Old 10-24-2013, 10:24 PM   #1966
Trigxrr
Oddometer: 89
Here is mine
Trigxrr is offline   Reply With Quote
Old 10-28-2013, 04:21 PM   #1967
Mikey Boy
Mikey Boy's Avatar
Oddometer: 246
New owner here. I rode Hoologan's 650R on a 3 day Nevada trip last weekend and was hooked. Sold my wr250 and picking up a plated 2000 XR650R on Wednesday. Has Q4 pipe, Clarke tank, 3/4 inch risers with Renthals, K&N filter and a bunch of other mods.
Edit: I'm gonna need a bigger tank for DV and such. Acerbis 6.3 or IMS 7.0 Gallon tank? Thoughts?
Work to ride, and ride to work.
2014 Tiger 800xc - Meow
2000 XR650R - plated
Mikey Boy is offline   Reply With Quote
Old 10-28-2013, 05:15 PM   #1968
LVCJT
LVCJT's Avatar
Oddometer: 236
Get rid of the k&n. They are a well none weak spot on the Xr650r. Tons of info here. http://www.advrider.com/forums/showt...php?p=22643783
Sent from the depths of my pockets
LVCJT is online now   Reply With Quote
Old 10-29-2013, 08:25 AM   #1969
Mikey Boy
Mikey Boy's Avatar
Oddometer: 246
Uni? Moose? Gracias amigo!
Old 10-29-2013, 03:05 PM   #1970
LVCJT
LVCJT's Avatar
Oddometer: 236
I use uni. But as long as you stick with foam you should be okay.
Old 10-30-2013, 07:44 AM   #1971
Shibby!
Oddometer: 1,658
Stock is actually best for filtering. Maybe not for flow.
I run Twin Air, but i think they are all pretty much the same with Moose, Uni, etc.
Stock's are pretty pricey but seem to fit the best and have nice thick filter media.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 03-26-2014, 05:26 PM   #1972
BronkoRob
Oddometer: 61
how many of you guys are running bigger batteries? what battery and where have you placed them?
I am looking into a small LED light bar and wiring GPS and speedo to the bike. I have noticed the well known dimming of lights at idle, and I want to get away from that. Right now I have a 200W stator running threw the ricky stator reg/rect, so the whole bike is DC.
I am thinking about adding a battery in a small tail bag and running accessories off of that. I do have dual outputs from the stator and was wondering if there would be any benefit or issues to running all power threw 1 reg/rect to the battery than to devices.
I hope to get the lighting and light bar setup and either making a taller rally style fairing or just going the BMW Dakar wind screen route and cutting an opening for the light bar.
No Pads, No Helmet.....Just Balls!
BronkoRob is offline   Reply With Quote
Old 03-27-2014, 07:44 AM   #1973
modette
RMAR
modette's Avatar
Oddometer: 4,699
Actually as long as you FOLLOW the K&N directions you will have no issues. Got to use the K&N grease to seal around the air filter unit. Also spray some tacky filter stuff on it vs just the K&N oil. No dust is getting in. I bet a LOT of people skip the grease around the filter to seal it into the air box.
Follow directions people.
Edited to say: It's why I said use the tacky stuff and don't just use the K&N oil. I think there might be enough room to put a foam filter on top of the K&N I'll tinker when I put the kiddo to nap time and see if so I'll take a picture.
Board of Directors for RMAR: Director of Digital Marketing & Promotions
Our site: Rocky Mountain Adventure Riders
modette screwed with this post 03-27-2014 at 11:13 AM
modette is offline   Reply With Quote
Old 03-27-2014, 09:09 AM   #1974
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,129
K&Ns suck for dusty riding, when clean they pass dust period. All you have to do is look at Baja racers, the people running the K&N are running an oiled foam prefilter around it and often a filter skin. Unfortunately on bikes it's hard to layer the filtration. K&Ns actually don't start filtering well till they get dirty, the design relies on trapped dirt particles to help filter out other dirt. When they are clean (and oiled) fine dust particles will pass right through them. The size that gets through is very fine so it's not like it's going to toast you motor but most off-road applications don't rely on the K&N alone. When oild foam doesn't pass anything why install a filter that doesn't stop everything.
I run one on my sand rail because it's makes a good base to support the 2 other filters layered over it.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-27-2014, 12:25 PM   #1975
luckychucky
luckychucky's Avatar
Oddometer: 1,255
Cool sand rail pic! I put a solar panel for charging my Tusk battery pack. I'll let you know in a year or two how it's doing
luckychucky is offline   Reply With Quote
Old 03-27-2014, 01:30 PM   #1976
modette
RMAR
modette's Avatar
Oddometer: 4,699
More then enough room to run a pre-filter with a little trim job.
Old 03-28-2014, 07:48 PM   #1977
npcaldwell
Oddometer: 27
Here's my 2003
Here's my 2003 XR650R ready to take some bikes out behind the wood pile
Uncorked
K&N
Big Gun POS full system (installed by previous owner) with melted insert.
7.0 gallon IMS tank
Renthal Fat bars
BRP top tripple clamp (no stabilizer yet)
HDB top clamp
HDB turn signal/horn/kill switch housing
Vapor Computer with Pauls HDB billet protector/mount
Home made wiring harness done right, 1.3AH AGM battery, RS 200W stator
tiny blinkers
Dual PIAA 510 headlights running 155 watts of deer vaporizing light
NEW Pirelli mt 43 rear!
Junky Pirelli scorpion front
And a long, long, long wishlist
npcaldwell screwed with this post 03-28-2014 at 08:01 PM
npcaldwell is offline   Reply With Quote
Old 03-28-2014, 08:55 PM   #1978
BronkoRob
Oddometer: 61
Where did you stash the battery? Any pics?
Old 03-29-2014, 07:48 AM   #1979
XRR-kat
Prodigal Scrambler
XRR-kat's Avatar
Oddometer: 354
For KEYZ
Originally Posted by XRR-kat View Post
Got the part and fabbed a bracket from 1x1x1/8 alum angle. I say fabbed but the only metal working tool I have is a grinder. Thought I would need two, but single hose clamp is sturdy enough. Slot ground through the corner of the angle and hose clamp threaded through that.
kellyk7, pburke, & gaspipe,
Thanks for your support !
Reposting for Keyz
"Compression release? What compression release ?!"
XRR-kat is offline   Reply With Quote
Old 03-29-2014, 08:17 AM   #1980
npcaldwell
Oddometer: 27
Battery mount
I copied RIDEFREAK's design on this sort of, I used 1" x 1/8" angle iron to make the box, 1" x 1/8" strap for the mounting tabs and fit everything to mount to the cable guide bolt hole in the case and the rear motor mount bolt it's very sturdy. After it was all welded up I lined it with 1/8" rubber, I have a Trail Tech reg/rect mounted on the back of the box too.
Times are GMT -7.   It's 10:07 PM.
