01-21-2007, 05:05 PM
#286 |
jamboa
Oddometer: 818
That's the first thing I am thinking of if I go the XR650R route.
04 Triumph 904 Bonneville SE 08 Suzuki GSX1300 BK B King 10 Kawasaki 650 Versys 13 CB1100F |
01-21-2007, 05:26 PM
#287 |
Who knows
Oddometer: 1,746
Both are available but not in stock form
there are electric start kits and big bore kits for the Big Pig not sure why you would want either, but it's your money baby
There's a fine line between "RED ASS" and "DUMB ASS" "Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK |
01-22-2007, 05:48 AM
#288 |
Fresh Ground
Oddometer: 2,077
I briefly thought about estart for my pig, but sheesh that's a lot of money and fair amount of weight and complexity - for what?
Just put on an Edelbrock, and though I've not ridden it yet, cold starting is a breeze and based on reports hot starting will be just as easy as a good day - and very easy after a dump. More snap too, should lighten the front end when required quite nicely. Frankly, only after a dump when hot have I had any trouble starting it with the stock carb.
-Bill '06 Buell Ulysses 'Odysseus' a.k.a. 'Ody', '00 XR650R plated & farkled- 'Nuclear Thunderpig' '06 PS1000LE Paul Smart. One cannot do without a Duc or two. '97 KDX 220 for woods work SMUGMUG COUPON RSKbiM6oytjtw, save some money and have a great online picture gallery! |
01-22-2007, 06:23 AM
#289 |
Dog Rancher
Oddometer: 4,181
When I bought my BRP the previous owner told me how to start it. I got it home and was going through his routine and it started while I was trying to find TDC. It is one of the easiest kickers I have ever had.
01-22-2007, 06:29 AM
#290 | |
Gimme Dirt
Oddometer: 371
01-22-2007, 07:49 AM
#291 | |
ZAPP - Tejas
Oddometer: 12,920
The absence of the secret ritual is what puts nice, barely-ridden, low mileage stock BRP's on the aftermarket
Zapp "I will not let the White City fall... nor our people fail.” - Aragorn K4 WEESTROM Stealthfighter Black - Invisible to Radar '02 DR650SE SOLD ![]() '97 DR650SE My Fave
01-22-2007, 08:06 AM
#292 |
Dog Rancher
Oddometer: 4,181
I guess my point was mine started without the ritual.
Also if you haven't done it yet, when you have the carb off look at it as you twist the throttle to see the stream of fuel squirt. Gives you a mental picture of what happens if you twist as you kick.
01-22-2007, 08:20 AM
#293 |
ZAPP - Tejas
Oddometer: 12,920
one thing [of many!] I do not understand is the vast diff between my properly-jetted DRZ/FCR vs. my XRR.... the XRR starts with no messing around with throttle [in fact its a no-no....] and its "not a pumper". The DRZ's FCR is a pumper but it can be a b#!@@$ to start. Different ritual.... gotta "pump" the throttle about 10 times first, then hit the magic button, then DON'T touch the throttle when it fires, you just cross your fingers and hope it stays. most times it dies about half a dozen times [it runs outta fuel.... how ?] frustrating to say the least.
but the non-pumper just starts.... idles with choke on for 30 seconds or so, then half-choke... just let 'er warm the oil a bit.
01-22-2007, 08:26 AM
#294 |
Fresh Ground
Oddometer: 2,077
I wonder if your FZR is a tad lean in the idle circuit? Also, part of the secret ritual with my Pig was cranking up the idle a bit (several turns) until she warmed up, you might try that with the DRZ.
The Edlebrock is a breeze, no choke but none needed. Find TDC, decomp and slight kickstarter movement, turn on the ignition (BD dualsport kit, basically move it off the 'kill' position), three squirts on the throttle, and sharp kick. Not even dialed in yet, and takes 1-3 kicks tops.
01-22-2007, 08:48 AM
#295 | |
Who knows
Oddometer: 1,746
If it were me I would run Conpression and check everything out, I do that anyway on new/used stuff, but that is just me, the week I got my bike home I tore it down to the frame and motor, Now I know what I have.
01-22-2007, 08:55 AM
#296 | |
Who knows
Oddometer: 1,746
01-22-2007, 08:57 AM
#297 |
Who knows
Oddometer: 1,746
[quote=Red_Chili]I wonder if your FZR is a tad lean in the idle circuit? Also, part of the secret ritual with my Pig was cranking up the idle a bit (several turns) until she warmed up, you might try that with the DRZ.
quote] I read you say this on another thread and I do this now, it really helps cold run and then first time I stop pop off my glove tweak it back down and all is good in the pig pen again.
01-22-2007, 12:07 PM
#298 | |
Dog Rancher
Oddometer: 4,181
I didn't have a 4 stroke at the time so I never experienced that. I sold my KTM300exc and got a KTM400exc and gave the throttle a twist while the carb was off for jetting. It looked like a tiny drinking fountain squirting fuel. Later I bought a BRP on ebay. I got it home and tried to start it like the guy told me. It just started like it was a Honda 50. I was expecting a long painful kicking fight. I just assumed it had an accelerator pump. I haven't done much work with it yet. In August I had jetted my BRP just right and it was running fine. I was returning home from a ride. There had been some light rain and the BRP threw me to the ground as I went over a wet wooden creek over pass. My BAJA designs ON/OFF Light switch got smashed. I sprained both ankles and couldn't get it started. (FYI My worst ankle was my left. I think my boot got caught between the peg and shifter). My friend had his truck and took me and BRP home. So up until the crash my BRP started fine.
01-22-2007, 12:08 PM
#299 | |
Talks more than he rides
Oddometer: 995
Peter |
01-23-2007, 03:44 AM
#300 | |
Feral Chia tamer
Oddometer: 2,596
Which tank is this, and does it interfere with moving forward on the bike? Thanks
Mutt'n the custard. On the outside with my back turned. |
