Old 03-29-2014, 09:08 AM   #1981
jules083
jules083's Avatar
Oddometer: 4,039
Quick question, what is the reason for guys running batteries? I'm planning on a trail tech vapor soon and maybe a small fan for the radiator. Can't think up a need for a battery though, maybe I'm missing something?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 03-29-2014, 09:22 AM   #1982
npcaldwell
Oddometer: 27
From everything I've read if you want to run 12v DC you need either a battery or a capacitor, along with a DC regulator/rectifier to convert the AC coming from your stator. I tried originally to go straight AC and the headlights worked but the led turn signals and the horn wouldn't, now that I'm running DC everything works perfectly.
npcaldwell is offline   Reply With Quote
Old 03-29-2014, 09:38 AM   #1983
jules083
jules083's Avatar
Oddometer: 4,039
True. I'm on AC only right now, I'll have to switch one leg to DC if I get a fan. I got the turn signals to work but don't have a horn.
Wouldn't a capacitor be smaller, lighter, and easier? It's not like we need the battery for anything as far as I know.
Old 03-29-2014, 11:25 AM   #1984
Kiko
Kiko's Avatar
Oddometer: 1,855
I don't think a cap would work with a HID headlight. Don't know if you have HID or have plans to get one, just passing that info along.
Conmigo piscas, y no moloncos.
Kiko is offline   Reply With Quote
Old 03-29-2014, 04:02 PM   #1985
Gildus
Gildus's Avatar
Oddometer: 247
You're right...caps and HID headlights are a bad mix. If you read through the XR650R Electrical thread you'll see why so many guys are running small batteries. Even those without HID lights.
Gildus is offline   Reply With Quote
Old 03-29-2014, 04:34 PM   #1986
BronkoRob
Oddometer: 67
I am looking to mount a battery because of the dimming you get with the lights at idle. Even with high output stators, they dont put out a lot of power at idle RPMs.
No Pads, No Helmet.....Just Balls!
BronkoRob is offline   Reply With Quote
Old 03-29-2014, 04:59 PM   #1987
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
Sean-0 is offline   Reply With Quote
Old 03-29-2014, 05:09 PM   #1988
bigkuri
bigkuri's Avatar
Oddometer: 842
+1
What exactly is the need for a battery? Fix the stator and it'll do everything you need while riding... Do you all have electric starts mounted?
Not trolling, just curious as to why all the batteries :)
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R
bigkuri is offline   Reply With Quote
Old 03-29-2014, 06:06 PM   #1989
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
reason for mine
12v dc pwr the whole bike 200w stator to a reg/rec from a Kawasaki 1000,
to 12v dc to charge battery ...lights work from there ....so hid ...led's ...12v charge to run gps..12v pwr outlet to charge phone other 12v items ...thermo fan ...heated grips...all this avaliable whilst bike is not running
ppl say if ya want all that buy a updated bike ..... i love my xrr's ...
Old 03-29-2014, 06:26 PM   #1990
Keyz
Keyz's Avatar
Oddometer: 58
Originally Posted by Sean-0 View Post
Thanks for pic seano
Could you explain a bit for the wiring, like the fuse setup and the black switches(?) at the top
Present 2001 Bandit GSF1216N
Past 2000 XR650R 2009 DR650 2006 SV650N
Keyz is offline   Reply With Quote
Old 03-30-2014, 11:31 PM   #1991
Akunin
Neo-Vegabond
Akunin's Avatar
Oddometer: 130
reason for mine
how do you like that antigravity?
I'm planning something similar but looking at the powerhub2 to clean up all the electronics. great looking ride there!
Akunin is offline   Reply With Quote
Old 03-30-2014, 11:52 PM   #1992
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
had it about 12 months now and i really like it ....i once left my 12v charger in the socket and drained it to flat about .2v .... i thought dam i have buggered it ...i placed it on my charger ..not a special 1 or nuthin just a cheapo ....put about 5v back in it and then back on my bike ... ran it for a good hr or so then looked at the v and was back to 13.5v ....that was about 6 months ago and no problems ... holds charge for a month or so no worries ... i ride weekly but ws away for a month ...tested v and was the same ....
so yup i recommend them
my lights are 100 watt spot ...55/60watt on the bottom and the 2 led's are 26 watt i think .. so im just under my watt capacity...with led tail light brake light
so they handle that with no issue charge wise ....every time i test the v i get 13.5v
Old 03-31-2014, 12:03 AM   #1993
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
sorry keyz i missed your post
the switch's at the top are mains pwr ... turns on light's dash and tail light
second switch pwrs spotlights and led spots ...switch via the high beam switch on the handle bars ..must be like this for correct road worthy ..via a relay
third switch pwrs the thermofan ...i dont use a temp sensor as my vapor has that so when i see the bike getting hot i switch it on
the fuse box is just that a fuse box so all my lights fan heated grips 12v socket so on are fused ... only popped 1 fuse when a wire rubbed ... but sorted that and all good now
if you look you can see where i labeled the wire ends at the fuse block ....makes for easy fix when i need to
Old 03-31-2014, 12:10 AM   #1994
Akunin
Neo-Vegabond
Akunin's Avatar
Oddometer: 130
just what I wanted to hear about that battery!
That tops the list of next buys next to a high output stator (BD perhaps)
and some LED lights (lots of deer around these parts)
The bike last week (freshly uncorked)
since then I have the LED brake light and blinkers wired up. The new tip on the exhaust is installed as well.
and the new dash featuring
BRP triple, HDB top clamp, brush guards and mirrors (work great btw!)
this is the bike last year when I got the BD dual sport kit for it
so by June I plan of having the following installed:
XRs only skid plate
BD Stator
Antigravity 4 cell battery
MondoMoto auxiliary lights
Powerhub 2
and the HDB top clamp needs a powerlet for charging the gps and cellphone while on the road :)
Old 03-31-2014, 12:38 AM   #1995
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
yup nice work , i set mine up for long haul .the hdb stuff is very nice ...i wanted the setup you have HDB .. but i needed a place to mount batt and reg/rec .and well i ended up like i have
bang a big tank on that and go ride
we are just coming into our winter so riding season is on ...
Times are GMT -7.   It's 07:54 AM.
