlelionmonster
Rerutnevda ylranG
littlelionmonster's Avatar
Oddometer: 882
Originally Posted by hyena
I agree. Ordered the gasket and 4 more seals late this afternoon. In stock at Baxter. I'll definitely make sure the mating surfaces are good, and use Hylomar or comparable. My guess - the original bolt seals eventually flattened out enough to permit the leak.
I'm having the same issue on my 06. I read on ratnet where guys have changed the gasket and still had issues. Before buying all new seals I tried a coating of RTV on the mating surface, reassembled and retorted everything. I haven't been able to get out and test it, but it was worth a shot.
Sounds like the bolt seals compress over time and don't keep the cover properly sealed.
littlelionmonster is offline   Reply With Quote
Old 10-25-2010, 08:24 PM   #11192
NoPoChicken
CSMC
NoPoChicken's Avatar
Oddometer: 1,093
Originally Posted by riverorange
Are there any news on the Pivot Pegz?
Thanks,
Chris
I was on the list to get a pair on the first round, and was told they would be ready last spring. Haven't heard a thing in months. Received this in an e-mail in April:
We are working very hard to have the Triumph Scrambler Pivot Pegz available as soon as possible however at this stage we wonít be able to have them shipped to the US before May because we are trying to finalise an alternate design. The reason for the delay is that we are trying to develop Pivot Pegz for the Triumph Scrambler that are 15mm longer than our standard Pivot Pegz. It sounds simple but unfortunately it isnít and the design is proving troublesome and this is causing the delay.
I just want to let you know that we do have Scrambler Pivot Pegz available but they will not be the 15mm longer version. We have supplied these in the past to some other customers who have been fine with them but there have also been some other customers that would prefer to have an extra 15mm in length. (Protrude 15mm further from the frame).
If you are happy to have the standard size Pivot Pegz then we can ship them to you next week. Otherwise if you want the 15mm longer Pivot Pegz then unfortunately you will have to wait.
I chose to stay on the backorder list because I think that the extra legth would be awesome. I sent an e-mail on the 18th of October looking for an update and have not yet received a reply.
I do want to express myself, okay. And I don't need 37 pieces of flair to do it.
NoPoChicken is offline   Reply With Quote
Old 10-25-2010, 08:32 PM   #11193
ColoradoKevin
Colorado Scrambler
ColoradoKevin's Avatar
Oddometer: 234
Originally Posted by Fire Escape
My Scrambler hasn't needed this repair (yet) so I only have "other related" experience to draw upon. In that experience I tend to find that as you suggested 'once it leaks' it will likely continue to despite re-torquing the fasteners. I'd look carefully at the mating surfaces when you replace the gasket, might consider a sealant such as Hylomar when assembling and would look carefully at those seals that you just replaced because while they may not have any time on them, they are not "new" anymore, having been installed and compressed. In all probability it is not necessary to do all these things to have an oil tight engine again but I tend to be a 'belt and suspenders' kind of guy, I hate to do things over! YMMV.
Bruce
The cam cover gasket was leaking oil on my '08 Scrambler. The repair was covered under warranty and fixed by my dealer. After several thousand miles, I've not had any further issues with it.
ColoradoKevin is offline   Reply With Quote
Old 10-26-2010, 10:19 AM   #11194
Island_Moose
Oddometer: 19
The design is proving "troublesome"? Given that we are talking about an extension of a mere 15mm, I would assume the issue is that the additional length (and resulting lever arm) caused the prototypes to snap off?
I would love someone to develop pegs that are about 20mm further back and 10mm higher.
Island_Moose is offline   Reply With Quote
Old 10-26-2010, 12:43 PM   #11195
Firedawg450
Why did I wait??
Oddometer: 119
Single seat plus ventura
Becsta, the Ventura rack fits behind the single seat rack, so the set-up you describe works fine. I've lashed 45lbs to the single seat rack and used the Ventura for everything else. I've heard that the rack mounting points are prone to cracking when overloaded, but I never had issues. I think it depends on the kind of riding you do. I babied things when I knew the rack was overloaded.
Originally Posted by becsta
Has anyone fitted another rack like the ventura with the single seat. Does it sit behind the inbuilt rack on the seat? I was wondering about this as I know the seat rack isnt strong enough to hold a full top box so was thinking that you could put a top box on the other rack and have the seat rack for a tent or esky.
"If I didn't have bad luck..."
Firedawg450 is offline   Reply With Quote
Old 10-26-2010, 04:32 PM   #11196
ivara
ivara's Avatar
Oddometer: 327
Quote:Originally Posted by thistle66
Zapp,
What length spacers are those?
Originally Posted by ZappBranigan
One inch. That's the only size that Spacer Jim offers currently.
he can make other lenghts too..:
http://spacerjim.com/Custom.htm
02 Bonneville, 05 SV650, Dnepr MT-16
ivara is offline   Reply With Quote
Old 10-26-2010, 07:22 PM   #11197
ZappBranigan
Oddometer: 470
I'm sure he can, but a warning: The cables and wires are tight with the 1" spacers. Any more and you may have problems.
Martin (AKA ZappBranigan)
"Branigan's Law is like Branigan's Love: Hard, and Fast!"
Current Ride: 2002 BMW R1150R
ZappBranigan is offline   Reply With Quote
Old 10-27-2010, 01:47 AM   #11198
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,868
In this photo you can see the "J" rails for the rack which goes into them and extends backwards.....
