12-01-2011, 03:39 PM
#14341 | |
Oddometer: 1,638
I apologize if I post up my bike too much. *Heavy remorse*
It is alway changing and I like to scheme concept or direction on my bike. As we know the Scrambler is the 'bolt on' king for changing its personality or use. My latest is a gearing change. Same basic gearing, albeit slightly lower. 2.389 down to 2.421. 18/43 to 19/46. Maybe just a bit more acceleration. The reason I did it mainly (besides wearing sprockets and chain) is to shorten the wheelbase. To me the tire looks pushed way back. Older (60's) Triumphs were shorter and their tire wasn't pushed so far back. Doing this shortened my wheelbase about an inch. Wheel is better placed within the fender... Looks much better now IMO. Hopefully I can get a fresh stock length chain on... Weird I know... ![]() ![]()
Horsepower is a distant second to useable torque, unless cafe cruising is the reason for the purchase... Quote:
12-01-2011, 03:47 PM
#14342 |
The Magnanimous
Oddometer: 168
Old Triumphs had 19 inch wheels front and back. That's the big difference in looks. Some new Triumphs I've seen had 19's on the back and it looked good. Unfortunately, it limits tire options.
12-01-2011, 10:13 PM
#14343 | ||
Oddometer: 112
Which rear shocks do you use and what changed after installing them? Looks like they are height adjustable, too. Georgios screwed with this post 12-01-2011 at 10:21 PM |
12-01-2011, 10:36 PM
#14344 | |
Oddometer: 222
Keep on posting Max, I like to see the way you go:-) |
12-02-2011, 12:11 AM
#14345 | |
Commonist
Oddometer: 14,129
7th Day Adventourist. Terrafied -If you get it wrong you'll get it right next time- |
12-02-2011, 12:13 AM
#14346 |
Commonist
Oddometer: 14,129
About time I bought some new cush drive rubbers.
12-02-2011, 04:18 AM
#14347 |
is this thing on?
Oddometer: 52
Scrambler mono....
sure why not, if you know how.
http://www.youtube.com/watch?v=buZtfq9ea0I at 0:49 sec. he knows how. |
12-02-2011, 05:27 AM
#14348 | |
Oddometer: 112
12-02-2011, 05:39 AM
#14349 | |
scarce
Oddometer: 5,390
Hornswoop me bungo pony. |
12-02-2011, 09:01 AM
#14350 | |
Oddometer: 72
Ignition relocation bracket
I wanted to post a follow up about the joker machine relocation bracket issues. I spoke to Bryan via e mail and he told me that they have had a few complaints about the bolt holes for the ignition being drilled and tapped for he wrong size. He said that he would contact production and look into it. I ended up drilling and tapping it myself, no big deal really. As to the wrong bolts being supplied, their supplier mixed the bolt bin with bolts of different thread pitches. Bryan was quick to send me the correct bolts. The bracket is now installed and looks great.
12-02-2011, 09:46 AM
#14351 | ||
Oddometer: 1,638
He is standing on the buddy pegs to get his weight back and has no brake to cover. But yes he does a nice wheelie on a low powered bike. Just clutch it up!
12-02-2011, 10:01 AM
#14352 | ||
Oddometer: 1,638
They are spendy as any, top of the line but they have a full range of adjustment. Compression, rebound, spring preload and length. And the looks to go with them. The added length get close to interference with our wonderful centerstand and chain. Maybe slightly quicker steering with the longer shocks too - but basically the same (as they settle in under weight).
12-02-2011, 01:51 PM
#14353 |
Oddometer: 112
Interesting.
How much do you gain in travel and do you use the compression adustment in real life? I guess they should be wide open all the time. |
12-02-2011, 05:10 PM
#14354 | ||
Oddometer: 1,638
If the Triumph is at 5"/5" f & r thats not so bad... lol For a bike that is lacking to start with. The compression dial is the most used, on any bike for me. If your spring sag is where you want it, compression takes your bike from harsh to plush (or versa visa). My Scrambler has felt too soft, so I dial in more compression adjustment to firm it up a bit. From plush to a little more sporting. Rebound (for me) is left alone so the shocks extend quick. Here is a better look of them. I am not trying to push these shocks due to price. There are others that have some of these features at a better price. But I like 'em...
Maxacceleration screwed with this post 12-02-2011 at 05:23 PM |
12-02-2011, 05:43 PM
#14355 |
Oddometer: 460
not quite, they were generally 18 rear, 19 front....Norton Commandos use(d) 19's front and rear and that makes for very limited rear tire choices....18 is not so bad, many more options
victor441 screwed with this post 12-02-2011 at 05:51 PM |
