Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 02-04-2012, 07:53 AM   #14761
twodogsf
twodogsf's Avatar
Oddometer: 230
speedo
My cable did the same in cold weather, took it out and lubed it, no more noise
twodogsf is offline   Reply With Quote
Old 02-04-2012, 09:24 AM   #14762
Motoblag
Replacing skill with will
Motoblag's Avatar
Oddometer: 394
What did you lube it with? I've tried: PB Lube, general purpose grease and motor oil. Still get squealing right at 35 MPH when it's around freezing temps.
Motoblag is offline   Reply With Quote
Old 02-04-2012, 09:30 AM   #14763
panthercity
Cap'n Crunch
panthercity's Avatar
Oddometer: 481
There are specific speedo cable lubes, graphite with a carrier, available at auto supply stores. Regular cable lube is NOT designed for rotating cables like speedo and tach cables.
Bob AMA #162726 LPR #54
`94 BMW R1100RSA
`95 BMW R1100RSA
`05 R1200ST
`06 Triumph "Scrambled"
panthercity is offline   Reply With Quote
Old 02-04-2012, 12:58 PM   #14764
twodogsf
twodogsf's Avatar
Oddometer: 230
cable
I used Dupont teflon multi use.
Old 02-05-2012, 07:37 AM   #14765
tvscum
tvscum's Avatar
Oddometer: 139
Crash bar tubes
Does anybody have information on how to install one of these extension tubes on the Scrambler crash bars? This was Rhodie's setup.
Current: 2012 Triumph Scrambler;
'97 Honda XR440 (plated)
Past: '83 Honda XR500; '84 Honda XL600;
'86 Yamaha XT350
tvscum is offline   Reply With Quote
Old 02-05-2012, 06:09 PM   #14766
Motoblag
Motoblag's Avatar
Oddometer: 394
Got one of my new tires on!
It's a Shinko SR241 3.50-19. Clears everything and works way better on gravel than the Conti Trail Attacks I had on for my Alaska/Inuvik trip. Pavement traction is pretty poor, though.
Motoblag screwed with this post 02-06-2012 at 08:11 AM Reason: Wrong previous tire
Old 02-05-2012, 07:59 PM   #14767
beetleything
Oddometer: 5
They look good.
You might want to run them / scruff them up more for better pavement traction.
beetleything is offline   Reply With Quote
Old 02-05-2012, 08:07 PM   #14768
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,222
Nice tires Motoblag. Shinko is the only mfg who does proper sizes for mid 60's Triumph/BSA bike other than the Dunlop Gold Seals (K70's).
They look good although our Scrambler is probably kinda heavy for them.
Tvscum, I believe originally the strengthening cross member mod was done with a solid piece with machined ends to fit over the stock crash bars.
I think if I was to do it I would use a hollow piece over the crash bars and a tight fitting through bolt/nut cranked down through each with loctite.
Maxacceleration is offline   Reply With Quote
Old 02-06-2012, 02:11 PM   #14769
satcen
satcen's Avatar
Oddometer: 211
Any idea about these tires? Heidenau?
Current bikes: Triumph Scrambler (09-), Honda CBF 250 (06-)
Bike history: Simson 50 Enduro (84-89), MZ 251 ETZ (90-95), Suzuki XF 650 Freewind (97-02), Aprilia ETV 1000 Caponord (03-09)
satcen is offline   Reply With Quote
Old 02-06-2012, 04:21 PM   #14770
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,010
I wanna see the rest of that bike...
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 02-06-2012, 04:25 PM   #14771
CordR
Oddometer: 514
I would say that they are. I didn't have them on my scram, but I did have them on my GSPD before I sold it. Never got to test them in the dirt, but they looked good and were way better (on that bike) than the T 63's I had on it previously.
CordR is offline   Reply With Quote
Old 02-06-2012, 07:37 PM   #14772
Maxacceleration
Awol
Oddometer: 2,222
I have one front and two rear Heidenaus ready to go on my bike.
They have a good reputation, although maybe not as good as TKC's off pavement.
I am not taking my bike off pavement as much as I used to, thus the Heidenaus.
I say go for it.
... And that Raisch bike (?) looks beyond belief!
Old 02-06-2012, 10:21 PM   #14773
tvscum
tvscum's Avatar
Oddometer: 139
Thanks Max on the crossbar-crashbar idea...
Also... Looks like the same tire here:
http://advrider.com/forums/showpost....&postcount=476
'86 Yamaha XT350
Old 02-08-2012, 05:49 AM   #14774
henryII
henryII's Avatar
Oddometer: 398
Alternative screen
The oem screen dont fit, since it is 2 clocks on my '11 Scrambler. So I mounted the Dartscreen instead.
Does anybody know of a alternative to the Dart that is a little smaller? I liked the look of the oem better
since the lamp is more visible.
Old bike New bike
________________________________________
[/URL]
henryII is offline   Reply With Quote
Old 02-08-2012, 08:55 AM   #14775
GEORGE K
Oddometer: 51
Need help, rough idle
2008 with carbs. Put Arrow two into one exhaust on. Changed from 110 to 115 jets. Bike runs strong from just off idle all the way up but has a rough idle with some popping and wheezing at low RPM. Idle mixture changes don't seem to make much difference except going lean seems to make it worse. Anyone else had this symptom after muffler and jet changes? What to do?
GEORGE K is online now   Reply With Quote
Times are GMT -7.   It's 08:02 AM.