Some people have had issues with weight on the single seat rack. A simple solution is to remove the rack and use the shelf as the weight bearing surface....
I load all sorts of stuff on top of that tail bag and it carries it fine. Looks like this when loaded....
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 10-27-2010, 02:15 AM   #11199
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,868
Scramblers in Spain and beating the French fuel blockade
Having gone to Spain for a few days trail riding on our Triumph Scramblers
Yes, we had to ride up that..... That day wore us out. At one stage we thought we were in the shit and would have to make camp over night.
The scenery was stunning....
So, we were now stuck in Figueres, north east Spain, by the French fuel blockade. We had a ferry booked from Cherbourg but it was too far with fuel the supply being dodgy. So, we hatched a plan, in the bar, to buy fuel canisters to carry an extra 30 litres of petrol each and head to Geneva, 400 miles away, where we could refill and continue up to Luxembourg for another refill and then onwards to Calais for a ferry to Dover.
We set off from our hotel in Figueres on a chilly Wednesday morning
on the Autoroutes at a steady 60mph to conserve fuel. After about 100 miles we saw a petrol station open for business so we topped off our tanks and were able to up the cruising speed to around 75mph which got us to Annecy for an overnight stop.
The next morning was really frosty and we got moving at 09:30 and rode into Geneva with 10 litres of fuel to spare thanks to the top up on the Autoroute. After filling everything we had and taking the obligatory photo at the famous fountain
we headed north over the “Col de la Faucille” @ 1323 metres, which had a covering of snow.
The ride on the north side, down from the peak was treacherous with icy patches but the views with the frost in the trees were stunning.
Because of the conditions, we abandoned plans to ride the “Route de Cretes” in the east of France and diverted toward Dole and then north towards Luxembourg along some lovely “D” roads. We got as far as Chaumont before we were frozen so we found a hotel there.
Another frosty morning made us slow to start off but we got going around 09:30 after bump starting my bike because the heated grips and heated jacket liner has drained the battery too far. We continued to Luxembourg on very pretty back roads. Refilling everything there, we set off for Chimay for an hotel and some beer but couldn’t find one single hotel in the town. This is a town with an Abbey brewery and a race circuit with no hotels??!! Surely a missed opportunity. So the Garmin Zumo came in handy and routed us to an Ibis in Maubeuge for our final night in this saga.
Next morning was more of the frosty same but with rain forecast. Our route took us through Cambrai, Arras, Frevent, Hesdin, Desvres, and Guines to Calais where we were robbed of €62 for a one way ferry crossing. Dave and I went our separate ways off the M20. Job done.
Message to the French :- We don’t need or want your petrol! Get back to work you lazy B#*@^"ds.
LINKS TO VIDEO:-
http://www.youtube.com/watch?v=o1x4z__vmHc
http://www.youtube.com/watch?v=-IkOPZ
http://www.youtube.com/watch?v=y4FANLPc1GkE3cAE
http://www.youtube.com/watch?v=YrihHN22oVQ
http://www.youtube.com/watch?v=FPwgGNt3pI0
blacktiger screwed with this post 10-27-2010 at 03:25 AM
Old 10-27-2010, 05:19 AM   #11200
becsta
becsta's Avatar
Oddometer: 118
Thanks for the replies and thanks blacktiger for the pics.
Current Ride: 2010 Triumph Scrambler
becsta is offline   Reply With Quote
Old 10-27-2010, 08:00 AM   #11201
Oriondk
Oddometer: 311
Originally Posted by blacktiger
Message to the French :- We donít need or want your petrol! Get back to work you lazy B#*@^"ds.
Great read. You're making want a Scrambler.
Oriondk is offline   Reply With Quote
Old 10-27-2010, 08:19 AM   #11202
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,664
Great posting Blacktiger!
"If you don't peer over the edge now and then, how do you know where it is?" The venerable Mr. Cob
Mista Vern is offline   Reply With Quote
Old 10-27-2010, 08:24 AM   #11203
FoothillRyder
Tiger Cub
FoothillRyder's Avatar
Oddometer: 406
LINKS TO VIDEO:-
Brilliant, and very cool to see more video of Scramblers in some serious offroad stuff. Three more days and my Tangerine/Silver '08 will be in my hands!
- Foothill Ryder
BIR # 47, AMA # 289558
'08 Scrambler <>
'97 Triumph Trophy 3,'73 Triumph T120V,'64 BMW R50/2
FoothillRyder is offline   Reply With Quote
Old 10-27-2010, 10:00 AM   #11204
pm9654
pm9654's Avatar
Oddometer: 181
Originally Posted by rous44
Just got the Scrambler back from the pinstriper today.
What do you think ?
THAT is just beautiful!!!
BATMAN
pm9654 is offline   Reply With Quote
Old 10-27-2010, 04:49 PM   #11205
HighScore
No More, all done.
HighScore's Avatar
Oddometer: 928
Just a quickie about my arrow pipe, I had it installed at a dealership for warranty purposes. The guys at the dealership said I didn't need to change my carb jetting for the new pipe, now I am noticing after 1000 miles that theres some soot like crap spewing out with the exhaust.
I also removed the DOT fuel emissions crap and hardware from the fuel system. Installed the kit from New Bonneville...
Should I be changing the jetting? The bike runs very well, and goes like hell but I wonder if it's running a little rich?
I don't really give a shit how many miles you rode in a day, just as long as you have a good time and take lots of pictures.
HighScore is offline   Reply With Quote
Times are GMT -7.   It's 12:44 AM.
