Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 11-01-2011, 08:29 AM   #14131
Boston813
Oddometer: 131
Originally Posted by earwig View Post
Any one know where I can get a set of those pipes? I have a '69 TR6c just waiting for some love this winter.
Boston813 is offline   Reply With Quote
Old 11-01-2011, 08:56 AM   #14132
earwig
Crowbar of Embrayage
earwig's Avatar
Oddometer: 4,724
Nope.
They were the find of the century for me. I've found some similar sets, but not another pair like these.
Good luck!
earwig is offline   Reply With Quote
Old 11-01-2011, 11:05 AM   #14133
timolgra1
timolgra1's Avatar
Oddometer: 495
Originally Posted by wildjester View Post
Hmmm now how much is my old one worth towards one
timolgra1 is offline   Reply With Quote
Old 11-01-2011, 02:27 PM   #14134
Bambi
Bambi's Avatar
Oddometer: 687
Hello there,
concerning the open pipes on the TR 6/T 120 scrambler: have a go with these guys!
http://www.motorcyclewebsite.com/armours-ltd
Take care, my computer from the stone age couldn't handle their site. But that has nothing to do with their products and their quality but with the amount of bites or their presentation.
They offer solutions for nearly every exhaust-problem with brit-bikes. Many of my German brit-bike-friends are satisfied with their pipes and silencers for their old bikes.
I have to admit, I don't know, if this also applies to the new ones ...
Kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 11-01-2011, 02:31 PM   #14135
Bambi
Bambi's Avatar
Oddometer: 687
Sorry,
I got to 'repair':
This is the link to their home-page ...
http://www.skiddersmusic.com/Armours/Home.html
Bit confusing because of the title ...
Cheers, Bambi
Old 11-01-2011, 08:51 PM   #14136
wildjester
wildjester's Avatar
Oddometer: 82
Question Need help... no start electrical issue
Need help... no start issue... elecrtical
I have a feeling and am hoping this is a simple issue.
I installed a lucas style tail light and turn signals the other day.
Blew out a couple of fuses for the turn signals in the process.
Replaced all fuses and buttoned everything up.
Now bike wont start.
Turn key
All lights go on
Fuel pump cycles
But when I hit the starter button... I get a "ckunk" from around where the battery is and dash lights click off.
A few seconds later... lights reset and fuel pump cycles... hit starter and "clunk"
Any ideas?
I know my way around bike, but have spent 10 years dealing only with I4 Jap bikes. To me it feels like an inertia switch or something stupid that got flipped and needs to be reset.
wildjester is online now   Reply With Quote
Old 11-01-2011, 09:26 PM   #14137
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,830
Is the kill switch set on off or run? This simple thing baffled my neighbour for a whole weekend.
Rick, Chapleau, ON
Triumph Scrambler 900
Honda Trail CT90
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline   Reply With Quote
Old 11-01-2011, 10:11 PM   #14138
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,311
I dont think the starter will spin with the kill switch off.
Have you checked your battery voltage ? It should be around 12.6 volts. Or possibly a bad connection at the battery can cause similar problems.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 11-01-2011, 10:32 PM   #14139
dean-o
Dabs often
Oddometer: 852
battery short circuited???
i've had similar happen - the battery still shows god voltage - but if you were to load test it, it would fail...just make sure you know the CCA of your battery before having the auto parts person do the test...
hope this may help - it's happened to me...
dean a scrambler fan, but not yet owner!
tenessee
dean-o is offline   Reply With Quote
Old 11-01-2011, 11:16 PM   #14140
FoothillRyder
Tiger Cub
FoothillRyder's Avatar
Oddometer: 406
Do you know (for sure) why you blew those fuses? You may still have something not quite right in the wiring, which (getting to your problem) has drained the battery below the point where it has enough energy to handle the load of the starter. What would happen when you hit the button is the battery voltage would drop to the point where the ECU resets (taking out lights, etc.), then the load goes away, battery recovers after a brief pause, and the ECU comes back along with the lights, etc.
Put a battery tender on it. If the tender never indicates full charge, you have something loading down your electrical system.
I'm glad I have an '08 - before there was an ECU to worry about.
- FoothillRyder AMA# 289558, BIR #47, COP #001
'97 Trophy 900, '98 Tiger, '03 Speed Triple 955i
My Blog: http://foothillryder.com/
FoothillRyder is offline   Reply With Quote
Old 11-02-2011, 05:19 AM   #14141
wildjester
wildjester's Avatar
Oddometer: 82
Bingo! Sometimes I can be so smart and then so stupid. Put it on the charger overnight and presto! Vroooom! patato-patato-patato-patato
In my defense, this is all new to me. On any other bike (Jap Sport) I've owned, when the battery is too low to start it tries to crank and makes the typical dead battery noise. The ECU reset totally threw me off. Now I know!
Ok-this made me feel better!
Old 11-02-2011, 06:58 AM   #14142
wildjester
wildjester's Avatar
Oddometer: 82
Ok.
Now that is over and done with... whats with the check engine light?
Will it reset?
Can I reset?
or is it a stealership only item?
Old 11-02-2011, 09:00 AM   #14143
FoothillRyder
Tiger Cub
Oddometer: 406
None of my bikes have all them fancy 'lectronics; but I did a quick Google on 'Triumph Scrambler Check Engine Light'. Seems you're not the only one. My bet though, is that when the ECU got reset, it set a condition that caused the CEL to come on and stay on until it gets reset.
If I knew how to reset it, I'd tell you. Anyone?
Old 11-02-2011, 09:16 AM   #14144
wildjester
wildjester's Avatar
Oddometer: 82
It looks like people are saying "3 run cycles" and it will fix itself.
Some said disconntect battery for 30min.
I rode to work... thats one cycle.
Old 11-02-2011, 01:53 PM   #14145
2whl-hoop
2whl-hoop's Avatar
Location: Cottage Grove, the ragged edge of suburbia, MN
Oddometer: 944
Does the Arrow pipe stick out as far as the stock pipe? I really like the look of the Scrambler, but then I go to sit on one and that stupid pipe bangs into the inside of my right knee. I think that would get pretty annoying really quickly.
2whl-hoop is offline   Reply With Quote
Times are GMT -7.   It's 03:56 PM.
